Wall Plugin for SketchUp
0 Members and 76 Guests are viewing this topic.
Medeek
Nathaniel P. Wilkerson, P.E.
Medeek
Is 8,000 sqft too large? I'm going to say yes, at least for most people.
Besides the regular mdkBIM plugins I also used the grid tool (Medeek Project), but the regular SketchUp grid tool works just as well. A grid tool is a requirement in my opinion, you really need something like this for laying things out correctly.
I also used TIG's mirror tool for certain manual modeling tasks.
The trim and extend tools in the Medeek Project were also very handy for creating my diagonal braces.
Medeek
Version 3.7.2 - 10.13.2024
- Fixed a critical bug with the in-wall column module.
- Added the following additional Wide Flange (W14) beams to the beam module: W14X38, W14X43, W14X48, W14X53, W14X61, W14X68, W14X74, W14X82, W14X90, W14X99
- Added the following additional Wide Flange (W16) beams to the beam module: W16X45, W16X50, W16X57, W16X67, W16X77, W16X89, W16X100
- Enabled a wood grain and an end grain material for glulam beams within the beam module.
- Enable additional built-in materials for "Custom" in-wall columns.
- Added the following (27 - low poly) Simpson column bases to the post module: CB7_6, CB1212, CB1012, CB1010, CB812, CB810, CB718_7, CB718_6, CB718_4, CB612, CB610, CB88, CB86, CB68, CB64, CB48, CB46, CB9_105, CB9_75, CB9_9, CB9_6, CB7_105, CB7_75, CB7_9, CB6_7, CB5_45, CB5_6
- Added the following (6 - low poly) Simpson column caps to the post module: CCQ84, CCQ86, CCQ94, CCQ96, CCQ98, CCQ106
Medeek
Version 3.7.4 - 10.22.2024
- Added the following (27 - low poly) Simpson post caps to the post module: 1616HTQ_8, 1616HTQ_6, BC8, BC6, BC4, BC46, RTC44, LCE4_64, LCE4_46, LCE4_6, LCE_4, AC4R_4R, ACH6_8, ACH6_4, ACH6_6, ACH6E_8, ACH6E_4, ACH6E_6, ACH4E_6, ACH4E_4, ACH4_6, ACH4_4, AC6_4, AC4_6, AC4_4, AC6_6, AC6R_6R
Medeek
Version 3.7.5 - 10.23.2024
- Added the following (9 - low poly) Simpson post caps to the post module: LPC4_4, LPC4_6, LPC4_8, LPC6_4, LPC6_6, LPC6_8, PC4, PC6, PC8
- Added the following (10 - low poly) Simpson post bases to the post module: ECB88, ECB66, EPB66, EPB46, EPB44, MPB44, MPB66, MPB88, PPBF44, PPBF66
The post module now has 86 post caps and 65 post bases within its built-in library.  I think I've modeled about 75% of the Simpson Strong-Tie's Wood Construction Connectors Catalog at this point.
Medeek
Tutorial 53: Multi-Landing Stairs (10:21)
Medeek
Version 3.7.7 - 12.12.2024
- Added a "Calculated Parameters" section to the edit menu of the stair module.
- Added the ability to create L-Shape, U-Shape and Straight runs of stairs with landings.
Medeek
Tutorial 54 - Stairs with Landings (13:27 min.)
Medeek
First look at double landing configurations with 2-step and 3-step L-winders:
Medeek
Version 3.7.8 - 12.17.2024
- Added the following L-Shape and U-Shape winders: 2, 3, 4 and 6 step.
- Added the following two step angle winders: 30, 45 and 60 degrees.
- Added the following T-Shape stairs with landing: T, TL, TR
- Enabled double landings for all landing and winder configurations.
Medeek
**Tutorial 55** - Complex Stairs (9:57 min.)
Medeek
Tutorial 56 - Flared Stairs (4:53 min.)
Medeek
If I enable some turn outs and volutes I will need to adjust for these but also I need to provide some additional parameters so one can fine tune the placement of the handrail and its termination:
Medeek
The handrail sub-menu now has a few more parameters:
Medeek
Tutorial 57 - Over-the-Post Handrails and Fittings (18.42 min.)
Medeek
Version 3.7.9 - 12.26.2024
-  Added the inverted T-Shape landing.
-  Enabled straight and curved flared staircases.
-  Added 37 handrail fittings into the built-in handrail fittings library.
-  Updated the handrail module with additional parameters for over-the-post handrail systems.
-  Enabled additional handrail sub-menus for multi-landing stair assemblies.
Medeek
Version 3.8.0 - 12.30.2024
- Enabled open tread staircases.
- Added sub-menus for multiple stair runs for open treads.
- Added the following starter steps: square, full round and half round.
- Added a return parameter for square cut starter steps.
- Enabled flared handrails (over-the-post) for straight and curved flared staircases.
Medeek
Tutorial 58 - Open Treads and Starter Steps (7:35 min.)
Medeek
Tutorial 59 - Multi-Board Treads and Side Spacers (7:15 min.)
Medeek
First look at over-the-post handrails with posts:
Medeek
Version 3.8.2 - 01.05.2025
- Added balusters to the stair module for vertical and OTP handrails.
- Added newel posts to the stair module for vertical and OTP handrails.
Tutorial 60 - Balusters, Posts and Handrails (16:39)
Medeek
Version 3.8.3 - 01.10.2025
- Added a "deck" profile or option for handrails (with balusters) to the stair module.
Tutorial 61- Handrails for Decks (8:51 min.)
Medeek
Version 3.8.4 - 01.14.2025
- Added a minimum winder depth parameter for all stair winder types.
- Adjusted the deck handrail algorithm for narrow cap rails (2x4).
Medeek
Version 3.8.5 - 01.21.2025
- Updated the skirt boards to accommodate open treads.
- Added tread covers, carpet and stair runners for stairs, landings and winders.
Medeek
Tutorial 63 - Stair Runners and Tread Covers (10:06 min.)
