Truss Calculators
Medeek
Nathaniel P. Wilkerson, P.E.
Medeek
#1026
Version 2.9.9 - 07.25.2021
- Enabled the rafter framing module for complex roofs.
I am releasing this update so that users can begin testing out the rafter framing module, however be warned that it is still missing many features and is technically in a BETA state right now as I sort out some of the details and finer points.
Please send bug details or other concerns directly to my email address, [email protected].
Medeek
Most of my time is actually spent debugging or looking for ways to break the plugins (instabilities etc...)
I found one small minor issue this morning when I generated this roof (I will issue the fix later today or tomorrow):
The module is surprisingly robust even with more intensive roofs however the draw and edit time required for this geometry is noticeable on my ten year old PC.  My youngest son keeps telling me to update to a newer machine with a better graphics card but I figure the older machine actually helps me keep my code lean and efficient.
View model here:
https://3dwarehouse.sketchup.com/model/a245116e-88cd-4b5f-9536-cc060a43ce63/Complex-Rafters-3
Medeek
Version 3.0.0 - 08.03.2021
- Fixed a minor bug with the rafter framing module for complex roofs.
- Adjusted the tool tips within the HTML edit menu for common trusses.
Medeek
Version 3.0.1 - 08.08.2021
- Fixed a bug with the edit menu for common trusses and custom materials.
Medeek
Version 3.0.2 - 08.23.2021
- Fixed a bug with ceiling joists for shed rafter roofs.
- Fixed a bug with rafter roofs with glulam beams that have soffit and fascia enabled.
- Updated the wireframe preview of the draw tool for select rafter and truss roof types.
Medeek
Just a reminder that all of the Truss plugin tutorial videos are listed here:
http://design.medeek.com/resources/medeektrussplugin.html#Videos
Medeek
Version 3.0.3 - 10.02.2021
- Added custom materials to the roof and wall cladding parameters of the Sheathing tab within the Global Settings.
Medeek
Version 3.0.4 - 10.23.2021
- Added error checking code into various HTML menus for roof and wall materials.
Medeek
Version 3.0.5 - 11.03.2021
- Added additional energy/raised heels for double fink truss (2 variants: wedge and slider).
Apparently when I added in the raised heel algorithms for this truss type a couple years ago I only added in the vert with strut option.  It was brought to my attention a couple days ago that the other two options were missing.  I apologize for the delay in making sure all three options were available for this truss type.  We should be good to go now with the double fink truss.
Medeek
Version 3.0.6 - 11.30.2021
- Added ceiling gypsum to shed and shed w/ ledger rafter roofs.
- Enabled ceiling gypsum for all shed rafter roofs with ceiling joists enabled.
Medeek
Version 3.0.7 - 01.25.2022
- Added energy/raised heels for 4/2 scissor trusses (1 variant: vertical w/ strut).
Medeek
Version 3.0.8 - 01.29.2022
- Added ceiling gypsum and ceiling battens to all floor assemblies.
I am still working on the new floor plugin however in the meantime it was not difficult to add the gypsum option to the existing floor truss/joist module.
This feature added per customer request.
Medeek
Version 3.0.9 - 02.09.2022
- Enabled soffit and fascia for hip truss sets.
- Fixed a minor bug with the hip truss set module.
- Removed the Gutter Extension parameter from the hip truss set edit menu.
Medeek
Version 3.1.0 - 02.10.2022
- Enabled customizable colors for system materials for complex roofs: Outline and Geometry.
Medeek
Version 3.1.1 - 02.13.2022
- Enabled advanced options for mono scissor trusses.
- Enabled the "Edit Truss Assembly" function for all mono scissor trusses (imperial and metric units).
Also note that one can adjust the bottom chord pitch to be the same as the top chord pitch and with a raised heel (ie. 24") you can effectively create shed roof parallel chord trusses:
Medeek
Version 3.1.2 - 02.15.2022
- Enabled MPC wood blocking panels for common trusses.
If your heel height exceeds 15" and you have selected "Vertical" heel blocking as your orientation, then rather than solid blocks the plugin will now insert MPC blocking panels instead.
I still need to enable heel blocking and blocking panels for various other truss types and also make this available for rafter roofs as well.
Medeek
Version 3.1.3 - 04.10.2022
- Enabled 3D roof and wall cladding materials for monopitch trusses.
- Fixed a bug with the valley set detection option.
Medeek
Version 3.1.4 - 04.27.2022
- Fixed a minor bug with the advanced options for scissor trusses.
- Updated the scissor truss module so that raised heel trusses are properly rendered/drawn.
Medeek
Version 3.1.5 - 05.07.2022
- Enabled 3D roof and wall cladding materials for attic trusses.
Medeek
Version 3.1.6 - 06.05.2022
- Enabled ceiling insulation for common trusses: Batt, Blown-in.
- Enabled ceiling insulation for monopitch trusses: Batt, Blown-in.
- Added an insulation layer in the global settings.
I still have a lot of work with regards to insulation and numerous other truss types and rafter roofs.
Medeek
Version 3.1.8 - 08.29.2022
- Added a parameter into the general tab of the global settings to allow for adjustment of the size of labels and annotations.
- Added a parameter into the general tab of the global settings to allow for adjustment of the font for text found within annotations and labels.
- Added a "resolution" parameter into the general tab of the global settings for adjusting the smoothness of annotation text.
- Added a "Label Rotation" parameter (0 or 180 degrees).
- Enabled various annotation options/parameters for truss roofs.
Basically just bringing some of the annotation formatting options over from the Wall Plugin.  I will still need to enable these options for rafter roofs, hip sets and complex roofs.  This update per user request.
Medeek
Version 3.1.9 - 11.25.2022
- Enabled subtractive geometry for all shed rafter roofs.
Medeek
Version 3.2.0 - 11.28.2022
- Fixed a minor bug with the roof cladding thickness parameter when the materials option is toggled off.
Strange that I never noticed this bug before but I guess most of us turn on the materials option so that is probably why no one ever really noticed.  I highly recommend turning on the materials options to get the full bang for your buck out of the plugin but in the rare chance you don't want to this bug fix will take care of the previous issue reported above.
Medeek
Version 2.0.7 - 11.01.2022
- Added four additional top chord point loads under advanced loads for solar panel installations and other applications.
