OKLAHOMA 20X30 SINGLE STORY
astidham
This is how we put the beams in place
— Henry Ford
SardonicSmile
Quote from: astidham on June 22, 2010, 06:59:02 PM
Looks a lot easier than what I did (raised slab). If I had to do it all over this is what I would do. Nice work!
astidham
Thank You Sardonic Smile I have followed your thread, yours is looking real good!
— Henry Ford
Nice work and thanks for the helpful photos. Everyone can share and learn from a project like this.
dug
I was going to build my foundation like you did, using concrete above grade with posts in order to make leveling the beams easier but was concerned about getting good enough bracing with the short posts. I am wondering if you plan to brace yours, or maybe I am missing something and it may not be as important with the two part pier system you used.
I am not criticizing (looks great!), just curious.
cmsilvay
When we built ours I was also concerned about bracing so instead of 6x we went with dry stacked 8" blocks filld with concrete.We had rebar running up the center for extra reinforcement.
astidham
Quote from: dug on June 23, 2010, 02:47:52 PM
dug i plan on bracing the beams, not sure with what yet.
i was going to have some steel triangles built at a fab shop, but more likely to use 2x6 cross brace.
i also think that using the continuous footings i poured will help a little. the way you braced yours look very strong, if you have any suggestions please let me know
— Henry Ford
The foundation plans for the pier and beam foundations in my plans have details showing prefab steel brackets and 45º wood brackets bolted to the beams and the wood posts. There are a number of options depending on how tall the posts or piers are.
astidham
Thanks John, I see what you are talking about on page 1.
I did use a simpson bracket (AC6), each bracket holds 10 nails and when they are all nailed up they hold the beam pretty tight.
If i can fit the lumber, i will use the method you call out.
— Henry Ford
astidham
I checked my beams with the water level and found them not level with each other.
instead of shimming the low places, i notched the beams
I used dugs method for finding square by building 2 boxes and moving them until square...Thanks dug!
I wasn't able to get all the floor joist up before the storm
mostly because i didn't have my helper, my wife
— Henry Ford
astidham
Anyone use pocket doors before? are they hard to install?
— Henry Ford
handyman
Pocket doors aren"t hard to do.  Buy the kit and frame it into your new wall, then buy the door and hang it on the rolling track.
They are not convenient to use, and are mostly just left open.
PEG posted something a while back about some higher grade pocket door hardware he had found.  I know it sounded a lot better to use in the long run.
astidham
more floor joist pics
Simpson bracket
— Henry Ford
dug
Looking good! I'm sure you must feel very satisfied seeing it growing away from the ground. I was right there not so long ago.
astidham
#66
Thanks dug, It does feel like an accomplishment!!
— Henry Ford
astidham
Rain has slowed down production but we did get a couple of visitors
Started the floor sheathing
Sheathing complete, future living room view
shop view
— Henry Ford
astidham
The tarantula spider is on a 2x6
— Henry Ford
dug
QuoteThe tarantula spider is on a 2x6
The males are out in force here as well
Good work on the deck!
astidham
Thank you dug, cant wait for your update!
— Henry Ford
astidham
got the first wall up today, 100 degree temp sure didn't help good thing was dad came down to visit and laid out the framing
living room wall followed closely
— Henry Ford
astidham
as of today dad and I Have put up 3 walls
not bad for a short weekend
— Henry Ford
dug
You guys are cranking along well!  Good to see.
One thing I noticed- The opening that looks about 6 ft. wide seems to have an awfully thin header. Maybe it's just the photo, but you may want to check the sizing if you haven't already.
astidham
Thanks dug, the header is 3 2x6s nailed together. I will check the span table, good catch dug!
— Henry Ford
