Building Codes and Permits, in Plain English
How stock house plans, local codes, and the permit desk actually fit together.
Do these plans meet code?
This is one of the most common questions we get, and the honest answer is more interesting than a yes or no: no stock plan from anyone, ours included, is “certified to code,” because there is no such thing as one building code.
Here is how it actually works.
There is no single building code
Most states base their rules on a model code called the International Residential Code (IRC). A new edition comes out every three years, and each state adopts its own edition, on its own schedule, with its own amendments. Many states enforce editions that are years old. Some skip the IRC entirely: Wisconsin, for example, has its own Uniform Dwelling Code for houses.
On top of the state rules, your own piece of land has the final say. Snow load, wind, frost depth, and soil conditions all change what a code-approved building looks like. A foundation that sails through inspection in Georgia would fail in Minnesota. Compliance is a property of a building in a place, never of a drawing by itself.
So how does anyone build from stock plans?
The same way people have for a hundred years. You take a good set of plans to your local building department, and they review it against the rules for your area. The plan reviewer marks anything that needs adjusting for your location, and a local builder, designer, or engineer makes those adjustments. Then you get your permit and build.
This is the system working exactly as designed. The permit desk is not an obstacle; it is the free expert review that makes sure your house suits your climate and your ground.
Our plans are drawn to sound construction practice and give you the complete picture of the house: the structure, the dimensions, the materials. Lots of folks build by using them as a starting point, then work with someone local to fit the details to their land and their code.
What usually needs adapting
On any stock plan, from any company, the local adjustments tend to be the same short list:
  • Insulation and energy details, which vary by climate zone and have tightened over the years
  • Egress window sizes in bedrooms
  • Stair dimensions
  • Wall bracing details in high-wind areas
  • Smoke and carbon monoxide alarm locations
  • Foundation depth and design for your frost line and soil
For a simple, small house, these are routine changes a local pro handles all the time.
What about an engineer’s stamp?
Our plans do not carry an engineer’s or architect’s stamp, and no stock plan does in any meaningful way. A stamp certifies that a design meets the rules of a particular jurisdiction, so it has to come from an engineer working with your local requirements. Most areas do not require a stamp for a small one- or two-family house. If yours does, there are engineers in every region who specialize in exactly this job, and it is usually a modest, one-time cost.
A good path, in order
  1. Pick the plan that fits your project and your land.
  2. Get to know your local building department early in your planning. A short call or visit about what they require for a small house saves surprises later, and they are usually friendlier than people expect.
  3. Line up a local builder, designer, or engineer to fit the plan to your site and your code.
  4. Submit, adjust whatever the reviewer marks, and build.
Plenty of the owner-builders in our forum have been through the permit process, in nearly every state, and their build threads are a good way to see how it goes in the real world.
