Truss Calculators
0 Members and 11 Guests are viewing this topic.
Medeek
Tutorial 28: Drawing Complex Gable Roofs (4:16 min.)
Nathaniel P. Wilkerson, P.E.
Medeek
Version 3.3.5 - 10.06.2023
- Sheathing Vertical Offset parameters added for common and monopitch trusses.
- Cladding Vertical Offset parameters added for common and monopitch trusses.
By customer request.
This feature is already implemented within the Wall plugin so it is about time that I bring the Truss plugin up to speed as well.  I think these four parameters are self explanatory enough that I don't need a tutorial video but if I do please let me know.
Medeek
Tutorial 29: Vertical Offset of Sheathing and Cladding (13:26 min.)
Medeek
I still need to come up with a good porch module for wrap around porches and the like, but in the meantime with some careful use of the SUBTRACT function one can get pretty close:
The model can be viewed here:
https://3dwarehouse.sketchup.com/model/64c6616c-bbfb-4323-98da-e6c60fa3a522/Wrap-Around-Porch
Medeek
Version 3.3.6 - 10.20.2023
- Sheathing Vertical Offset parameters added for attic trusses.
- Cladding Vertical Offset parameters added attic trusses.
- Wall Cladding Gap parameter added for common, monopitch and attic trusses.
The wall cladding gap parameter was added to bring the Truss plugin inline more with the Wall plugin.
Medeek
Version 3.3.7 - 10.29.2023
- Enabled the "Edit Truss Assembly" function for symmetric cathedral trusses (imperial and metric units).
- Added ceiling gypsum for symmetric cathedral trusses.
- Fixed a minor bug with parellel chord trusses.
Medeek
Version 3.3.9 - 12.30.2023
- Updated and improved the license verification module.
- Disabled redundant logging to improve plugin performance.
Medeek
Version 3.4.0 - 01.11.2024
- Added a "Primitive" option to the roof framing parameter within the Draw and Edit menus for the following rafter roofs: Gable, Shed, Shed (with ledger), Hip.
- Added lower pitches to the draw menus for the following rafter roofs: Gable, Shed, Shed (with ledger), Hip.
Medeek
Version 3.4.1 - 04.18.2024
Medeek
Version 3.4.2 - 04.23.2024
- Fixed a compatibility bug with SketchUp 2024 (Fixnum & Bignum) while maintaining backward compatibility with previous versions of SketchUp.
Medeek
Version 3.4.3 - 04.30.2024
- Added ceiling gypsum for tray and coffer trusses.
- Enabled the "Edit Truss Assembly" function for tray and coffer trusses (imperial and metric units).
- Enabled labels for tray and coffer trusses.
- Updated the license verification system with a more secure and improved algorithm.
Medeek
Version 3.4.4 - 05.02.2024
- Added ceiling gypsum for cambered and mono cathedral trusses.
- Enabled the "Edit Truss Assembly" function for cambered and mono cathedral trusses (imperial and metric units).
- Enabled labels for cambered and mono cathedral trusses.
- Fixed some minor bugs for mono cathedral trusses.
Medeek
Version 3.4.5 - 05.10.2024
- Enabled ceiling insulation for shed rafter roofs: Batt, Blown-in.
- Enabled ceiling insulation for gable rafter roofs: Batt, Blown-in.
- Enabled ceiling insulation for hip rafter roofs: Batt, Blown-in.
- Enabled the "Edit Truss Assembly" function for all flat trusses (imperial and metric units).
Medeek
Version 3.4.6 - 05.16.2024
- Enabled sheathing, cladding, ridge cap and labels for dual pitch trusses.
- Updated the polynesian truss so layers and materials are properly assigned.
- Enabled the "Edit Truss Assembly" function for dual pitch trusses (imperial and metric units).
- Enabled the "Edit Truss Assembly" function for polynesian trusses (imperial and metric units).
- Enabled the "Edit Truss Assembly" function for bowstring trusses (imperial and metric units).
- Enabled the "Edit Truss Assembly" function for bow barrel trusses (imperial and metric units).
The edit and regen functions have now been enabled for all active truss types within the plugin.  However I still have four truss types that need to be setup and activated.
