OKLAHOMA 20X30 SINGLE STORY
0 Members and 19 Guests are viewing this topic.
dug
In the house I used to live in I installed two cisterns at opposite corners to collect rain water. I used 4 ft. diameter steel culvert (purchased from a highway supply store) that we sunk about 6 inches deep into a concrete pad. I put the water outlet and overflow pipes under and up through the middle of the footing before we poured.
Easy and relatively cheap.
archimedes
They ran an electrical wire 1/4 mile for free!  Wow,  that's a great deal.
astidham
Thanks dug..
here are some power pole pics.
— Henry Ford
astidham
After tweaking the plans a little bit, this is how we are going to lay out the cabin, not seen is the upstairs loft bedroom.
— Henry Ford
dug
Looks like a nice open layout but I am not understanding the stairs. Only 8 risers and it looks like it will be landing where there is no head room.  ???
Am I missing something?
astidham
The stairs in the layout was the only one to choose from that looked like a ladder style stair.
the stairs will be a wider version of a library ladder with hand rails, it will be less steep, with more stair treads than the picture shows.
I'm not to sure how far from the south wall we will place the stairs, but my layout shows about 3' as a reference.
Thanks for the observation dug, I didn't take headroom into consideration.   back to the drawing board :D
— Henry Ford
astidham
here is an updated version with a closet....
— Henry Ford
Looks nice, but I'd put the toilet where the sink is & sink where you have the toilet...  unless  ::)  as Glenn said, you want to sit there & watch people while they're eating  c*
astidham
#233
have been working on the soffits, trying to get ready for siding.
— Henry Ford
astidham
I finished the soffit today, the weather held up long enough to get all the plywood up. the plywood will be a nailer for cedar.
I think i might buy cedar pickets to cover it with, since they don't cost so much.
— Henry Ford
mogie01
duncanshannon
nathan.principe
coming right along! I bet your getting excited to start on the inside!
astidham
#238
today I removed a 30-50 window and replaced it with a 30-30 window bumped out 1'.
this window will be over the sink. My wife wanted a garden window so bumping out will leave a approximately 18"shelf for her plants.
the window should be installed tomorrow
— Henry Ford
duncanshannon
astidham
— Henry Ford
mogie01
Great job on the window, your wife will love it! [cool]
astidham
— Henry Ford
Mrdecatur217
i noticed you used glass for your windows., and wood for your walls is that normal? it looks very nice son,. it is easier to change now then when the inside wall is finished., so have fun. Dad
dug
Beginning to look like a home. Nice job!
beckhamk
What was the cost of your trusses?  Very nice and coming along nicely.
astidham
the trusses cost around 1200.00 if i remember right, for the scissor trusses and the drop cable trusses
— Henry Ford
beckhamk
astidham  - thanks for the info. just wanted to compare to the prices i was seeing.  Mine are inline.
BTW: I assume a 12/12 pitch on the outside and that the inside is 8/12?
Also are you planning to run any ties accross your open area at all to tie the walls together?
astidham
Quote from: beckhamk on April 23, 2011, 05:06:27 PM
it is a 12/12 pitch.
how i understand it, If your trusses are engineered, collar ties are not necessary with a 10' or under side wall.
my side walls are 10' with the trusses i have our loft has a ceiling height at the peak ~9'
— Henry Ford
beckhamk
Thanks for the info! Your truss mfg didnt say that the inside would be a 8/12?  just curious as i just contacted one place and they told me they can do a scissor truss 12/12 for hte outside but the inside would be 8/12.  I figure your inside is around the same.
