Foundation Plugin for SketchUp
Started by Medeek, July 04, 2016, 02:26:33 AM
Medeek
Version 1.8.3 - 03.10.2022
- Enabled the installation of windows and doors for polyline stemwall openings.
- Enabled lumber and pressure treated lumber textures in the Materials tab of the Global Settings.
- Added a door and window opening tool to the Stemwall Opening Toolbar.
- Animation option added to the General tab of the Global Settings.
This is a fairly substantial upgrade to the foundation plugin.  Note that windows and doors can only be installed into "polyline" stemwalls, this new feature does not work with the legacy stemwall tool.
Nathaniel P. Wilkerson, P.E.
Medeek
Medeek
I've been giving the Basement Entrance some more thought and I've come up with the following parameters for this option:
1.) Entrance Direction: Left, Right or Center
2.) Stemwall Height
3.) Stemwall Thickness
4.) Footing Width
5.) Footing Depth
6.) Landing Width
7.) Landing Depth
8.) Slab Thickness
9.)  No. of Steps
10.) Riser Height
11.) Tread Depth
12.) Tread Overhang
13.) Nosing Radius (Typically 1/2")
Let me know if I am missing anything.
Medeek
Version 1.8.4 - 03.16.2022
- Enabled entry stairs for polyline stemwall openings: Left, Right and Center.
Note: I did not enable the radius for the nosing on the treads but I think this additional feature or lack thereof is not a major issue since it is purely cosmetic in my opinion.  If there is enough additional demand for it I will look into it further.
I also have not added any option for rebar into this concrete sub-assembly.  Again, I will address that further if there is additional interest or requests for it.
Medeek
Version 1.8.5 - 03.20.2022
- Fixed a bug with windows and doors when a polyline stemwall is in a RIGHT direction/configuration.
- Added a "TRIAL" licensing notice at SketchUp startup to alert users to activate their license/serial numbers if running in trial mode.
Medeek
Getting a little closer, now I just need to update the menus with all the new parameters:
Medeek
Version 1.8.6 - 04.24.2022
- Enabled the "Draw Grade Beam" tool with the following geometry types: closed polyline, open polyline and line.
- Added longitudinal rebar for grade beams.
- Added hoop/stirrup rebar for grade beams.
Medeek
Medeek
So I drew this with the column and new grade beam module:
My oldest son then asked me, "What is it?"
My answer was, "I don't know, it's whatever you want it to be."
Medeek
Version 1.8.7 - 07.31.2022
- Added slab depressions for rectangular and polygon slab assemblies.
- Enabled editing, moving and deleting of slab depressions for all slab assemblies.
- Added a "Regen" context menu item for polygon slab on grade (SOG) and slab assemblies.
Medeek
Version 1.8.8 - 07.31.2022
- Added a "Regen" context menu item for column footings and stemwall step assemblies.
- Added the ability to customize the texture/material for stemwall foundations.
- Added a "Stemwall Texture" parameter into the Materials tab of the global settings.
The "4x8 form" texture option was per customer request.
Medeek
Version 1.9.0 - 07.11.2023
- Fixed a minor bug with the "Edit Outline" menus for various foundation types.
Medeek
Version 1.9.1 - 09.26.2022
- Added a negative X and negative Y slope direction for slab depressions.
Medeek
Version 1.9.2 - 11.30.2023
- Enabled Openings for stemwall steps: Windows and Doors.
- Enabled Blockouts for stemwall steps.
This update per customer request.  Now openings and blockouts can be used in either polyline stemwalls or stemwall steps.
Medeek
Version 1.9.3 - 12.16.2023
- Fixed a bug with drain pipes for polyline stemwall foundations which have openings or blockouts enabled.
Medeek
Version 1.9.4 - 01.07.2024
- Updated and improved the license verification module.
- Disabled redundant logging to improve plugin performance.
Medeek
Version 1.9.5 - 02.13.2024
- Improved the serial number verification logic within the License tab of the Global Settings.
- Updated the javascript logic within the License tab of the Global Settings.
- Added statistics for the following foundation types (Medeek Estimator integration): Slab-on-Grade, Slab, Stemwall, Grade Beam
Medeek
Version 1.9.6 - 04.20.2024
Medeek
Version 1.9.7 - 04.23.2024
- Fixed a compatibility bug with SketchUp 2024 (Fixnum & Bignum) while maintaining backward compatibility with previous versions of SketchUp.
Medeek
Version 1.9.8 - 04.28.2024
- Updated the license verification system with a more secure and improved algorithm.
- Updated the polyline stemwall tool with an improved wireframe preview which includes the footing.
Medeek
Version 1.9.9 - 06.06.2024
- Added additional rebar sizes for slab reinforcement for slab and SOG foundations: #6, #7, #8, #9, #10, #11, #14, #18.
