The Volks Cottage
28x42 Volks Cottage Plans Kit from CountryPlans.com
  • 983 square feet (28’x42’ overall, L-shaped)
  • 2 bedrooms
  • 1 bathroom
  • Open great room with dining area
  • Light fixtures, switches, GFCI callouts and plumbing fixtures shown in position on the floor plan
  • Foundation plans: slab and crawlspace included
  • All structural information needed for starting the permitting and construction bid process included
PDF plans$275
Paper plans$350
PDF + Paper$425
PDF plans are complete ready-to-print drawings for permits and building. Paper plans are printed sets shipped to you.
Already own an older paper set of these plans? Adding the current PDF to your set is $75. Booklet and materials list come with it. Write to questions@countryplans.com with your name and the plan.
Purchase the Volks Cottage Plans
Order Plansfrom $275 · PDF or Paper
PDF plans arrive by email, usually within hours. Paper plans are 5 printed sets by USPS.
The Volks Cottage is an alternative floor plan for the Grandfather Cottage. Slightly larger, but still under 1000 sf. this easy to build Cottage House can be built on either a slab or crawlspace foundation (both foundation plans are included). The roof is trussed with a sloped cathedral section over the Great Room. Optional skylights fit between the trusses and bring in extra light to the center of the house.
All interior walls are non-load bearing so the interior can be revised as needed. The addition wing could easily be reflected on the other side of the cottage for a large family room or sunroom/dining room. The plans have the structural information needed for building permits and contractor bids. The roof is built with inexpensive lightweight trusses engineered to your local requirements and these can often be delivered to the tops of the walls. The floor plan shows light fixtures, switches, GFCI callouts, smoke detectors and plumbing fixtures in position, and the booklet includes a page of plumbing and electrical notes.
This home is designed to be sun tempered and well insulated. The walls are 2x6 @ 24" o/c and the insulation is R-21. The trusses are "energy" trusses for R-38 ceiling insulation all the way to the outside wall. The plans include easy to change window and door layouts for customizing the layout for your site and climate. The slab floor option includes insulated thermal mass that can be used for sun warmed floors and lower heating bills. Information is included for a radiant floor heating system using a small gas water heater.
Included with the drawings are additional upgraded details (items not required for permit) — interior and exterior trim options, window hoods, and a craftsman style upgrade to the porch.  The Plans kit also include a Project Planner for customizing your plans and getting the best prices from builders and subcontractors, and a Building Department Strategy Checklist for smoothing the sometimes tricky process of getting your permits.
  • info on how to find the right land
  • tips for dealing with the building dept.
  • notes about heating, hot water, & a/c
  • info about foundations and soil types
  • a guide for how to read house plans
  • a guide to typical platform framing
  • a guide to earthquake and wind bracing
  • details for rafter and dormer framing
All of this is in the free 10-page booklet that ships with every plan set.
28x42 Volks Cottage Plans Kit from CountryPlans.com includes
The Materials List
Every set comes with a materials list: a five-page take-off of the shell, as an editable Word file and a PDF. It was put together by a professional take-off service. The pages run from the sub-floor and wall framing up through roofing, siding, doors, windows, insulation, drywall, rough hardware, plumbing and electrical, with a blank price column for you to fill in. The Volks has its own list, not a shared one.
Take it to a lumber yard and get a quote before you commit. The list is for comparing suppliers, not for ordering. A note on every page says what it leaves out: foundation concrete, rebar, wire mesh, visqueen, cabinets, complete plumbing and electrical materials, HVAC, finish flooring, paint and appliances. Trusses come from a local truss manufacturer. You can edit the Word file for your own material choices; save it under a new name to keep the original.
Dimensions and loads
The numbers people ask us before they buy.
Footprint
28' x 42' overall, L-shaped, with a 16' x 12' corner the sheet marks as a future deck or patio: 983 sf of living area on one story, a near mirror of the Grandfather.
Wall height
8' ceilings generally, and they can be raised.
Loft or second floor
None.
Ceiling and headroom
8', with a sloped cathedral section over the Great Room. John Raabe, who drew these plans, noted that the minimum for a habitable room is 7'-6".
Roof pitch
6/12 main roof, 9/12 porch roof.
Design snow load
Not certified for one site. The truss company carries the snow and wind loads.
Height to peak
16'-8" +/-.
Dimensions come from the plan sheets. None of these plans is engineered for one site: your truss company designs the roof to your local snow and wind loads, and your building department has the last word. Ask us about anything not here at questions@countryplans.com.
A Customer’s Story*
The owner's carpenter grandson built this house. Planned as a family building project, it not only saves money, but gives the young builder a chance to manage a full-sized construction project on his own. He will probably go on to build some fine homes for others judging by the care he is taking on this one.
A customer-built Grandfather Cottage
A house like this is a particularly good one for an owner/builder/contractor. The one-story construction is simple to frame, there is no stairway to deal with, the roof trusses eliminate most roof issues, and the heated floor slab simplifies the number of subcontractors who must be managed. Plus the floor plan is more flexible than almost any other type of design. This allows for easy modifications even after the project is underway.
This earlier photo shows the two skylights that bring light into the interior of the house
Notes on the cost of this home: The owners spent around $65k for everything including a $1,500 outside storage shed and a $1,500 propane stove. The hardwood cabinets, new appliances, jetted 6' bath tub, W/D, etc. are included in that figure. The builder got $25/hr wages but probably didn't bill for all his time. Other subs (friends of the family) probably billed less than they normally would as well. The house is quite nice on the interior with rounded drywall and wood trimmed (vinyl) windows and doors.
*this is the story of the Grandfather’s Cottage (a reversed layout of the Volks Cottage)
2 Story Universal Cottage. Country House Plans
The Volks Cottage
