Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
Home
Forum
Help
Search
Login
Register
CountryPlans Design/Build Forum
Off Topic
Off Topic - Ideas, politics, humor, inspiration
(Moderators:
hpinson
Adam Raabe
Not Directly Related to Building.... My Latest Flashlight Mod
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Not Directly Related to Building.... My Latest Flashlight Mod (Read 1415 times)
Administrator
Journeyman
Jemez Mountains, NM; that's pronounced HEY-mess
on:
November 29, 2017, 01:09:30 PM »
A light that can be used camping or for any emergency, power grid down, situation.
It began life a a cheap Chinese knockoff of a light known as an SRK, a Sky Ray King. The body holds 4 x 18650 lithium ion cells, the cylindrical cells that used to power all laptops. I chopped the head down and rebuilt the front/top end. Light is from a Cree LEDusing a remote phosphor dome for the 3000 K output. It is not super bright on maximum, but has great run time. On highest output it seems to be much like a clear globe 40 watt incandescent. It is kinda hard to make meaningful photos, but here's one in the workshop, on high, right after final assembly. The maximum head O.D. is about 2-1/8"; 55 mm.
With the 4 - 3000 mAh cells it will run about 18 hours continuous on high.
Another view
Not visible is the micro-usb port which powers the built in charger and allows up to 2 amp rate recharging of the cells while in the light.
I have lots more construction photos if anyone is interested.
One more photo.
This is the head, removed from the body with the circuit boards hanging loose from each end. The firmware allows stepless ramping from lowest, moonlight like setting to the highest which I intentionally limited to use 700 mA maximum.
Logged
MushCreek
Journeyman
Re: Not Directly Related to Building.... My Latest Flashlight Mod
Reply #1 on:
December 02, 2017, 02:27:59 AM »
Cool project! I'd like to make an attachment to go on my Milwaukee M18 flashlight that would redirect and diffuse the light. The light stands up right, uses rechargeable 5.0 A/H batteries, and runs a long time with the LED bulb I got for it.
Logged
Jay
Administrator
Journeyman
Reply #2 on:
December 02, 2017, 06:47:54 AM »
Those are nice utility lights. A number of people have adapted various plastic jars or bottles to assorted lights. My experience, and that of a couple of other guys on the
flashlight forum
is that the LED is best facing down like in the light I showed above. There is less glare in your eyes. But placing the led there is more complicated.
Logged
MushCreek
Journeyman
Reply #3 on:
January 07, 2018, 02:22:47 AM »
I don't want to modify the flashlight- it's too handy! I was thinking of a reflective cone hanging down, and a lampshade to diffuse the light. It would just sit on top of it.
Logged
Jay
Administrator
Journeyman
Reply #4 on:
January 07, 2018, 07:07:30 AM »
Go for it. I had a Ryobi 18volt I was going to mod but then I got into changing the electronics, and changing led's.
Logged
Administrator
Journeyman
Reply #5 on:
November 09, 2018, 05:28:08 PM »
Seems like a good time to add to this old topic. Another light I am almost finished building. This one has a fair amount of woodworking. I will include a few photos here. I am posting a more detailed build description over on the BLF (budget light forum) website...for any of the more curious that can be found
here
The idea for this light was inspired by the
bookshelving
I built for our son's home recently.
Here's the current project, a japanese shoji style light. This may be used on a table or may be hung once it is completed. All the woodworking is completed now. The electronics that control the LED output have to be installed. Included is a lithium polymer battery and a charger.
The wood used is pine. The stain is Minwax ebony. The screen material is a plastic laminated paper 0.2 mm thick.
The screen frames number four in total, one for each side and are removable. They began life as a piece of 1/2" thick pine. Grooves were routed and then the board was cut apart into "sticks" called kumiko.
One of the frames being glued up...
Four frames completed...
Two of the corner posts, or stiles, test fitted with a frame...
Test fitted, rubber bands holding everything together...
The shoji paper is affixed to the backside of each frame with double sided tape...
If interested, more photos of the process are at
BLF
. I'll also post a completed set of photos here when it is completed.
Logged
Journeyman
Reply #6 on:
November 10, 2018, 02:27:07 AM »
Beautiful and some pretty high level joinery
I'm reminded each time we have an outage and have to drag out the smelly old kerosene lamps that I should make some nice long runtime battery lights.
Logged
Administrator
Journeyman
Reply #7 on:
November 16, 2018, 10:53:58 AM »
A completed project. The copper discs have a direct thermal path to the LED to offer the needed cooling for the LED. In my excited rush to photograph the completed light, I neglected to dust off a few areas.
The second shot os with the LED powered on mid power. The LED is 3000 K, plus the copper plates probably add a little warmth as / if light reflects off them.
The underside, showing the battery cavity plus most of the electronics (charger board, usb port, voltmeter...) The on-off switch is located in the leg or corner post at lower left where the black and red wires enter through a drilled hole set.
Two hatch covers on the underside; one is installed, the other is still off illustrating the LiPo battery fitment. The extended copper strip is for cooling the charger.
There is an onboard voltmeter that only operates when the momentary contact switch is held down. The red LED indicates a charge is underway and when the LED switches to green, the charge is complete.
Last Edit: November 16, 2018, 01:12:47 PM by MountainDon
Logged
NathanS
Senior Member
NY Mountains
Reply #8 on:
November 16, 2018, 11:25:36 AM »
Very nice.
Logged
firefox
Senior Member
Eureka NV or Bust
Reply #9 on:
November 17, 2018, 08:23:09 AM »
Just WOW!
Logged
Bruce & Robbie
MVPA 23824
Print
Pages: [
1
Go Up
« previous
next »
Off Topic
(Moderators:
hpinson
Adam Raabe
Templates: 5:
index (default)
Ads (default)
Portal (default)
Display (default)
GenericControls (default)
Sub templates: 12:
init
html_above
adsheaders_above
body_above
adsindex_above
portal_above
main
portal_below
adsindex_below
body_below
adsheaders_below
html_below
Language files: 3:
SPortal.english (default)
index+Modifications.english (default)
Ads.english (default)
Style sheets: 1:
portal (default)
Files included: 38 - 1124KB. (
show
./index.php
./Settings.php
./Sources/QueryString.php
./Sources/Subs.php
./Sources/Errors.php
./Sources/Load.php
./Sources/AnnoyUser.php
./Sources/Subs-Portal.php
./Sources/Security.php
./Sources/LoadAds.php
./Sources/Subs-Db-mysql.php
./cache/data_5b07fc8ce18bd349a4b1cafd3fd817f3-SMF-modSettings.php
./Sources/ManageSearchEngines.php
./cache/data_5b07fc8ce18bd349a4b1cafd3fd817f3-SMF-spider_search.php
./cache/data_5b07fc8ce18bd349a4b1cafd3fd817f3-SMF-board_parents-0.php
./cache/data_5b07fc8ce18bd349a4b1cafd3fd817f3-SMF-permissions--1.php
./Sources/Subs-Auth.php
./cache/data_5b07fc8ce18bd349a4b1cafd3fd817f3-SMF-theme_settings-1.php
./Themes/default/languages/SPortal.english.php
./Themes/default/index.template.php
./Themes/default/languages/index.english.php
./Themes/default/languages/Modifications.english.php
./Themes/default/Ads.template.php
./Themes/default/languages/Ads.english.php
./cache/data_5b07fc8ce18bd349a4b1cafd3fd817f3-SMF-log_online-update.php
./Sources/PortalBlocks.php
./SSI.php
./Themes/default/Portal.template.php
./Sources/Display.php
./Themes/default/Display.template.php
./Sources/Subs-Editor.php
./Themes/default/GenericControls.template.php
./cache/data_5b07fc8ce18bd349a4b1cafd3fd817f3-SMF-verificationQuestionIds.php
./cache/data_5b07fc8ce18bd349a4b1cafd3fd817f3-SMF-parsing_smileys.php
./Sources/AutoEmbedMediaPro2.php
./cache/mediaprocache.php
./cache/data_5b07fc8ce18bd349a4b1cafd3fd817f3-SMF-response_prefix.php
./cache/data_5b07fc8ce18bd349a4b1cafd3fd817f3-SMF-moderator_group_info.php
Cache hits: 12: 0.00216s for 40,795 bytes (
show
get modSettings: 0.00030s - 15558 bytes
put modSettings: 0.00046s - 15558 bytes
get spider_search: 0.00013s - 1882 bytes
get board_parents-0: 0.00013s - 6 bytes
get permissions:-1: 0.00012s - 75 bytes
get theme_settings-1: 0.00018s - 2017 bytes
get log_online-update: 0.00017s - 0 bytes
get verificationQuestionIds: 0.00017s - 143 bytes
get parsing_smileys: 0.00020s - 5427 bytes
get response_prefix: 0.00012s - 11 bytes
get moderator_group_info: 0.00014s - 118 bytes
get menu_buttons--1-english-1: 0.00003s - 0 bytes
Queries used: 29.
