Two Story Universal Cottage
The 20’ by 34’ Two Story Universal Cottage House Plans Kit from CountryPlans.com has a saltbox foundation
  • 1360 square feet (20’x34’)
  • 3 bedrooms
  • 3 bathrooms
  • 8 Foundation types included
  • Plans contain all structural information needed for permits and construction bids
  • Editable CAD file available
20 by 34 main floor plan from CountryPlans.com
main floor plan
20 by 34 floor plan from CountryPlans.com
upper floor plan
PDF plans$375
Paper plans$450
PDF + Paper$525
CAD + PDF$725
CAD + PDF + Paper$800
PDF plans are complete ready-to-print drawings for permits and building. CAD plans add the editable drawing files, so you or a designer can make changes in CAD software. Paper plans are printed sets shipped to you.
Already own an older paper set of these plans? Adding the current PDF to your set is $75, and adding CAD + PDF is $350. Booklet and materials list come with it. Write to questions@countryplans.com with your name and the plan.
Purchase the Two Story Universal Cottage Plans
Order Plansfrom $375 · PDF, Paper or CAD
PDF and CAD arrive by email, usually within hours. Paper plans are 5 printed sets by USPS.
This classic 20' wide farmhouse-style home is built with simple platform frame construction on your choice of eight different foundation types to adapt to your specific soils, budget and site. The home feels spacious and open but is efficient with its use of space. The plan has three bedrooms and three bathrooms, a utility hall and a full sized wrap around stair. The stair can go down to a basement or on up to the attic, should you need to expand up there in the future. Because of the simple framing system much of the interior layout can be modified by the owner or builder.
The Two Story Universal Cottage is a great starting platform for your own home building project because additional wings can be added in the future and the plans include options you might choose to build anytime, such as an add-on window seat or wrap around porch. The 16 page plan set includes all the drawings and information normally needed by builders and the building department, including:
  • Full structural floor plans (main, upper and basement)
  • Full foundation plans and details for a basement, crawlspace, slab, or beam and pier (post & beam) foundation
  • Structural cross section with basement, crawlspace, slab and pier and beam foundation options
  • Roof and attic framing plans and details for both truss and rafter & joist framing
  • Optional truss diagrams for flat or cathedral ceiling in the upper story
  • Basement plans with details for your choice of poured concrete, concrete block, or the stud and plywood all-weather wood foundation system
  • Foundation details for two types of concrete slab on grade floors and two types of pier and beam systems
  • Framing plans for floors using both I-joists for full width spans, or 2x8 joists and an exposed interior beam and post support system
  • Porch framing plans and details for the shed roof porch in the photo, plus an extendable wrap around porch that can run down either side
  • Four elevations including trim and siding details
  • Electrical plans and plumbing layout notes
  • A bonus sheet with complete plans and details for a pop-out bed and sitting alcove that can be added to any outside wall (it needs no foundation)
Plans are ready to submit to your building inspector after you decide which foundation plan sheet to include and which way you want to build the roof. Electrical plans and plumbing locations are included. As with any building plans, you may be required by the inspector to make changes for your local codes and requirements. The 6 page materials list includes all materials for the post & pier foundation, house framing, hardware, insulation, windows and doors, drywall, electrical, plumbing and interior trim. This can be helpful for pricing materials and tracking costs.
  • Superinsulation techniques for cold climates
  • Hot water and heating system design notes
  • A checklist and tips for going to the building department
  • A diagram and glossary of standard building terms
  • A ‘How to Read Plans’ diagram
  • Trim, Siding and Money Saving Ideas
All of this comes in the free 11 page booklet included with every plan set.
The 2 Story Universal Cottage House Plans Kit from CountryPlans.com includes everything seen here.
Here is everything that comes with a plan set (note that paper orders come with 5 sets of printed plans, only one is shown here)
The Materials List
Every set comes with a materials list: a six-page take-off of the shell, as an editable Word file and a PDF. It was put together by a professional take-off service. The pages run from the sub-floor and wall framing up through roofing, siding, doors, windows, insulation, drywall, rough hardware, plumbing and electrical, with a blank price column for you to fill in.
Take it to a lumber yard and get a quote before you commit. The list is for comparing suppliers, not for ordering. A note on every page says what it leaves out: foundation concrete, rebar, wire mesh, visqueen, cabinets, complete plumbing and electrical materials, HVAC, finish flooring, paint and appliances. Trusses come from a local truss manufacturer. You can edit the Word file for your own material choices; save it under a new name to keep the original.
The list used to be a paid extra. It comes with the plans now.
Dimensions and loads
The numbers people ask us before they buy.
Footprint
20' x 34', two full floors plus a storage attic. 1,360 sf of living area.
Wall height
2x6 walls. John Raabe, who drew these plans, said the ceiling could be anything up to 10', and that a 9' ceiling changes only the stair.
Loft or second floor
A full second floor. The attic is storage with 7' of headroom at the peak, not drawn as living space.
Ceiling and headroom
John's stair notes set the stair-headroom minimum at 6'-8". The upper bedrooms are fine at 7'-6".
Roof pitch
10/12 as designed.
Design snow load
John's design basis for his plans was standard code loads for the floors and 35 psf live load for the roofs, enough for all but heavy snow country, with the floors designed for the heavier 40 psf live load. The truss option is engineered locally.
Height to peak
About 28' above grade.
Dimensions come from the plan sheets. None of these plans is engineered for one site: your truss company designs the roof to your local snow and wind loads, and your building department has the last word. Ask us about anything not here at questions@countryplans.com.
Related discussions on the forum
Here are a few photographs of a local builder’s version of the Universal Cottage. This was built by Sky Hoelting on Whidbey Island, Washington State. The owner used board and batt siding, with shingles on the gable ends. There are nice porch details and an attached carport in the rear. Click here to see a few more photos.
Here’s the front entry area, looking over the dining area towards the kitchen
The 20’ by 30’ Two Story Universal Cottage House Plans Kit from CountryPlans.com has a saltbox foundation
A customer-built Two Story Universal Cottage with a porch on the long-end of the house
The living room
2 Story Universal Cottage. Country House Plans
