Wall Plugin for SketchUp
0 Members and 11 Guests are viewing this topic.
Medeek
I suppose one could gang together as many window units as one would like, but two or three is probably the practical limit from a structural standpoint.
Here is a three-gang of windows with one header, utilizing the recent advanced framing options:
Nathaniel P. Wilkerson, P.E.
Medeek
Version 4.0.0b - 05.28.2025
- Enabled "green" pressure treated lumber within the stair module.
Medeek
Version 4.0.1 - 05.29.2025
- Added five additional layers to the Layers tab of the Global Settings for stair assemblies.
- Added a "Stair Layers" option into the Layers tab of the Global Settings in order to toggle the stair layers "On" or "Off".
Tutorial 71 - Layers/Tags for Stairs (4:02 min.)
Medeek
Version 4.0.2 - 06.01.2025
- Added a bottom gap parameter to the draw and edit menu of the door module.
- Added the bottom gap parameter to the door tab of the global settings.
Medeek
Version 4.0.3 - 07.03.2025
- Fixed a long standing bug (06/27/2023) with the edit dimension tool for framing dimensions (rectangular walls).
Medeek
Version 4.0.4 - 07.13.2025
- Added the following steel post types to the post module: Round (HSS), Pipe (NPS).
I'm not sure why I never added a "pipe" option in before, I guess no one ever asked until now.
I will need to add more sizes but I now have the most commonly used sizes from 3" to 6" DIA.
Medeek
Version 4.0.4b - 07.14.2025
- Added springfield plates to the post base and post cap libraries (for 3.5" and 4.0" pipe).
- Added the following Simpson post caps to the post module: LLC35_35, LCC35_4, LCC45_35, LCC45_4, LCC525_35, LCC525_4, LCC6_35, LCC6_4, LCC7_35, LCC7_4.
If I'm going to add in this new "pipe" post then it stands to reason that I also add some appropriate bases and caps to match.
Medeek
Version 4.0.4c - 07.15.2025
- Added the following Simpson Strong-Tie holdowns to the wall, column and shearwall modules: HDUE3, HDUE5, HDUE7, HDUE9, HDUE13, HDUE17.
Looks like Simpson added this new replacement for the HDU holdown in May of this year.  I just noticed this morning so I added them in.
Note that these are low poly versions of the holdowns based directly off of the geometry provided on Simpson's website.
Medeek
Version 4.0.5 - 07.16.2025
- Fixed a bug with quadruple end wall studs (applies to all wall types).
- Added the following Simpson Strong-Tie pre-assembled anchor bolts to the wall, column and shearwall modules: PAB6-12, PAB6-18, PAB6-24, PAB6-30, PAB6-36, PAB7-12, PAB7-18, PAB7-24, PAB7-30, PAB7-36, PAB8-12, PAB8-18, PAB8-24, PAB8-30, PAB8-36, PAB10-12, PAB10-18, PAB10-24, PAB10-30, PAB10-36.
- Added the HTTH6.5 holdown to the built-in holdown library.
Note, that these anchor bolts come in five different lengths (12, 18, 24, 30 and 36).  I did not add in the 1/2 and 5/8 dia. anchor bolts since this option is primarily chosen when a much larger anchor bolt is needed, but do let me know if you would like to see them added in.
Just playing catch up on a number of items after spending three or so weeks on the HVAC plugin.  Undoubtedly, I am spread a bit thin these days with six plugins now under active development.
Medeek
Version 4.0.6 - 07.17.2025
- Fixed a bug with gable walls.
- Added the following Simpson Strong-Tie pre-assembled anchor bolts to the wall, column and shearwall modules: PAB4-12, PAB4-18, PAB4-24, PAB4-30, PAB4-36, PAB5-12, PAB5-18, PAB5-24, PAB5-30, PAB5-36, PAB9-12, PAB9-18, PAB9-24, PAB9-30, PAB9-36.
Medeek
Version 4.0.7 - 07.20.2025
- Enabled the polyline draw mode for all wall justification options: Front, Center, Back, Sheathing.
Tutorial 72 - Wall Justification (7:16 min.)
Medeek
mdkBIM Tutorial 6 - Building a Ham Shack
My initial concept of the ultimate Ham Shack (16' x 12') designed in SketchUp using the Medeek extensions.
The model can be found here:
https://3dwarehouse.sketchup.com/embed/41926b8b-553f-4a06-a665-e16742919406?token=rwdGfAJloEo=&binaryName=s21
My call sign is KK7UXO, but I don't get on the radio much, mostly I'm programming. :slight_smile:
Medeek
Per customer request I will add in an LSL option for the framing very shortly:
I'm using the updated LSL texture I created for the Floor plugin, but I still feel like it is a bit dull or dark compared to my previous texture (OSB).  It could be a bit more vibrant or saturated.  I will need to spend some more time on this.
Weyerhaeuser sells their Timberstrand line of LSL framing and studs:
https://www.weyerhaeuser.com/woodproducts/engineered-lumber/timberstrand-lsl/timberstrand-lsl-framing-lumber/timberstrand-lsl-wall-framing-studs/
However, I would always worry about water damage.  What happens if the LSL gets wet?  We all know what happens to OSB, and plywood is a much more robust product in comparison.  Standard lumber seems like a much more resilient choice when it comes to potential water damage, but I could be wrong.
Medeek
Some Youtube viewers of this video reached out and told me that they had more equipment than could reasonably fit within such a small structure.  I agree, maybe a 16'x12' space is a bit cramped for anyone, especially if you are also using it for a content creation studio.  This is where the parametrics of the extensions come in real handy:
The model(s) can be viewed and downloaded here:
https://3dwarehouse.sketchup.com/embed/aa7589c0-5dde-498d-ba91-ba73e1a68791?token=YhzP4g4wwgE=&binaryName=s21
Medeek
Version 4.0.8 - 07.25.2025
- Enabled LSL as a wall framing material.
- Updated the material textures for LSL and PSL.
These don't seem like major updates however there are numerous places within the plugin that required updating and also during the process I was able to further refine and compress the code so it is now more efficient and better organized.  Updates were made to the following modules:  Walls, Stairs, Columns, Beams, Posts and Shearwalls.
Medeek
Version 4.1.0 - 07.28.2025
- Added the following Simpson "Sage" post caps and bases to the post module: SAGE_B66, SAGE_C66, SAGE_T66
- Fixed a critical bug for custom materials within the stair module.
- Updated all of the move tools with upgraded wireframe previews and dimensions.
- Updated the window, door and garage door draw tools with a filled wireframe preview.
Medeek
Version 4.1.1 - 08.17.2025
- Added Fixed - Slider (L) and Fixed - Slider (R) windows to the window module.
These two window types added per customer request.
Medeek
Version 4.1.2 - 08.18.2025
- Added hexagon windows to the window module.
Note, that to get a regular hexagon window you will want to enter in a window height that is given by this formula:
height  = width x 0.8660254
So for example if window is 48" wide its height will be: 48" x 0.8660254 = 41.569219"
One can always enter in any size for example an elongated hexagon or squished hexagon but I suspect most manufacturers will typically only stock a "regular" hexagon shaped windows in various sizes.
Medeek
Version 4.1.3 - 08.21.2025
- Added a "Label Scaling" parameter for all wall types.
Update per customer request.
Medeek
Version 4.1.4 - 11.26.2025
- Added "GPS" and "PU" foam insulation as an option for SIP wall panels.
- Enabled insulated (filled) custom headers for windows, doors and garage doors: XPS, ISO, EPS, GPS, PU.
- Insulated headers can be customized/created with the Global Settings similar to standard (OSB/PLY) headers.
- Added a QHQ Single Hung window to the window draw and edit menus.
All updates per customer requests.
Medeek
Tutorial 74- Insulated Headers (6:28 min.)
Medeek
Version 4.1.5 - 11.29.2025
- Enabled Green, Pink and Grey options for XPS headers and SIP wall panels.
- Added an option in the door draw and edit menus to change the door hardware material/color: None, Brass, Nickel, Bronze, Black, Copper, Gold.
- Updated the file/component loading method for door hardware and shearwall holdowns to increase plugin performance.
Medeek
Version 4.1.6 - 11.30.2025
- Updated the context menus for walls with an "Edit Opening..." option if the selected (right click) wall contains a door, window or garage door.
- Added "Arial Bold" as a font within the Annotation Formatting section of the General tab of the Global Settings.
- Fixed a bug with Single and Double Hung QHQ windows.
- Added a QHQ Double Hung window to the window draw and edit menus.
Medeek
Tutorial 75 - Updated Context Menu (5:22 min.)
Medeek
Version 4.1.7 - 12.05.2025
Enabled XPS (blue, green, pink and grey), ISO, EPS, GPS, and PU foam insulation within the wall sheathing options.
