Interesting comments. Glen my wife insists I finish the siding so painting the felt is out. During the design process I looked at thousands of house photos online of nearly every style. The final design has a strong Japanese influence but it also has some northern Europe influences as well. The basic structure shell is really just a modified Victorias cottage without the wing added. It looked easy to build and efficent use of materials. But I also want a sort of holiday home look as well. Like going on some sort of permanent vacation. In the end its just a cabin but one with a slightly unusual and I hope interesting style. Thanks for the kind words.
I think I understand your question. The felt goes all the way down the wall to about 1" below the deck. There is a layer of 8" wide galvanized metal and 2 layers of #30 felt there. If that won't weather it in nothing will. The deck wood will shield the felt from the sun. Siding does not weather proof the wall the felt does. The deck is actually below the wall and floor and is attached to the foundation beams of the house. Siding will start at the top of the deck. The deck boards are spaced away from the house 3/4" to allow water to drain out below.
That's total cost of building materials for everything. I've spent about $600 on the deck so far. I haven't included fuel yet which I guess I should but I doubt it's over a couple of hundred since I try to buy lumber on my regular trips to town. The cabin is only a 1/4 mile from my house so not much fuel use there.
Oh I expect it will go up alot. My budget is $15k for the total project so I'm only 1/3 done. I'd have to go thru all the recipts to get a price list together but I can give some examples.2x4x104 5/8 stud- $1.994x8 sheet 7/16 OSB- $5.352x6x16'- $8.002x8x10' treated- $8.39Something to watch out for when shopping for lumber is price per foot for various lengths. The longest lengths are not always the cheapest per foot. For example a 2x6x10' treated is $5.79 a 2x6x12' treated is $8.55 and a 2x6x16' is $12.00 as you can see buying the wrong length will cost you more. The 10' board is the best value so when possible I used shorter boards. On the other hand the best price I got on 2x4 lumber other than studs was on 20' lengths for $5.19. I compared prices among several stores before each major purchace.
