Author Topic: Foundation Plugin for SketchUp  (Read 16186 times)
Offline Don_P
Re: Foundation Plugin for SketchUp
« Reply #50 on: April 05, 2017, 02:06:40 AM »
Wow! That is the deep end of the pool  :D
Offline hpinson
« Reply #51 on: April 05, 2017, 04:00:00 PM »
Can you guys recommend a wall plugin and a roof plugin? I see there are a few - not sure what is best.
Offline ChugiakTinkerer
« Reply #52 on: April 06, 2017, 10:11:02 AM »
I use Medeek's truss plugin for truss and rafter generation.  I'm actually a little behind in keeping up with the versions that Medeeek has cranked out.  For wall generation I have a plugin that I can't remember the name of at the moment.  It's one of the free ones that has been available for a while.  It makes simple layout real easy, but for detail work I end up creating my own walls.  I am not a production designer, just a diy guy wanting to build a cabin so I can afford to waste time futzing with stuff in Sketchup.  Having spent the last three nights developing cut lists and story boards, I think it would be worthwhile to have a plugin that can do that for you.  I'd probably pay a few hundred dollars if it could do it well.
Edit: Medeek's plugin will do roof sheathing too.  I think his latest version will do roofing material.  I purchased a license, which provides for free upgrades for a year.  It wasn't much money and definitely worth my trivial investment.
Offline Medeek
  • Structural Engineering
    • The Engineering and Design Firm of Medeek
« Reply #53 on: April 09, 2017, 04:34:32 PM »
The polygon tool for the slab-on-grade foundations is nearing completion.  I've got the concrete, perimeter rebar, internal footings and even anchor bolts all working.
The only item still pending is the slab reinforcement (mesh/bar).  I've been contemplating devising my own boolean subtraction tool.
I've even managed to create a fillet tool based on TIG's 2D tools that properly applies the correct bend radius to the perimeter rebar.
Nathaniel P. Wilkerson, P.E.
Offline Medeek
« Reply #54 on: April 09, 2017, 04:35:43 PM »
I'm still using the Housebuilder plugin for walls since my own wall plugin is still not there yet, but I'm hoping to get something out in the near future.
Offline Medeek
« Reply #55 on: April 12, 2017, 09:53:37 PM »
I think I've got the slab reinforcement working now.  I haven't tested it enough to determine if its really robust enough to release another update but I'll keep testing.
I owe Sdmitch big time for this one.  I've integrated his rebar trim function into the plugin to create a new module that trims the slab rebar or mesh.  I am still trying to figure out exactly how the magic is done but most of it is over my head.
View model here:
https://3dwarehouse.sketchup.com/model/7d64c1ab-bb1a-47a2-9fb4-4cf3553e7cec/Foundation-4
A mesh reinforced slab though can get quite heavy with the polygon count so it may only have limited usefulness.
Offline Medeek
« Reply #56 on: April 13, 2017, 10:32:59 AM »
I haven't fully compiled a TODO List for this plugin yet but there are still a number of items that need to be addressed.
- A hole cutting tool that removes the concrete and the rebar and any anchor bolts in the way.
- Square and Rectangular Footings for point loads
- Strip Footings
- A line tool for the stemwall module
- Retaining Walls with Engineering
- Ability to step foundation walls
- Webdialog input for SOG and Stemwall so that interior footings can be configured with ease.
Let me know if there is anything you would like to add to this list.
« Reply #57 on: April 13, 2017, 01:15:51 PM »
That's the one, thanks!
Offline Medeek
« Reply #58 on: April 14, 2017, 04:41:41 AM »
Version 1.1.0 - 04.14.2017
- Added polygon outline tool for slab-on-grade and slab.
- Enabled perimeter rebar, anchor bolts, and slab reinforcement for (polygon) slab-on-grade foundations.
- Enabled slab reinforcement for (polygon) slabs.
Offline Medeek
« Reply #59 on: April 23, 2017, 08:01:08 PM »
Version 1.1.1 - 04.23.2017
- Added polygon outline tool for stemwall foundation.
- Enabled perimeter rebar, anchor bolts, vents, and internal footings for (polygon) stemwall foundations.
View model here:
https://3dwarehouse.sketchup.com/model/d8dec962-1fb4-4637-adcd-7406fef4e9df/Stemwall-Foundation-POLYGON
The next improvement would be a web_diaolog input so that more than one internal footing can be specified at a time.
Offline Medeek
« Reply #60 on: April 23, 2017, 10:51:44 PM »
Using the rectangular floor primitives I was able to manually create the floor on the previous foundation in about 30 minutes:
If I create the polygon floor tool I will be able to accomplish the same thing in under 10 seconds.  The polygon floor tool in the truss plugin is next...
Offline Medeek
« Reply #61 on: April 26, 2017, 11:59:05 AM »
The trim tool in the Truss Plugin comes in quite handy when dealing with more complex foundation geometry:
For this foundation I used the stemwall (rectangle and polygon) function and the slab (polygon) function.  I had to trim the garage stemwall and also manually create the smaller interior post/beam assemblies.  I also adjusted the position of some of anchor bolts once I cut the doors into the garage stemwall.
View model here:
https://3dwarehouse.sketchup.com/model/4ed9f28d-11e4-4166-b698-b3cd734cd2a1/Foundation-7
Offline Medeek
« Reply #62 on: May 06, 2017, 08:59:05 AM »
Version 1.1.2 - 05.06.2017
- Added "Circle Segments" option within the global settings, rebar and mesh polygon counts can now be controlled.
In this example I set the segment number to "5".
The global setting circle segment number will default to 24.
Offline Medeek
« Reply #63 on: May 07, 2017, 09:56:12 AM »
Some common configurations of concrete columns:
« Last Edit: May 08, 2017, 04:37:39 PM by Medeek »
Offline Medeek
« Reply #64 on: May 31, 2017, 06:15:55 AM »
I've had a request for adding the option of insulation around a slab on grade, in short a frost protected shallow foundation (FPSF).
This should not be too hard to add in.  There are a number of resources online I will study to come up with the most standard configuration as possible.
Are there any particular things anyone would like to see with regards to FPSF insulation.
Offline Medeek
« Reply #65 on: May 31, 2017, 08:00:43 PM »
An FPSF with 2" foam insulation along the wall and vertically.  2.5" foam insulation at the corners with the following horizontal dimensions:
A = 12"
B = 24"
C = 40"
The rectangle foundation is easy, the polygon shaped foundation will be more challenging.
View model here:
https://3dwarehouse.sketchup.com/model/ab622b36-cc2f-43f8-baa4-f93ceec80741/FPSF
Offline Medeek
« Reply #66 on: June 01, 2017, 05:57:40 PM »
An irregular shaped FPSF, note the 135 deg. corners.  Once this angle becomes greater than 135 degrees I would probably just treat it the same as a straight wall.
View model here:
https://3dwarehouse.sketchup.com/model/bfcf8f49-0e4e-4932-a42c-06121a20fd73/FPSF2
Offline Medeek
« Reply #67 on: June 02, 2017, 11:30:45 PM »
Version 1.1.3 - 06.03.2017
- Added "FPSF" option to rectangular slab-on-grade foundations.
- Added an insulation layer in the global settings under the "Layers" tab.
Offline Medeek
« Reply #68 on: June 03, 2017, 09:59:27 AM »
- Added "FPSF" option to rectangular stemwall foundations.
Offline Medeek
« Reply #69 on: June 03, 2017, 10:13:22 PM »
Working on the square/rectangle spread footing tool:
I will start with wood posts as an option with the following sub-options for the wood post:
Post Size:  4x4, 4x6, 6x6, 6x8, 8x8
Post Height (in.)
Post Base:  None, ABA, ABU, ABW, CBSQ
Post Cap:  None, CCQ, ECCQ
Post Rotation:  0, 90, 180, 270
I also plan on having the option for steel posts with the following sub-options:
Post Size:  HSS4x4x1/2, HSS4x4x3/8, HSS 4x4x1/4, HSS3x3x3/8 etc...  (round and square tube)
Post Height (in.)
Base Plate Size (in.) - square shape L x L
Base Plate Thickness (in.)
Base Plate Hole Dia. (in.): 1/4, 3/8, 1/2, 5/8 (4 bolts per baseplate)
Vert. Offset (in.)  - for non-shrink grout
Post Cap:  Not sure what to do with this yet.
I've been contemplating using the Simpson Strong-Tie post caps and bases as provide in the warehouse but I'm worried that the polygon count is too high.  I may have to generate my own dumbed down versions.
Offline Medeek
« Reply #70 on: June 04, 2017, 10:01:38 PM »
Added "FPSF" option to polygon slab-on-grade foundations:
Offline Medeek
« Reply #71 on: June 05, 2017, 12:07:49 PM »
An octagon slab on grade (FPSF).  Note that the angle of the corners is 225 degrees, any less and the corner treatment would go away.
Offline azgreg
  • Full Member
« Reply #72 on: June 05, 2017, 02:54:46 PM »
Do you plan to do anything with plumbing etc.?
Offline Medeek
« Reply #73 on: June 05, 2017, 08:12:12 PM »
Added "FPSF" option to polygon stemwall foundations.
Now I've thoroughly beaten the FPSF option to death, the only thing I might add in later is a global setting to change the insulation color to pink, blue or white.
Offline Medeek
« Reply #74 on: June 05, 2017, 08:14:38 PM »
Tell me more about plumbing or other features you would like to see with this plugin.  I still have a number of things I would like to add but I am slowly chipping away at the todo list.
Cache hits: 12: 0.00223s for 40,810 bytes (show)
Queries used: 28.
