- An Inclinometer with surveying charts. Use this tool to determine the slope of a hillside and layout the best driveway or trail to your house. Use it to estimate the height of trees and to locate where they might fall. (You don't want to build under storm blown trees!) You can also use it to do simple surveying such as laying out a foundation. Instructions included.
- A Solar slide rule that shows you how high in the sky the summer and winter sun is for your particular latitude. Use this with the inclinometer and you will know what trees block your winter sun and which ones will give you summer shade. Use this to decide what to cut down and where to do new plantings. You can take the solar slide rule and inclinometer with you when looking at property to understand what kind of sun it will get throughout the year.
- False Front option for the Little House. This western store front can be added to any of the cabin plans and gives an old-town feel to a home office, workshop, or guest outbuilding. The deck/boardwalk out front can tie back into the big house.
Little House Plans Kit
- 140-336 sq. ft. (Comes with three different plans included: 10x14, 12x18, & 14x24)
- The perfect starter house project
- Works great as a workshop
- Can be used as a home office
- Makes a cozy get-away cottage
- Multiple foundation types (all included)
- Easy to build
- Materials List included
PDF plans are complete ready-to-print drawings for permits and building. Paper plans are printed sets shipped to you.
Already own an older paper set of these plans? Adding the current PDF to your set is $75. Booklet and materials list come with it. Write to questions@countryplans.com with your name and the plan.
Purchase the Little House Plans Kit
Order Plansfrom $225 · PDF or PaperPDF plans arrive by email, usually within hours. Paper plans are 5 printed sets by USPS.
The Little House (some might call it a Tiny House) Plans Kit has complete plans for three sturdy long-lasting houses you can build inexpensively by yourself or with the help of a friend, spouse or kids. Each of these houses can be used as a camping cabin, starter house, workshop or home office. Each can be built with a walking roof deck or with a steep pitched roof and a small loft.
The Plans kit includes construction plans for all three houses (10x14, 12x18 and 14x24) and full instructions. The booklet also shows how to combine all three into one expanded house. Your license covers one project per plan set. The plans include a simple to build post and pier foundation for a permanent little house. This latest version also includes details for an even easier to build skid foundation for a closer to the ground movable cabin, storage shed or playhouse - any building that won’t need access to plumbing under the floor. Here are the three different floor plan options: (click to expand the photos)
Planning a full second story on the 16x24 footprint? See our 16x24 two-story cabin guide.
Plans include
- A ten page booklet with complete building and customization instructions. Including: how to adjust your cabin for climate & soil variations, insulated footings for cold climates, working with the building department, how to find the right builder, and lumber yard tips for buying the right materials.
- Nine pages of plans which include a library of window and door layouts and the False Front version of the 14’ cabin.
- A step-by-step construction checklist for building each phase of the house.
- A Materials List for pricing and building any of the three houses.
Bonus tools included
The Materials List
The Little House booklet and materials list ship as one PDF. The shell materials list is a page inside it, headed "Little Houses – Shell Materials List", with a column for each of the three cabins: 10x14, 12x18 and 14x24. It runs from foundation and subfloor through walls, flat roof, gable roof and loft, then siding and interior wall areas.
Take it to a lumber yard and get a quote before you commit. The list is for comparing suppliers, not for ordering. Concrete is bid locally from your site conditions.
Dimensions and loads
The numbers people ask us before they buy.
- Footprint
- Three cabins: 10' x 14', 12' x 18' and 14' x 24'. 14' is the structural limit.
- Wall height
- 8' 2x4 walls, with 92" studs on the 12x18. John Raabe, who drew these plans, said 10' was allowed with no other change.
- Loft or second floor
- A crawl-in storage loft on the wall plates. John put a code stair in a 14x24 at about 17% of each floor.
- Ceiling and headroom
- Loft headroom at the peak: about 3'-10" at 10' wide, 4'-10" at 12' wide, 5'-10" at 14' wide. Header height on the clipped-roof detail is 6'-8".
- Roof pitch
- 12:12 on the steep gable roof.
- Design snow load
- Light duty: post-and-pier for mild climates. John's answer on the 2x8 loft joists was that they are fine, and that it would take much more than storage up there to get over 30 psf. In snow country he pointed buyers to the Builder's Cottage.
- Height to peak
- The 14x24 peaks at 18' above grade, the same as the Builder's Cottage.
Dimensions come from the plan sheets. None of these plans is engineered for one site: your truss company designs the roof to your local snow and wind loads, and your building department has the last word. Ask us about anything not here at questions@countryplans.com.
Related discussions on the forum
Our story of building the Little House
My two sons and I built the smaller (10'x14') cabin. We used only hand tools and a circular saw and worked on it part time over three weeks. The house was weather-tight in 11 days. We spent about $1,400 (or $10/SF in the year 1998) buying all construction materials new from our local lumberyard except for the used windows and doors. It has complete insulation, interior finished wood on the walls and ceiling, and a small wood stove and chimney.
