The Big Enchilada
14x24 Builders Cottage Big Enchilada Plans Kit from CountryPlans.com
  • 140 to 692+ square feet across the bundled plan sets, from a single small module to the 14’x24’ Builder’s Cottage core (336 sq ft) plus additions
  • 1-3 bedrooms
  • 1-2 bathrooms
  • Super modular home kit
  • Multiple foundation types included
  • All structural information needed for starting the permitting and construction bid process included
14x24 Builders Cottage from Country Plans
The Big Enchilada includes: The Little House Plans (left), The Builder’s Cottage Plans (center), and the Sunroom, Greenhouse & Skylight Plans (right). The drawing above is just one of many possible configurations.
PDF plans$375
Paper plans$450
PDF + Paper$525
PDF plans are complete ready-to-print drawings for permits and building. Paper plans are printed sets shipped to you.
Already own an older paper set of these plans? Adding the current PDF to your set is $75. Booklet and materials list come with it. Write to questions@countryplans.com with your name and the plan.
Purchase the Big Enchilada Plans
Order Plansfrom $375 · PDF or Paper
PDF plans arrive by email, usually within hours. Paper plans are 5 printed sets by USPS.
The Big Enchilada Plans can be used as a flexible small home design kit. The house at the very top of the page is only one possible combination. You can customize the plan layouts to fit your site and space needs.
This kit starts with the Little House Plans Kit and all the included bonuses. Then we have added an upgraded core house plan for the 14' x 24' house called the 14' x 24' Builder's Cottage. This building has a concrete perimeter foundation, 2x6 walls for R-21 insulation and R-30 in the roof. These construction details can also be used in the smaller building modules added for wings and extensions with the plans kit.
We’ve also added the Sunroom, Greenhouse & Skylight Plans, which lets you build inexpensive sunroom windows and skylights into the main house or additions. Every Big Enchilada set also comes with a free 19-page booklet. Here are a few of the details included in the kit:
There are enough options here for just about any combination of small homestead buildings or a build-as-you-go expandable cottage (up to 14' in width). The booklet shows one expanded example at 692 square feet: the 14' x 24' cottage with a 12' x 18' gable addition and a 10' x 14' shed addition. Make your own customized building plans as your project evolves. Many people use the included Builder's Cottage plan for the building permit and core house and then modify the project from there.
  • Superinsulation techniques for cold climates
  • Hot water and heating system design notes
  • A checklist and tips for going to the building department
  • Trim, Siding and Money Saving Ideas
  • A guide for taking your plans to the building dept. (strategies for the bureaucratic hurdles)
  • The guide Evaluating your Soil - use this to determine which foundation type is appropriate for your specific site
  • A guide to framing terms and the symbols and abbreviations used in building plans
14x24 Builders Cottage Big Enchilada Plans Kit from CountryPlans.com includes
The Materials List
The Big Enchilada kit includes the whole Little House Plans Kit, and that kit's booklet and materials list is the list that ships with this set. The shell materials list is one page inside that PDF, with a column for each of the three cabins: 10x14, 12x18 and 14x24.
There is no separate materials list for the 14x24 Builder's Cottage. The booklet says why on its first page: there are several ways to build this plan, so there is no fixed list. Once you have made your choices, have a takeoff done by your lumber center. A materials list is for comparing suppliers, not for ordering.
Dimensions and loads
The numbers people ask us before they buy.
Footprint
A 14' x 24' Builder's Cottage with 2x6 walls and a concrete perimeter crawlspace, plus the full Little House set.
Wall height
8' walls with the rafters on the plates. John Raabe, who drew these plans, said 9' or 10' was straightforward. The booklet has details for 12' studs with the loft floor at 8'.
Loft or second floor
A ladder loft. The 12' stud option gives a taller and wider one.
Ceiling and headroom
8'-1 1/8" finish floor to top plate, 6'-10 1/2" header height.
Roof pitch
12/12 main roof, 12/4 porch roof.
Design snow load
John noted the Builder's Cottage has 2x12 rafters for heavy snow loads and deep insulation, and he sent sites at 65 psf to an engineer.
Height to peak
18' above grade.
Dimensions come from the plan sheets. None of these plans is engineered for one site: your truss company designs the roof to your local snow and wind loads, and your building department has the last word. Ask us about anything not here at questions@countryplans.com.
Related discussions on the forum
Details on the Builder’s Cottage (included in the Big Enchilada)
The Builder’s Cottage is a classic little house. There are two sleeping areas, a small kitchen and a full bath. Lots of windows, a dutch door, an open cathedral ceiling, skylights and a sitting porch add a feeling of spaciousness to a small cottage. The cottage is highly energy efficient and designed for year-round living.
The Builder’s Cottage floor plan: 14' x 24' with a 7'-6" x 13' sleeping loft, 3'-6" storage loft & a 5' porch
Exterior Sketch with front porch, note the window hoods
14x24' Builder's Cottage Plans from CountryPlans.com
The 14' x 24' Builder's Cottage
Included in the plans is information for building a 12' sidewall detail that can give a larger loft
2 Story Universal Cottage. Country House Plans
The Big Enchilada
