Wall Plugin for SketchUp
0 Members and 19 Guests are viewing this topic.
Medeek
Version 1.3.9 - 04.28.2020
- Added a "Terminal" end wall condition.
The principal use of this end condition is for interior walls terminating against multi-wall corners as shown above.
Nathaniel P. Wilkerson, P.E.
Medeek
Version 1.4.0 - 05.01.2020
- Enabled a second layer of gypsum for interior and exterior walls.
This update adds an optional 2nd layer of gypsum to the wall assembly.  By disabling the first layer of gypsum one can create an air gap between the 2nd layer of gypsum and the framed wall.
This update also addresses a minor bug caused by the updates in Version 1.3.8.
This latest update will require the user to recreate their wall presets since three new parameters have been added to the wall attribute library.
View an example of double gypsum walls here:
https://3dwarehouse.sketchup.com/model/fca7d773-6c68-4b86-b51e-68492cef6ce4/Double-Gypsum-Walls
Medeek
Version 1.4.0b - 05.01.2020
- Fixed a critical bug with the tee intersection ladder blocking with walls with no openings.
- Added a "Rustic Shiplap" built-in material into the material library.
Medeek
The Wall plugin has been slowly maturing over the last few months, however I am quite sure there are still a few more bugs that I am hoping to uncover and resolve.
In an effort to flush out these last remaining bugs I will be offering a "Bug Discovery" incentive program.  If you find and report a bug and I then verify that it is indeed a bug in the code (not an unfinished feature/module or user error), you will then be entitled to an additional year added on to your current update expiration date of your license/serial number.
This program will also be extended to all other Medeek plugins.  The credit can only be applied to the plugin(s) in which they were found.
Hopefully this will encourage users to help find and report bugs and ultimately make all of the plugins that much more robust.
Please send all bug reports directly to me at nathan@medeek.com
Please do not include any SketchUp models large than 2 MB or large video files or MS Word documents.  Screen shots and output from the ruby console is always very helpful.
Medeek
Version 1.4.1 - 05.12.2020
- Enabled a tapered wrap for a free standing columns.
- Added a HardiPlank Colonial (Rough Sawn) built-in material into the material library.
Two new parameters:  Taper and Taper Offset
View model here:
https://3dwarehouse.sketchup.com/model/327d5d82-ce92-4349-8320-799eae8c9dd7/Tapered-Square-Column
Medeek
Version 1.4.1b - 05.13.2020
- Added a "Style2" hardware option (Lever & Lock) to the garage door module.
This additional hardware option added per customer request.
Medeek
Version 1.4.2 - 05.14.2020
- Added a layer for posts to the advanced layer options (Layer tab of the global settings).
- Added a layer for blocking to the advanced layer options (Layer tab of the global settings).
Medeek
First look at the blocking toolbar:
I will also be removing the Fixtures toolbar from the Wall plugin, this toolbar will become part of the upcoming Medeek Interior plugin.
The blocking tool will not only be available for use with the Wall plugin but also the Truss and upcoming Floor plugin as well as any generic wall or roof.
Medeek
Version 1.4.3 - 05.17.2020
- Added a blocking tool/module for inserting custom blocks into Medeek walls, roofs, floors or generic groups.
- Added the Blocking toolbar and icons.
- Removed the Fixtures toolbar and icons.
Note, that the blocking is automatically retained within the wall, roof or floor assembly after a regen or edit of the primary assembly.
After selecting the first point one can toggle the positioning of the blocking with the "Ctrl" key.  There are nine possible positions the block can be inserted at.
The blocking is placed on the framing layer unless the advanced layers are turned on, in which it is placed on a specific blocking layer.
I will be releasing a tutorial video shortly on this new tool.
Medeek
Version 1.4.3b - 05.17.2020
- Added the "Shift" hotkey to the blocking draw tool in order to toggle the block rotation between zero and ninety degrees.
Medeek
Medeek
Version 1.4.4 - 05.24.2020
- Added I-Joist blocks to the the blocking module: TJI, BCI, LPI, Red-I, PKI.
Medeek
Version 1.4.5 - 05.29.2020
- Fixed a number of minor issues with the ladder blocking option for tee intersections.
- Tee intersection blocking is now assigned to the blocking layer if the advanced layer option is turned on.
If you are using ladder blocking for your tee intersections then I consider this to be a critical update.
Medeek
Version 1.4.6 - 05.30.2020
- Enabled the "Wall Stretch" tool within the Medeek Wall Tools toolbar.
Note that this tool can be used to either shrink or stretch a wall panel.  Instructions for use below:
1.)  Select tool (click stretch wall icon)
2.)  Select the wall panel you want to modify.
3.)  Select either the start or end of the wall panel (red or green circle).
4.)  Position cursor to either shrink or stretch wall panel.
Also note that this tool will not adjust adjacent wall panels even if they are connected at the corners to the wall panel being modified.  This is by design.  I will release a tutorial shortly explaining the reasoning behind this behavior.
Medeek
Medeek
Medeek
Tutorial 13 - Stretch Wall Tool (7:41 min.)
https://youtu.be/-kDBzZcgSu4
The audio is a little strange in this video, not sure why, I will check the audio out in more detail for future videos.
Medeek
Version 1.4.7 - 06.02.2020
- Enabled the "Wall Join" tool within the Medeek Wall Tools toolbar.
Note, that to join two walls they must be colinear and their START and END points must be coincidental.
Medeek
Medeek
Version 1.4.8 - 06.05.2020
- Added Quoins as an option for exterior walls.
*** Warning ***
This update is backward compatible with walls drawn in previous versions of the plugin however if you download this version you will be required to recreate any wall presets that you have previously defined.
View model here:
https://3dwarehouse.sketchup.com/model/9e6cdd22-ef17-48f5-a349-8d7e5d25b864/QUOINS-Medeek-Wall
Medeek
Looks like the algorithm is working correctly even with non-orthogonal walls:
View model here:
https://3dwarehouse.sketchup.com/model/db66bf55-412b-4c1f-8daf-dbad6f4a9855/Quoins-Octagon
Medeek
Tutorial 15 - Quoins (8:34 min.)
https://youtu.be/AxN-NY8IIak
View model here:
https://3dwarehouse.sketchup.com/model/1243b906-bfb3-4db1-8df4-7f636475a702/Brick-with-Quoins
The feature is probably not as commonly used in most residential construction however it was an easy add and it has been requested enough times to warrant its inclusion.
Medeek
Version 1.4.9 - 06.11.2020
- Converted the "Draw Garage Door" menu to HTML.
At first glance this may seem like a minor update, but in fact it is was quite a major undertaking.  I rewrote a good portion of the Garage module so that both the Draw and Edit menus are fully HTML.  I also tracked down some long standing bugs with regards to the jamb depth calculation (garage door installation).
This is part of the larger project to migrate all of the draw menus to HTML.  I figured I would start with the garage door module since it is used less than the window and door modules and somewhat less critical.  I've tested the update extensively (both metric and imperial) and it all appears to shake out.  If things look good after a few more days I will proceed to update the other two modules.
The HTML draw menu is a significant improvement over the previous legacy menu system.
Medeek
Version 1.5.0 - 06.15.2020
- Converted the "Draw Window" menu to HTML.
I think everyone will find that the HTML menu is a much needed improvement over the previous system.
Medeek
Version 1.5.1 - 06.18.2020
- Converted the "Draw Door" menu to HTML.
- Fixed a bug with arched door sidelites.
Not a glamorous update, but certainly a critical one.  The three most important draw menus are now switched to full HTML.
