Progress
photos of a 14' x 24' Little House
Foundation - Because of deep cold in this climate, the owner used poured concrete piers for his footers. From owner Brian Wing: "The building inspector said I had to dig 40" to the frost line, so I did. I first made 10" dia. X 6" footers (I put an anchor bolt in the center) using cement tubes cut down. I made these in my basement over the winter. When I finally got the holes dug, I put crushed stone in the bottom for a base, then the concrete footers I made, then I put a 4' long x 8" dia. cement forming tube on top of that. Filled it up with cement and put a bracket in the top of it before is hardened. It turned out great." |
Beams - You can see that the owner spread crushed rock over the underfloor area of the house. This keeps things clean and retards weeds. Here Brian and his father are building the beams. They are using 2 LVL composite beams spliced together. These will sit in the saddles of the pier footings. |
The floor joists - Now things are starting to take shape. The floor joists are going up. |
Sheathing the roof - With the exterior walls and roof rafters in place the crew is moving along quickly.
Out of
the Weather: Here are pictures of where the house
is at this point. Brian says: "It only took 4 weekends to do. My father
helped with the low stuff and my wife's brother helped with the roof
— and that was it. Cost so far is approx. $3000. I'm going to
insulate it and put up some knotty pine boards on the inside, and then
put a log siding on the outside (to give it the log cabin look), but
that won't be until next spring. I'll send progress pictures as I get
them." Click Little
House Plans Kit to see the plans. |
