Truss Calculators
0 Members and 27 Guests are viewing this topic.
Medeek
I've had a number of requests for monopitch or monoslope trusses.  Shown below is a sample of potential configurations of this type of truss.  Has anyone ever seen a (5/3) or (6/4) or a (3/1) monopitch truss?  The first number is the number of top panels and the second number is the number of bottom panels to clarify.
Nathaniel P. Wilkerson, P.E.
Medeek
The left and right overhangs can now be set independently, however the right overhang defaults to match the left overhang to help speed user input:
I've also created a new page for the plugin with some basic documentation:
http://design.medeek.com/resources/medeektrussplugin.html
Just an FYI, the energy heels are enabled fully for the fink truss but not for any other truss type and the TRIAL version is actually not limited in any way.  I will probably keep it that way until the plugin is significant enough to actually warrant charging for it.
Medeek
I'm testing the attic truss option. At the moment I've only got one configuration which is probably about right for an attic truss that spans about 24-28 feet. You can see below that pushing it out to span 36 feet is a bit of a stretch:
The piggyback option is enabled by enforcing a max. height in the inputs.
36' span, 18' attic width, 9' ceiling 12/12 pitch, 11-7/8" bottom chord.
Medeek
This is the same truss I used in my 28'x48' garage:
Now I need to work on the energy heel option for this truss.
Medeek
24' truss without a piggyback (Max. Height set to "NONE"). 2x6 TC, 2x10 BC, 2x4 overhangs.  12' attic width, 8'-1 3/4" attic height.
Medeek
22' truss, notice the change in the web configurations as compared to the 24' truss.
There still may be a few kinks to work out in the algorithm that determines how many webs to place but overall I'm pretty pleased with what I have so far.
I've officially added the attic truss updates to the plugin so they are now live.
Medeek
Trusses are now created as components with each individual member of the truss a group. Arrays of trusses are multiple instances of the same component.
I think this plugin may actually have some potential now.
A couple more screenshots for fun:
I need a break for a few days on this but when I come back to it I'll knock out monopitch trusses next.
Medeek
Howe truss type is now active.
The latest plugin version is 1.0.4.  I would highly recommend downloading the latest version since I have also spent some time this morning cleaning up my code and removing global methods and variables so that I don't clash with other extensions or modules.
Medeek
Monopitch trusses are also now live:
Currently the 2/2 and 3/3 configurations are available, more of this truss family will be added after I address the metric issue.
Medeek
I'm looking at adding in scissor trusses.  Below is a matrix of common scissor truss configurations.  Once they get much larger than a 6/6 I think they probably go to site assembled half trusses, I'm not entirely sure since I don't have any drawings or diagrams of anything larger than a 6/6.
I vaguely recall one with a girder truss ridge and half trusses but it was cut up with dormers onto that ridge as well.
Medeek
For the common truss types I've configured the plugin to detect the SketchUp template units and display a metric UI.  I've also replaced the x/12 system with degrees for the metric interface.  All member sizes and other dimensions are open for the metric interface as well.
Go ahead and give it a whirl, if it checks out then I will go ahead and update the attic and monopitch UI with the metric option.
Medeek
With the truss plugin I have been primarily focused on typical MPC wood trusses however the potential for other truss types does exist.  I'm wondering if some of the more exotic timber truss types can be codified in a similar way so that one can generate possible configurations and experiment with their design.
One interesting truss type that comes to mind is the Hammer Beam truss/frame as shown below:
Some other variants (an probably quite a few more):
The math is the same for heavy timber just the design values and magnitudes change.
A hammer beam is a broken truss, or rather it is not a truss. When they do not fail it is due to heavy walls, buttresses, or good diaphragm in the roof... it certainly isn't the hammerbeam's fault if the roof doesn't splay.
Medeek
I actually like to call them timber frames since the current practice seems to be  to frame up the wall posts with the upper section as one unit.  They are the crown jewel of the timber framing industry as one web site puts it.  The problem with them is the considerable outward thrust because the truss is "broken".  Typically these are quite custom so I'm not really interested in putting them into my truss calculator (load calcs are probably best run in RISA 3D) but it might be interesting to have them in my plugin just for the geometry and the ability to play with the variables that affect the look and feel of the truss.
I would call what is pictured in your drawings a "bent", it can be either timberframed or post and beam, depending on whether wood or steel connected, and there is plenty of room for generalizing in any of that. In bent frame construction a section slice is tipped up into place, these are connected by girts. Another method, box frame, would be more akin to platform framing. Posts, plates, and truss or common rafters on top of or integral with the plate.
Basically, If they can get a computer to draw it, they will build it.
The thrust has to be taken care of by some other means, that should be made clear somewhere in there. I went to one workshop where a topic was how to retrofit failing hammerbeams. He had plenty of pictures. They are a shining jewel but not on a cap I'd want to wear.
One way to build one is to incorporate a steel rod across the gap, you'll see that in most modern versions unless there is another bracing element like adjoining wings.
This is a good link if you don't already have it;
http://timberframeengineeringcouncil.org/library/#tech bulletions
Medeek
Quote from: Don_P on October 22, 2015, 08:11:41 PM
Unfortunately, I don't get a lot of timber frame engineering opportunities in this area so I probably haven't opened that publication in a while.  Looks like I've got some reading to do.
Medeek
I was thinking about adding the scissor truss family to my SketchUp plugin until I realized that the calculation of the scarf of the bottom chord was a bit more complicated than your typical common truss with a zero pitch bottom chord.  When I actually sat down and did the  math it became clear how much more complicated it actually was.  If anyone cares to check the math I would be very grateful.  I will probably run it into AutoCAD tomorrow and graphically check the geometry against the equation, they should give the same result.
Medeek
The equation was spot on, my faith in trigonometry is restored:
Version 1.0.5 - 10.24.2015
Added Scissor truss type, configurations: (2/2), (4/4).
Metric input enabled for scissor truss types.
Medeek
Version 1.0.6 - 10.25.2015
Added floor truss type, Modified Warren - System 42.
Metric input enabled for floor truss types.
Top and bottom bearing option enabled for left and/or right end of floor trusses.
Ribbon cut option (top) enabled for left and/or right end of floor trusses.
One central chase that can be position relative to the left end of the truss.  If the chase becomes closer than 1/4 the span to either end it will flag the user and re-position.  Also some logic to check the chase size to span ratio and absolute max. chase size (24").
System 42 or 32 floor trusses using the modified warren configuration which seems to be the most popular for this type of floor truss.  Top bearing configuration includes an additional slider for extra strength and a vert. Note the change in diagonal directions when comparing a top to bottom bearing floor truss, I was not aware of this until studying them in some detail.  Typical panel length is 28" but this can also be set by the user to any value.
Makes sense, I had never noticed, the first web becomes a tension member... if so I'm guessing quite a connection.
Medeek
Floor trusses 40' span, 60' bldg. length, 24" deep.
Notice these are top chord bearing trusses with the diagonal webs reversed from the bottom bearing trusses in the previous post, this is by design.
A few years back (when I was in college and working construction on the side) I remember framing up a custom home with these.  I don't think much over 40' is recommended but I could be wrong.  I'm curious as to what the longest span (clear span) anyone has seen with these type of floor trusses and what is the max. depth.
Medeek
Just out of sheer awe I have to post these two pictures I found at Select Trusses website:
My one worry with commercial buildings constructed using light frame construction is fire resistance.  This building wouldn't have a chance if a fire were to occur:
A quad fink truss (10/9) with a raised heel (slider):
Quote from: Medeek on October 26, 2015, 07:11:39 PM
............  This building wouldn't have a chance if a fire were to occur:
That nice latticework would be like the handful of twigs used to start a campfire.
Medeek
Quote from: MountainDon on October 26, 2015, 08:04:37 PM
Exactly what I was thinking, well aerated and the wood member size (kindling) would be a perfect fuel.  If a building like this were to catch fire it would burn very quickly and aggressively.
