Author Topic: Okanogan 14x24 by a lurker :)  (Read 958064 times)
Offline Nate R
  • Apprentice
  • Welcome to the CP-Forum
Re: Okanogan 14x24 by a lurker :)
« Reply #2950 on: March 20, 2019, 08:21:02 AM »
That is one thing I do not own, snowshoes.  d*
But after this year, I will have a pair.
It takes about a day and a half to get my place really warmed up with the wood burner.
Toyotaboy
I bought a pair this year, and am glad I did!
Is your floor insulated? Or the crawlspace walls? Curious about the heating time vs insulation/thermal mass.
Hoping to start my 20x30 Northern WI build soon.
Offline MountainDon
    • My 15.75 x 30 Jemez Cabin
« Reply #2951 on: March 20, 2019, 10:33:32 AM »
Regarding warm-up time: with the floor insulated (R25) as well as walls (R19) and ceiling (~R50) we can raise the interior temperature 20 degrees an hour average using a small wood stove (VC Aspen) and a wall mount direct vent propane heater. The propane heater is rated at 18000 BTU but with the altitude correction is will have a maximum around 14000 BTU. The 8800-foot altitude will also reduce the output of the Aspen wood stove from its max of 18K to around 14K as well.  The ceramic tile floor is warmed nicely after 24 hours; becomes almost barefoot friendly.
If there is a lot more thermal mass than average on the inside of the insulation the warm-up time will be extended. Air leaks, drafts, will also make it slow to become comfortable.
Offline Toyotaboy
  • Full Member
« Reply #2952 on: March 20, 2019, 12:15:36 PM »
Nathan,
The 4 ft crawl space in not insulated but the overhead in the crawl space is. 14 inch I beams with insulation keeps the floor warm after it's warmed up. The rest of the place is 2x6 construction with insulation and drywall. All UDC to code.
We were so air tight that we had oder problems with the composter toilet when using the wood burner. I ended up making a nice floor
vent directly under the front of the wood burner to the crawl space. This alleviated the draw from the bathroom. But I have to remember to close it when we leave.
What also helps in the ceiling fan to push the warm air down from the loft.. This has been a tremendous help in circulating the air and helps with warming the whole place up.
Sorry to jack the thread Oljarhead.
Toyotaboy
Offline Nate R
  • Apprentice
« Reply #2953 on: March 21, 2019, 08:32:37 AM »
Thanks for the feedback Don and Toyota! Interesting to hear.
I'm doing an insulated slab on grade, and am hoping to use that thermal mass for comfort in the warmer summer days (cool nights, usually), but know I'll be paying a price in winter warm up time. (Weekend/Recreational use). So interesting to hear you're achieving 20 deg/hr or so, Don.
I'm getting the equipment together to datalog the thermal performance of my structure, mostly for my own curiosity. I intend to record inside and outside temperature and humidity, as well as the slab temperature and soil temperature around 4" depth. Probably at 1 hr increments, so I can see how cold/warm things get when unoccupied and when occupied, etc.
I may be able to integrate my solar datalogging into that too to roughly see how much impact sun has, etc.
<highjack over/>
Offline OlJarhead
    • Team SEWA
« Reply #2954 on: March 22, 2019, 03:36:03 PM »
No problem on the highjack :D
I use a cold air intake on my stove that comes from the outside so it drafts that way and doesn't cause issues.  The floor is R21 and the walls are R19 with an R21 roof and it takes about the same amount of time as Don's.  I can warm it above freezing from 18F interior in about an hour or so and after 6 hours or so it will be about 65-70F depending on the inside temps.  I use an 18k BTU propane heater to augment the stove (same stove as Don's) and at 3200 feet have a little more heating power than Don does.
I do find, however, that it takes a full 24hrs or so to heat every surface, cupboard etc and that's just how things work but I do that without the propane heater.  I only use it until the cabin hits 60F then I shut it off and only use wood.
Once it's warmed up it's very easy to maintain the warmth with the little stove.
Offline KodiakRanch13
  • Newbie
« Reply #2955 on: April 01, 2019, 03:12:51 PM »
Appreciate all the good posts Gents.  Newbie here, I purchased some property in Aeneas Valley a few years ago and hope to get started on a small build this Summer, 12x16 are my first thoughts as I want to avoid permitting etc.  Little research and general word of mouth has been 200SF and less wont require a permit for my shed, if I'm wrong let me know!  Thanks again for all your info and maybe I'll run into yall one of these days.
-Kodiak (from Eastern Washington)
Offline OlJarhead
    • Team SEWA
« Reply #2956 on: April 02, 2019, 03:19:52 AM »
Welcome to the neighborhood ;)
Offline OlJarhead
    • Team SEWA
« Reply #2957 on: April 27, 2019, 04:56:35 AM »
Did I ask this before?  I'm looking for ways to connect a D Log wall to a standard frame wall.
The idea is to make the addition with D Logs.  It will be 12 feet deep to the back of the cabin and come even with the current deck roof.
My though was to create a recess into the 2x6 wall for the stacked logs to be secured to but other than that I'm just not sure.
Thoughts?
Offline OlJarhead
    • Team SEWA
« Reply #2958 on: April 27, 2019, 04:41:05 PM »
My thought is that I can cut out the 8" needed for the log wall to be recessed into the framed wall and then frame the wall with 2x6's on either side and one 2x8 across them (so like a 6x8" pocket inside the wall) then cut the D logs square at that end and slide them into the wall.  I can then chink them at the corner to ensure a good seal but leave them free floating inside the wall to allow for shrinkage that likely will occur.
In essence I'd build the back wall (12' deep) then the outside wall and the front wall (to the porch) and a log wall back to the main cabin (beside the porch) giving basically 3 walls with the corner walls of the cabin being the inside.  This addition would be L shaped around the corner of the cabin and made with 8" D logs.  The roof would be a 3.3x12 pitch to match the front porch but rise to 3.3x12 pitch (or higher) on the back side (in order to match the pitch and keep it reasonably strong).  I'll just run the rafters on the front back to the hip which will be set back from the corner to allow the 3.3x12 pitch of the porch to continue across the front.
The front will remain at 10 from the cabin like the porch but the side being 12' out will need a stronger roof.
Cache hits: 12: 0.00208s for 40,801 bytes (show)
Queries used: 29.
