20x34 2-story universal in upstate NY
Started by NathanS, May 13, 2016, 11:04:09 AM
0 Members and 16 Guests are viewing this topic.
NathanS
Chipping away at the siding still. North wall and mudroom are done... that was a biggie, this time of the year the dew on the roof makes it hard to be up there. South wall just needs around the balcony a bit, may wait on that to use up scraps as they show up.
I am building attic vents out of red cedar slats, rather than router out for the slats, i just chopped blocks. Came out very nicely, I am building them square and sliding them under the roof trim to angle the tops. I really enjoy this kind of cheating, it looks complicated but kept simple.
The thick foam really does add a lot of work to everything... the trim work especially is very complicated. You are basically building boxes for everything - 3d instead of 2d. The mudroom roof and corner above, that took a day to trim - add to that getting the top of the trim to line up with the bottom of the clapboard layout. With the position of the two windows there I had no space to cheat it across a couple courses.
I held the mudroom roof trim up from the endwall flashing about 4", that zone is always rotten on houses. That trim has a return piece of wood so you can't see the foam when standing underneath.
This is my 120-130 year old clapboard clamp I found on ebay for $8. I have used it to put up 16 footers all the way at the top of the walls, it really makes short work of it. It holds the board in a cradle, which allows you to jam or snap the boards into position.
Also just to mention, the additional foam on the walls is already noticeable. We have had our share of cold snaps - a couple consecutive days lows in the 30s, highs in the 50s. We have yet to need a fire, the house is maintaining 67-70 degrees with cracked windows up and downstairs.
Mike 870
What brand and color stain are you using?  It looks amazing.  All that extra effort with the foam board will be worth it when you're saving loads of money on heating and cooling.
NathanS
Thanks Mike, it is TWP stain. The color is Pecan. There are online retailers that will ship 5 gallon pails very quickly. A lot of painters seem to swear by the stuff, it will just fade and need reapplied every 5-7 years - first time probably a little sooner since it is fresh planed wood.
In Ohio I think you can still get the original mixture, the "100 series," which is not the low VOC stuff we are stuck with from Virginia to Maine. Although one thing that I think is kind of nice about the solvents we had is that it dries slower, so you don't really have to worry about lap marks.
dablack
Again, the house looks great and thanks for the picture on the siding gauge.
On the house we are in right now, I went with ordinary spray foam in the walls and then a non-vented roof with spray foam between the rafters and then rigid foam on top of the roof deck and finally a silver metal roof.  We are more concerned with staying cool than warm.  Of course, I had zero roof penetrations, so adding the rigid foam on top was pretty easy.  Hanging insulation on an exterior wall still gives me pause as an engineer.  Those fasteners holding it on always have gravity working on them and the center of gravity of the insulation is an inch or more away from the house.  Then the rain screen and THEN finally the siding.  I think you have done an amazing job and you will be crazy toasty in there, but I still go back and forth!  I think the next house will be double wall.  Double wall will simplify the siding, windows, and doors.  No boxes to build.  Then with the large wall cavity between the walls, plumbing and wiring will be SO easy.  No drilling studs at all.  Then the only boxes you have to build are on the inside and all your windows will have a little 12" seat.  I'm just "typing" out loud at this point.
I think you have done a text book job with the "outsulation" and this thread should be used on how to do it right.  After seeing how perfectly you have done it, I'm still not sure if I would go that way or double wall.  I guess I have a couple of years before I have to decide!  Thanks for all the detailed pictures.
Austin
NathanS
Austin, thank you for the kind comments. You have probably seen what they are doing in Alaska - the REMOTE guide shows they are doing 6" of 'outsulation' in two layers with staggered seams. They will then put cement board over the rain screen, not sure how heavy that is, but my clapboards weigh almost nothing. One thing I picked up in that guide was to 'pre sag' the screws, shoot them in at a slightly upward angle. Made sense to me.
Anyhow, the siding has been done for about a month now. I am going to wait until next spring to have the electrical service disconnected to finish the gable on the one side.
I finished the balcony railing and decking as well. I put down white oak for deck boards - good enough for boats, good enough for me. I made the railing out of eastern white cedar, the top and bottom rails I ripped a 30 degree hat so water will not sit on them. The deck itself is also pitched all the way out. We had leftover rebar from the foundation, so I cut to length and drilled them into the rails. I ran pressure treated furring strips from the end of the deck all the way to the door threshold, I screwed them into the cantilevered portion, and on the inset portion where it is sitting on metal I caulked tar paper on the underside so they were not in direct contact. Otherwise the inset portion the deck just floats - feels sturdy because white oak weighs about as much as concrete. Lots of other details too, extending the subdecking out beyond the siding, bending the metal for proper water drainage... I even found a bent piece of deckboard for the end piece so it has a nice rounded edge - of course no one will ever notice that except for me. Didn't take a ton of pictures because I just wanted to get the thing done.
Even without gutters and all the roof runoff you can sit out there in the rain.
Now I am getting ready to do the kitchen. We are trying to decide between doing the house in Ash or Cherry. Doing a small lot order makes the wood so inexpensive, it really is just coming down to how we want the house to look. We get so much sunlight I am leaning to Cherry to darken things up a bit. Also am planning to do a cast in place concrete counter in the kitchen which will change how the cabinets need to be built a little bit.
The other thing I'm researching is installing a ductless minisplit. I will likely buy the hvac tools and install it myself. Doesn't seem that complicated, and the HVAC companies we've talked to want like $2,000 to basically shoot some nitrogren into some lines and then create a deep vacuum.
Rys
Mike 870
Looks great.  I've done a couple central ACs and a mini split.  It really was not difficult.  Now granted we didn't do a nitrogen pressure test, but I've had a bunch of systems professionally installed over the years, and the "experts" never once did it either.  In fact the last guy didn't even use a micron meter, just let the vacumme run and called it good.  That was the one that put me over the edge.  I would watch them do it, see how quick and easy it looked so I bought an HVAC textbook and now I do my own.  If you've figured out how to build the rest of your house, pretty sure you can install a mini split.
dablack
Lots of great minisplit installs and talk of the tools needed over on http://ecorenovator.org/forum/
Just go over the geothermal / heatpump section.  Lots of guys have installed their own units.
NathanS
Thanks for feedback on the minisplit. It's good to hear that Mike's done it, and the forum looks like a good resource too.
The house has been very efficient. So far this week we are averaging out to around 65-67F having one fire a day - burning 4-5 pieces of partially rotten pine I found in the woods. Highs in the 30s or low 40s and lows in the 20s. We've been getting sun this week, and that on its own will raise the temperature 3 or 4 degrees during the day.
Time is also short lately. I probably won't get to the minisplit until next year, this winter I would have liked to have it to prevent the house from freezing if we're away for a few days here or there.
I have cut most of the plywood for the kitchen counter where the sink will go. I am going to pour a 2" concrete slab for the counter, probably $60 of concrete vs $60 per square foot for the stuff from the store. Can't argue with that. I am planning to steel trowel it all day to burnish the heck out of it.
Once all the boxes are built and installed I'm going to bulk order the hardwood to trim out the whole house (trim, kitchen, stairs, doors). Probably something like 500 board feet of 4/4 and 200 board feet of 5/4. We are going to go with Cherry - been back and for on this. We can get the cherry planed top and bottom, and one side jointed for $2.32 a board foot... that seems just crazy cheap to me... We will probably spend more in the kitchen on plywood and hardware than the Cherry. Around $1700 all in. Ash would be around $1250.
NathanS
Thought I'd post an update, things go slower with a 7 month old.
I built about half of our lower cabinet boxes (all 3/4" plywood and most partitions doubled up) and poured in place a concrete countertop on them. I poured it 2" thick so I had space for 3/8" rebar in front and behind the cast iron (heavy) sink. By the way, my first time with a porcelain sink and find it a lot easier to keep clean than stainless steel... stuff 'sticks' to it less.
My personal opinion, I think there is a lot of snake oil out there for doing a concrete countertop. I just used premix concrete, like 5 bags? So around $20, leftover remesh, and plywood. I don't know, it seems like every time you look how to do something there is someone that has just taken it about 5000 steps and dollars too far.
Anyhow, I love my lasers... what time saver. I bought a cheap one from amazon after the Bosch failed, seems to work great.
Hiding the plywood base with a 2x4 lip dropped 3/4". I used 3/4" plywood for the base, I think 1/2" would have been stiff enough.
Reinforced and ready to go. The sink cutout, I used cardboard to make my template then cut boards and pocket screwed together. Rounded the edges with a jigsaw. Our sink sits on top so it didn't have to be perfect.
I like the end result. I did make a booboo when pouring though. I troweled the surface too early, which caused the very thin top layer to be too weak. I had to buy a harbor freight polisher and polishing pads at another $100 total. Sanded it out, made a portland slurry and applied with drywall knife, then resanded to 6000 grit. Came out good, but troweling too early added several additional hours of labor.
We also completed the first renovation...  ;D
The fridge just takes up too much space no matter where you put it, so we sunk it into the pantry. Our kitchen counter space will over double now, and the house just feels so much bigger and open. The pantry still has a lot of storage, it is actually probably the right width for one of those pantry types that have big drawers you pull out. Because we furred the ceiling drywall out we were able to snake 1/2" pex and electrical over for the fridge... we still got ice cubes.
This is probably the one advantage to living in an unfinished house, you can make decisions on experience instead of trying to plan everything all at once.
I have been working on the downstairs bathroom now.
dablack
Looks good!  I like the simple and over built approach to the countertops.  Looks really nice and I think the polish was a good idea even if you didn't want to do it.  Did you put on any kind of sealer or are you going to wax them or anything?
Also, your construction stairs are much nicer than mine.  I have misc scraps as the treads and it really bothers people.  Plus, no rail on mine so people feel really uneasy.
NathanS
Thanks Austin. I used Miracle Sealant Porous Plus. It is a penetrating sealer that is safe for food. Seems ok so far. One thing is for sure the counter is going to get abused. If it stains, it stains. I also wanted to be able to put red hot pots and pans right on it. I wondered with wax is what will the hot pan do to it.
With it being concrete, and having the pads now, I can always resand it once every couple years if it gets too stained up or ugly.
I put the rail on the stairs because I kept getting the same reaction from visitors. Hopefully not too many more months before things start getting clad in wood. I think March or April will be warm enough to start making stair treads and doors etc. I want to do wainscot all the way around the downstairs too.
NathanS
That's the brand. I got SC-L02 though, it's rated a bit more accurate.
https://www.amazon.com/gp/product/B01N21XU73/ref=oh_aui_detailpage_o07_s00?ie=UTF8&psc=1
It is so easily worth the purchase. I use them all the time. Bosch did send me a replacement for the one that broke. But with modern (maybe it's always been this way?) equipment, you pretty much always need 2 of everything. So I will keep the Bosch for if/when this one breaks.
You could even use these as a transit, you just have to wait until dusk or do it at night. I used it to establish the bottom trim around our house.
NathanS
Mostly have just worked on the downstairs bathroom over the neverending winter (getting another 2 inches of snow or so tomorrow april 19th... more like february than spring still).
If I never see another tile again it will be too soon.
We used Kerdi because it has a long proven track record. Also the shower pan - namely the integrated flange, allows for a face sealed mud bed instead of it being like a water storage resevoir. That was the main reason. Laticrete makes a liquid applied version of this which I think would just go way faster.
I used some extra redgard  in the niche, the Kerdi really requires a lot of origami if you want to do this, or you have to keep buying inside and outside corners which adds up.
I know what you're thinking "wow that looks like fun"
Dry pack mortar bed, this was tough because I didn't have much access. I actually didn't take any pictures of between kerdi and tiling it. The curb was fast setting concrete, that stuff is cool.
Two showerheads, also tiled the ceiling.
We could have centered the drain but decided instead to just make the shower as wide as we had space for.
The beer shelf, not sure what shampoo is doing there.
It was hard to get decent shots because there wasn't a lot of space. All the grout lines line up floor to ceiling, boy that was a lot of work. What was I thinking.
We have had 5 1/4 white ash flooring acclimating upstairs for a week or two now. I will be installing that next. I am strongly leaning toward an oil finish like 'rubio monocoat' instead of polyurethane.
azgreg
Looks great! Well done man!  :)
I love shower shadow boxes.
Nice job Nathan.  Glad you went with Kerdi as the shower is no place to skimp.  Too many think that concrete board will suffice.  NOT.
NathanS
Thanks guys. And agreed on both counts. I had considered the old school way of tar paper on the walls and the liner, but I was concerned with how to effectively waterproof the cubby. No good way to connect the tar paper to the liquid applied. Anyhow, really glad it's over with. I don't think there is anything left to do on the house that I will dislike so much. Funny I enjoy masonry, but i just find the tiling extremely tedious and never ending.
Also I want to throw out a question or two on doing the wood flooring -
I am starting the layout from the stair nosing, which means I have to reverse direction of the flooring in all bedrooms. I got the flooring straight from the mill, so they don't make splines. I was just going to rip them on the tablesaw from a piece of the flooring. Seems straightforward but not sure if there's anything I could run into there?
Only other thing is just if anyone has used oil as opposed to poly to finish a floor. The modern stuff is used even in commercial settings in Europe. It is supposed to harden the surface of the wood, and if you do get a nick or some kind of damage you can just spot repair instead of sanding down the whole floor and applying poly again.
ChugiakTinkerer
It looks gorgeous Nathan!  It's been over 5.5 years since I finished my last tile job in the upstairs bath.  I guess that's enough time to forget all the unpleasant parts of tile work, because after seeing your photos I want to get to work on the downstairs bath.   d*
NathanS
Thanks Chugiak, the bathroom has been awesome. It was also nice to get such a big project off our plate.
The other most disruptive project left is also off our plate now... the upstairs hardwood floors are done. We got 5 1/4 wide Ash from a local mill. It came out beautifully.
Started out by putting down tar paper on the floor, then face nailed where we had to and blind nailed everything else. I bought the "Numax" floor nailer off amazon and it worked flawlessly. For face nailing I got the makita 16 gauge finish nailer because I will be using that thing a lot. You can adjust the air pressure on the gun instead of the compressor which is awesome. Especially when you are using different tools that need different pressures at the same time.
The layout starts at the stairs, so I had to rip strips to slide into the groove in all the bedrooms to reverse direction. I got everything close on the table saw and then planed everything to fit perfect. I feel it would have been near impossible to get the splines just right without the planer.
I found the groove on the butt ends of the floor was slightly looser than along the length, it was much easier to snug boards together using that grove and a hammer than using the rubber mallet. The mallet was not enough, at least for 5.25" wide planks, to close up all the gaps.
Putting the floor down wasn't too bad, the sanding took a long time though. We did end up using "Rubio Monocoat" the pure version. The application itself is faster than poly, but because the wear surface and finish itself is the wood, any sanding imperfections will be picked up.
I drum sanded and edged with 60/80/100. Then I hand sanded the perimeter and corners. Then I used a buffer with a 100 grit screen to polish it off. Pretty much no marks anywhere.
The oil also goes on with a buffer, you buff it on, and then after a couple minutes you remove everything you can with a clean buff pad and then a cloth under the buff pad. The hard wax oil bonds with the surface of the wood and closes off the pores, the wear surface is the wood itself as opposed to a layer on top. It is also 0 VOC so the house isn't cancer city for the next week. The oil is slightly less wear resistant than poly, but if it ever needs a touch up you don't have to strip the whole floor, you can just lightly sand and reapply. I am really optimistic about this product.
Also want to mention I used "Timbermate" wood filler which is one of the most user friendly products I have used period. It took the oil great and blends right in.
GaryT
Awesome looking floor!  Very nicely done.
Gary
dablack
Love it.  Floor look great.  You did a really good job.
Beavers
That does look awesome [cool]
It's cool that you have a local mill where you can get stuff like that.
Rys
Wow! Looks great. I'll have to keep your finish in mind when we do our floors. Thanks for the info.
