Author Topic: OKLAHOMA 20X30 SINGLE STORY  (Read 294782 times)
Offline dug
  • Senior Member
  • SW New Mexico
Re: OKLAHOMA 20X30 SINGLE STORY
« Reply #225 on: April 04, 2011, 02:37:13 PM »
In the house I used to live in I installed two cisterns at opposite corners to collect rain water. I used 4 ft. diameter steel culvert (purchased from a highway supply store) that we sunk about 6 inches deep into a concrete pad. I put the water outlet and overflow pipes under and up through the middle of the footing before we poured.
Easy and relatively cheap.
Offline archimedes
  • Senior Member
« Reply #226 on: April 04, 2011, 03:09:37 PM »
They ran an electrical wire 1/4 mile for free!  Wow,  that's a great deal.
Offline astidham
  • Senior Member
  • Skiatook Oklahoma
« Reply #227 on: April 05, 2011, 03:12:56 PM »
Thanks dug..
here are some power pole pics.
— Henry Ford
Offline astidham
  • Senior Member
  • Skiatook Oklahoma
« Reply #228 on: April 06, 2011, 07:58:00 PM »
After tweaking the plans a little bit, this is how we are going to lay out the cabin, not seen is the upstairs loft bedroom.
— Henry Ford
Offline dug
  • Senior Member
  • SW New Mexico
« Reply #229 on: April 07, 2011, 09:37:44 AM »
Looks like a nice open layout but I am not understanding the stairs. Only 8 risers and it looks like it will be landing where there is no head room.  ???
Am I missing something?
Offline astidham
  • Senior Member
  • Skiatook Oklahoma
« Reply #230 on: April 07, 2011, 09:48:21 AM »
The stairs in the layout was the only one to choose from that looked like a ladder style stair.
the stairs will be a wider version of a library ladder with hand rails, it will be less steep, with more stair treads than the picture shows.
I'm not to sure how far from the south wall we will place the stairs, but my layout shows about 3' as a reference.
Thanks for the observation dug, I didn't take headroom into consideration.   back to the drawing board :D
— Henry Ford
Offline astidham
  • Senior Member
  • Skiatook Oklahoma
« Reply #231 on: April 07, 2011, 03:46:29 PM »
here is an updated version with a closet....
— Henry Ford
Offline Sassy
  • Calif Gold Country
« Reply #232 on: April 08, 2011, 08:47:26 AM »
Looks nice, but I'd put the toilet where the sink is & sink where you have the toilet...  unless  ::)  as Glenn said, you want to sit there & watch people while they're eating  c*
Offline astidham
  • Senior Member
  • Skiatook Oklahoma
« Reply #233 on: April 11, 2011, 11:19:19 AM »
have been working on the soffits, trying to get ready for siding.
« Last Edit: April 11, 2011, 07:59:28 PM by astidham »
— Henry Ford
Offline astidham
  • Senior Member
  • Skiatook Oklahoma
« Reply #234 on: April 14, 2011, 03:29:27 PM »
I finished the soffit today, the weather held up long enough to get all the plywood up. the plywood will be a nailer for cedar.
I think i might buy cedar pickets to cover it with, since they don't cost so much.
— Henry Ford
Offline mogie01
  • Senior Member
    • Our 20x34 1-1/2 story cabin in Michigan
« Reply #235 on: April 14, 2011, 03:47:00 PM »
Soffits look great!!
Offline duncanshannon
  • Senior Member
    • About Duncan
« Reply #236 on: April 14, 2011, 03:55:36 PM »
 [cool]
Offline nathan.principe
  • Full Member
« Reply #237 on: April 15, 2011, 06:45:43 AM »
coming right along! I bet your getting excited to start on the inside!
Offline astidham
  • Senior Member
  • Skiatook Oklahoma
« Reply #238 on: April 16, 2011, 03:59:56 PM »
today I removed a 30-50 window and replaced it with a 30-30 window bumped out 1'.
this window will be over the sink. My wife wanted a garden window so bumping out will leave a approximately 18"shelf for her plants.
the window should be installed tomorrow
« Last Edit: April 16, 2011, 04:39:19 PM by astidham »
— Henry Ford
  • Senior Member
    • About Duncan
« Reply #239 on: April 16, 2011, 04:04:29 PM »
 [cool]
Offline astidham
  • Senior Member
  • Skiatook Oklahoma
« Reply #240 on: April 17, 2011, 04:36:32 PM »
window is now installed!!
— Henry Ford
Offline mogie01
  • Senior Member
« Reply #241 on: April 18, 2011, 07:54:08 AM »
Great job on the window, your wife will love it! [cool]
Offline astidham
  • Senior Member
  • Skiatook Oklahoma
« Reply #242 on: April 19, 2011, 10:03:05 AM »
Just about ready for siding
— Henry Ford
Offline Mrdecatur217
  • Junior Member
« Reply #243 on: April 19, 2011, 01:43:50 PM »
i noticed you used glass for your windows., and wood for your walls is that normal? it looks very nice son,. it is easier to change now then when the inside wall is finished., so have fun. Dad
Offline dug
  • Senior Member
  • SW New Mexico
« Reply #244 on: April 19, 2011, 03:50:18 PM »
Beginning to look like a home. Nice job!
Offline beckhamk
  • Full Member
« Reply #245 on: April 21, 2011, 03:22:22 PM »
What was the cost of your trusses?  Very nice and coming along nicely.
Offline astidham
  • Senior Member
  • Skiatook Oklahoma
« Reply #246 on: April 21, 2011, 03:48:45 PM »
the trusses cost around 1200.00 if i remember right, for the scissor trusses and the drop cable trusses
— Henry Ford
Offline beckhamk
  • Full Member
« Reply #247 on: April 23, 2011, 01:06:27 PM »
astidham  - thanks for the info. just wanted to compare to the prices i was seeing.  Mine are inline.
BTW: I assume a 12/12 pitch on the outside and that the inside is 8/12?
Also are you planning to run any ties accross your open area at all to tie the walls together?
Offline astidham
  • Senior Member
  • Skiatook Oklahoma
« Reply #248 on: April 23, 2011, 02:53:55 PM »
it is a 12/12 pitch.
how i understand it, If your trusses are engineered, collar ties are not necessary with a 10' or under side wall.
my side walls are 10' with the trusses i have our loft has a ceiling height at the peak ~9'
— Henry Ford
Offline beckhamk
  • Full Member
« Reply #249 on: April 23, 2011, 03:05:36 PM »
Thanks for the info! Your truss mfg didnt say that the inside would be a 8/12?  just curious as i just contacted one place and they told me they can do a scissor truss 12/12 for hte outside but the inside would be 8/12.  I figure your inside is around the same.
Files included: 37 - 1132KB. (show)
Cache hits: 11: 0.00121s for 40,774 bytes (show)
Queries used: 30.
