14x20 in Damon Texas
Started by BRUTAL, August 31, 2011, 11:04:27 PM
BRUTAL
well I bought 5.3 acres last year after building an covered Pergola and outdoor kitchen at my house that my girlfriend helped with.
We sat around bored with nothing to do, but drinking Margaritas and decided to go look at land again. Long story short.....
Now Memorial day we started with internet plans, building a barn styled shed on concrete blocks. It (on paper) started out as a 12x16 and quickly progessed into a 16x25 2 story and a quick estimate of 12k in materials without well, septic, power. This was double my budget! And from storage building, to a live in cabin for a couple years till we build a house with Autoclaved aerated concrete. (a local experianced builder with this material lives right down the street, how cool is that) Anyway ive built most of this myself on weekends and it has again morphed from a (looking a my receipts) from a shed, to barn, to cabin to cottage. Im now planning on making it livable again. Im trying to workout ideas for bath, kitchen, plumbing, wiring, and spray foam insulation, etc.... So Ive found many of ya'll very imformative and articles helpfull. Wishing Ide had decided to stay with a habitat first for things like floor plan and joist size. So know trying to figure out the best way to add on a bath to the the back and get plumbing, sewer, PEX etc in....Any way here are a few in progress pics.....and 5k in materials later:)
Bill
http://countryplans.com/smf/index.php?topic=11116.0
making mistakes along the way and wishing Ide been here sooner :)
BRUTAL
THANKS, right now Im working on a lighting system using LEDS and a couple batteries from work. Ill hook a solar panel up to keep the batts charged and run all the light(DC) off them. The company that was linked here though has NOTHING in stock. Anyone else have current info on DC lights and power......our area rep at work runs all the lights in his house off LEDS and a single battery with 2 small panels. 1 on each side of the roof to catch the sun throughout the day. His neighbors hate him when the power is out in north Dallas since theyre using flashlights and he's watching movies on the laptop and all the lights on  in the house:)
So far I have not met an LED light that I can use to read by comfortably.  And for general illumination most of them don't cut it for me as they tend to be too focused. We have found clear/white LED Christmas lights to be very useful for outdoor illumination between buildings on our off grid mountain property. They could also be used for low level general indoor illumination.
BRUTAL
I THOUGHT ABOUT THAT TOO DON. MY SOLUTION WAS TO TAKE EITHER OPAQUE DIFFUSER FOR LEDS SPOTS. OR MAKE MY OWN. BY TAKING A SHEET OF EITHER LEXAN OR PLEXIGLASS AND SANDING THE BACK SIDE. I THEN INSERTED THEM INTO A LIGHT CAN TO USE WITH SPOT LEDS. IT FOCUSES DIFFUSED BRIGHT LIGHT ONTO WHERE I WANT TO READ. IF USE A SWIVEL LIGHT FIXTURE I CAN MOVE IT WHERE I WANT. I COULD ALSO USED COMPACT BUT USES MORE POWER THAN THE LEDS I GOT OUT OF TAILLIGHTS AT WORK :)
w*
I like the gambrel roof. It looks like great work.  More pictures are always appreciated.  ;)
As far as DC lighting, I would look into CFL too.  A little while ago I compared the cost per lumens.  IIRC, the cost of a LED equivalent of a CFL costs over twice as much.  So if a 12v CFL puts out X amount of light the LED equivalent would cost double. The amount of energy saved between the two is negligible.  If a cfl uses 7 watts and an LED uses 3 you are saving a total of 4 watts per hour. That is tiny.  In many cases it would be cheaper to upgrade the capacity of the system over the cost difference lighting.  They just featured this on a show "this new house" on the DIY network last night.  Although on the show was AC lighting, the LED lights were 11 watts to put out as much light as a 75 watt incandescent, which is equivalent to a 13 watt CFL.  The cost difference though was $30 for an LED light or $1 for a CFL. $29 to save 2 watts.
I light my place with one of those harbor freight solar kits. It comes with 3 panels, 2- 5w lights, and a control box for $150 with a coupon.  In my book, it is a good deal for a shed.  It is just enough for a light use 12v system.
schiada
Love the roof! [cool] Looking to use it on my 1 1/2.
Are the stairs code?
BRUTAL
well I dont have to worry about code where Im at. But I want things correct, theyre 7 5/8" rise and 9 1/2" tread. I couldnt tell you about the winder. you do have negotiate the center of them when useing. but they put 3 steps in the place of 1. Since theyre just like a small piece of a spiral case I dont see how they wouldnt be to code ???
BRUTAL
Quote from: Squirl on September 01, 2011, 02:44:16 PM
w*
I was there last night and theyre out of stock till tues. but as useal I pick up other things I uh...needed, yeah I needed those items honey. after all Im a Master Jaguar tech honey and need them for work
FWIW, stairway winders according to the 2009 IRC
Later today I'll stick this in a reference topic along with other stair info. Make it easy to find.
BRUTAL
https://www.facebook.com/media/set/?set=a.10150237819597582.327348.751732581
HERES A LINK TO MY FACEBOOK ACCOUNT WITH NEW PICS FROM THIS WEEKEND. WORKED ON THE DRIVERWAY. PUT UP MORE HARDIPLANK AND GOT THE KIDS PAINTING......:)
BRUTAL
#12
well this weekend I finished the wiring I wanted upatairs and SPRAY FOAMED with Green Stuff spray foam. Worked very well.
A little messy, but it dries in 30 seconds and I just scraped off the foam when I finished. I covered the windows with clear plastic to let light
in while I sprayed.
I did 3-5" along the eaves and gables. the opeings I first blocked with 1/2" foam board cut to fit. Most of the rest I spraying 1" or so, and then will follow up later with fibreglass batting. By the time I finished it already was deafly quiet, and felt like inside a Igloo cooler.:)
dablack
That looks great!  Nice job.
How much material did you buy.  Where did you get it.  How much did it cost.  How do you like it.  HA!  Basically I want a review of the product.
We will be doing the same thing.  We are currently looking for land and will build a garage first, live there and then the house.
thanks
Austin
BRUTAL
#14
Ilike it alot, and I really wanted something to create a air tight space. the R value is R7 per1". From there Ill use regular insulation batts. This makes it very cost effective. But since I don't have a vented attic space since its basically the upstairs bedroom, I need something to seal well and cost effective. (DIY) instead of $3-5k for a contractor. It was very easy to use and the only problem I had was I wasnt watching the hoses closely and after turning a couple times spraying I kinked 1 and  if you look at the 1 pic with me in it spraying youll notice the differance in color. This is another thing I liked about this companies product is the included dye to easily see if mixing in the nozzle properly. I spent $1400 shipped for 2 kits which will do approx 1200sq ft. it includes the suits, goggles, gloves, booties, and like 10 extra nozzles and fan tips. the upstairs took 1 kit and was the most sq ft of spray needed. I still have the other kits for when I do and finish the 8x12 bathroom addition. Her's the website with Q and A plus videos.
http://www.sprayfoamdirect.com/
That is great.  How hard was it to keep the thickness to 1"?
BRUTAL
I worried more about even coverage. Then took a break and went back over areas if need be. It was pretty easy really. Its more about having everything ready and planned. It comes with about 10 nozzles, I used 2. If you stop spraying longer than 30 seconds, you need to pop off the nozzle and replace with another. The foam is 2 part and mixes in the nozzle. The foam hardens in 30 seconds. All in all, yes its more than fiberglass batting. But You can't beat the air tighteness and sealing. And just worked perfect for my needs. ANd like many others here, I wanted a trial run and test of differant things to see how it worked out before doing a larger scale(house)
Im going back this weekend to batt the remainder and then sheetrock. The eaves and gable ends i went over a few times to build the foam to 3.5" as those areas are hard to get anything into. Ill let you know how it feels this weekend since itll be in the 30's and we dont have Heat yet other than a tent heater. so it better be warm:)
Cool outdoor kitchen!  And your cabin is coming along nicely  :)
BRUTAL
Thanks Sassy, Ahh the mistakes we make on things we don't do for a living. I went and and started putting in the batts. and realized I forgot to install backer boards or nailers on the end walls. Now that I ve filled those areas with 3.5" foam thats gonna be tough. I was gonna sheet rock to save a few hundred dollars. but I dont know. originally I wanted to use tongue and groove 1/4"pine planks for a more rustic look. It wont crack if theres cabin movement since its on skids. But i may go back to that idea since its only a 5"span in the end walls to cover and no nailers in the corners.
We came back last night since I didnt finish the insulation and I have the beds covered. Plus I wanted a good hot shower to get any fiberglass off and not get it in the bedding in the cabin. That would make for some inchy nights long down the road:D)
dug
QuotePlus I wanted a good hot shower to get any fiberglass off and not get it in the bedding in the cabin. That would make for some inchy nights long down the road:D)
Something I learned from a friend about itchy fiberglass- COLD shower! Hot showers open the pores and allow the fibers in, cold water closes pores and lets you wash them off. Not so comfy, especially this time of year but it really works!
Looking good by the way!
BRUTAL
Nice Dug, could have used that advise last NIGHT d*. Actually we're fine, minimal ichyness.
The lady down at the local feed, convienience, gas station, pizza parlor, beer joint, and hardware store, told my girlfriend to use babypowder on any exposed skin. I guess it keeps it from sticking, cause once I started sweating.......
The biggest issue I had was I couldnt wear goggle and particle mask at the same time without fogging the google up. So last night on the way home I picked up a differant kind of mask that has a exhale valve in the front that should keep our breath from fogging up the goggles.
1 downside to the spray foam insulation I found out yesturday. I USED to be able to easily push the door closed and it closed and latched so easy. NOW, I have to push it closed all the way. Nice to see how airtight the foam made the cabin, I havent even done the down stairs yet.
duncanshannon
 w* BRUTAL!
nice looking place. I really like the gambrel roof and the spray foam info is interesting.'
good luck!
CjAl
i think i may try that spray foam. i think i would fill the wall with it though. you could build 2x4 wall and get same or better r value then fiberglass in a 2x6 to offset some of the cost.
BRUTAL
Quote from: CjAl on November 13, 2011, 06:10:12 PM
they have a slow rise foam and video on how to for closed wall cavities too. the R value per inch is more than twice that of Fiberglass. 2"of foam equals 3 1/2"
of the Batting I used. But the cose is more than triple too. This is why I did a mixed install per their recommendations on best value.  Yes if you take out cost Ide love to do the whole cavity and trim with a serated knife even with the studs. Unfortunatly I now realise how poorly insulated my house is in comparison to the cabin. :(
CjAl
#24
im living in a double wide. poorly insulated 1x3 walls really make for a eratic power bill. i will go from running the ac to running the heat in the same day at times.
i'm a strong believer in the best insulation you can get. it will pay off in the long run.
i looked briefly at the site. it seemed the slow rise had less r value for not much less money
