Truss Calculators
0 Members and 35 Guests are viewing this topic.
Medeek
Version 2.7.0 - 04.12.2020
- Enabled the "Edit Truss Assembly" function for all timber trusses (imperial and metric units).
Nathaniel P. Wilkerson, P.E.
Medeek
Version 2.7.1 - 04.13.2020
- Enabled the "Edit Roof Assembly" function for shed w/ ledger rafter roofs (imperial and metric units).
- Enabled soffit and fascia for shed w/ ledger rafter roofs: boxed, gable, angled.
- Enabled a roof cladding extension parameter for shed w/ ledger rafter roofs.
- Added the option in the shed w/ ledger rafter roof edit menu to specify a separate front and back overhang length.
- Enabled a "No Framing" mode for shed w/ ledger rafter roofs.
Medeek
Velux has their official models in the warehouse but as usual there are too many details in these models, so I had to create my own low poly versions that are dimensionally accurate:
https://3dwarehouse.sketchup.com/model/f56a0a28-e161-46ce-a051-ea081c9e2a74/Medeek-Skylights-Velux-Low-Poly
Medeek
First look at the Skylights Toolbar:
Medeek
Version 2.7.2 - 04.24.2020
- Added wall sheathing thickness and wall cladding thickness parameters to the advanced options for trusses.
- Enabled advanced options for tail bearing trusses.
I still need to enable editing and labels for tail bearing trusses.
Medeek
Version 2.7.2b - 04.24.2020
- Enabled the "Edit Truss Assembly" function for all tail bearing trusses (imperial and metric units).
- Labels and callouts added to tail bearing trusses.
This update also resolves a potential bug that could cause the plugin to go into a infinite loop if the birdsmouth cut exceeds the depth of the top chord of the truss.  If you are using tail bearing trusses I highly recommend upgrading to this latest release.
The updated module is now properly creating the gypsum on the underside of the truss (three pieces).
Medeek
Version 2.7.3 - 04.26.2020
- Added a Global Reset button in the General tab of the Global Settings.
Medeek
Version 2.7.4 - 05.02.2020
- Fixed a bug with the soffit and fascia module for all truss types.
This bug fix is specifically for the boxed soffit for truss roofs.  Previously if one did not enable the fascia but enabled the soffit then it would throw an error.  There may be other similar bugs in this module or others so I am constantly testing combinations of various parameters to make sure no interdependencies have been overlooked.
Medeek
Version 2.7.5 - 05.05.2020
- Enabled a toggle feature (Ctrl key) for the Trim tool so that the selection can be retained or removed.
This small adjustment of the Trim tool is to bring it inline with the Trim 2 tool. This feature is per customer request.
Medeek
First look at the skylight tool in action:
Note, that this image shows the skylights added to a generic roof.  For the cutouts to work the roof geometry must be a valid solid group or component within an overall assembly group for the roof or building.
Initially there are three skylights (sizes) to choose from however it is possible to add your own skylights into the library.
The cut function can be toggled on/off in order to cut through the sheathing and cladding or in this case just a generic roof solid.
At some point I would also like to add in a few VELUX Sun Tunnels.
Now I just need to figure out how to heal the roof when a skylight is deleted or edited.  For a Medeek roof that is fairly straight forward, just regen the roof, however for a generic solid things get a little more tricky.
Medeek
Version 2.7.6 - 05.11.2020
- Added the Skylights toolbar.
- Enabled skylights for all truss, rafter and complex roofs.
- Enabled skylights for generic roofs.
I also added an additional tool for "regenerating" the skylights, this comes in handy after modifying the location of a skylight or if a Medeek roof gets regenerated and the holes in the sheathing and cladding need to be re-cut.
There are few new global settings I still need to add to fully complete this new module but overall it seems to be working quite nicely.
Medeek
Tutorial 18: Skylights (14.22 min.)
https://youtu.be/ogWO8nQRaxU
I often get a lot of questions that are answered in the tutorial videos.  Just a reminder, all of the tutorial videos can be found here:
http://design.medeek.com/resources/medeektrussplugin.html#Videos
Medeek
Version 2.7.7 - 07.31.2020
- Fixed a bug with all assemblies when auto-assignment of materials is turned off in the global settings.
Medeek
#988
I've been giving some serious thought to the estimating module the last couple of days as I regroup and review my various todo lists.
I would like to spend a few days and update the estimating module to include rafter roofs.  However, as I think about rafters and their lengths I am wondering what length exactly are we talking about?  Do we want the actual (longest length of the member) or do we want a horizontal projection of the length?  Typically both the top and bottom of a rafter has a bevel cut or even a compound bevel cut.
The ridge board on the other hand is very simple (generally).  There are no beveled end cuts so things are straight forward.
Medeek
In a nutshell this is the basic algorithm for the rafter module for complex roofs:
Of course the devil is the details and there are a lot of details missing in this picture.
The overall picture seems simple enough however there are a number of special cases where rafters align with ridge boards and the over simplistic boolean subtraction algorithm will not suffice.  I will need to try and account for all of those special cases.
The offset is a factor of the ridgeboard, hip rafter, valley rafter or flying hip rafter width.  However, as you can see in the detail below when the roof planes are not the same (asymmetric) the offset will not be symmetric and must be calculated, hence the opposing roof plane (pitch) at that edge must be known/tracked.  For a ridge board edge the offset will be given by:
offset  = T/(1 + tanθ/tanA)
Since the offset is only a function of the ratio of the two opposing pitches this equation should also hold for hips and valleys as well.  Note that when the angles are equal the equation degenerates to T/2 as one would expect.
Once all of the offsets are determined then it is merely a matter of generating the new points for the polygon drawn in blue highlighter.  Once that polygon (points) is determined it becomes the cutting polygon for the rafters.  Technically it is a boolean intersection rather than a subtraction, but that is all semantics.
Medeek
Version 2.7.8 - 10.09.2020
- Added a "Refresh Licensee Data" button within the License tab of the Global Settings.
Medeek
Version 2.7.9 - 10.23.2020
- Fixed a "rounding error" bug for pyramid shaped hip rafter roofs.
Medeek
Tutorial 19: Polygon Floor Workaround (21.46 min.)
https://youtu.be/G9Hrq1PzIUE
Manual workaround until the upcoming Medeek Floor plugin is released.
Medeek
Version 2.8.0 - 02.10.2020
- Minor modification to the range of available pitches for valley truss sets.
Medeek
Version 2.8.1 - 03.13.2021
- Standardized the naming convention of the plugin toolbars.
All of the Truss plugin toolbars will be prefixed with "Medeek", this will make it easier to find and sort through them, especially if you have a large number of extensions installed.
Medeek
Version 2.8.2 - 03.24.2021
- Added additional pitches to the shed and shed w/ ledger draw menus.
Medeek
Version 2.8.3 - 06.04.2021
- Added four additional parameters to the "User Interface" section of the General tab of the global settings. This allows the customization (colors) of the HTML menus and buttons.
This completes the user interface upgrade for all the major Medeek plugins.  The Truss, Foundation and Electrical plugins are now up to par with the Wall plugin.  Now on to bigger and better things, that task was very tedious but necessary.
Medeek
Version 2.8.4 - 06.13.2021
- Added a "Regen" context menu item for all truss assemblies (eg. Common Trusses, Scissor Trusses, Timber Trusses etc...)
- Added an option for subtractive geometry into the General tab of the Global Settings.
- Sub-groups within truss assemblies can be made persistent and "subtractive" by naming these groups to (subtract1, subtract2, subtract3, etc...)
- Components within truss assemblies can also be made persistent and "subtractive" by naming the component instance to (subtract1, subtract2, subtract3, etc...)
Once I've tested this a bit a further and received more feedback I will enable the same subtractive option/feature for rafter roofs and complex roofs.
Medeek
Version 2.8.4b - 06.13.2021
- Subtractive geometry can be constrained to only subtract from Sheathing and Cladding by setting the subtractive geometry parameter to "SHEATHING" in the global settings.
... and this is why feedback is important.
Medeek
#999
Version 2.8.5 - 06.14.2021
- Added stats (roof cladding) for common and monopitch truss roofs which can be analyzed within the Medeek Estimator (Wall Extension) module.
- Enabled net area calculations for roof sheathing and roof cladding statistics.
If cladding and/or sheathing is removed by subtractive geometry or features such as skylights, this information/data will be recorded and accounted for within the assembly.  When the Medeek Estimator runs it will pick up the net and gross areas for cladding and sheathing and report the correct amounts.  Previously only the gross areas were reported by the estimator.
