Author Topic: Ideas for a lawn mower engine?  (Read 8708 times)
Offline Barry Broome
  • Full Member
  • Seminary, Mississippi
« on: December 26, 2012, 06:22:32 PM »
I have a good engine off a 22 inch push mower. The mowers deck is broke and we bought a riding mower. What can I use a 5 hp engine for? Any good ideas?
“The press, like fire, is an excellent servant, but a terrible master.”
Offline MountainDon
    • My 15.75 x 30 Jemez Cabin
Re: Ideas for a lawn mower engine?
« Reply #1 on: December 26, 2012, 07:00:33 PM »
Vertical shaft I assume?
Small generator?
Offline StinkerBell
  • CountryPlans member
« Reply #2 on: December 26, 2012, 07:37:53 PM »
Make a trailer dolly with it.
Offline MushCreek
« Reply #3 on: December 27, 2012, 03:08:55 AM »
Make an adapter so you can attach it to the lower unit of that small outboard that died. That way, you can have a noisy, inefficient outboard motor for only twice the cost of buying a good one.
Don't ask me how I know so much about this... d*
Jay
  • Full Member
« Reply #4 on: December 27, 2012, 03:34:05 AM »
Yes it's a vertical shaft. I did see some home made generators, that might be the best thing. I hate the just throw it away   :(
Offline Ernest T. Bass
  • "One in the same, 'Bass' is the name!"
    • Our Family's Blog (cordwood house building and homestead-related stuff)
« Reply #5 on: December 27, 2012, 06:13:15 AM »
You could beat me to my life's ambition and make a hovercraft.. :)
Offline MountainDon
« Reply #6 on: December 27, 2012, 06:29:54 AM »
I only had my heart half in it when I made my suggestion.   ;D  I think we should all listen to that. Probably lots of projects like that around just because someone had something they could not bear to throw out.  If it's hurting too much to dump it, then freecycle it.
Offline UK4X4
« Reply #7 on: December 27, 2012, 06:34:22 AM »
fit just right on your jon boat
Offline peternap
« Reply #8 on: December 27, 2012, 06:49:16 AM »
I've always thought about building one of those. Looks like you need a horizontal shaft though.
Offline UK4X4
« Reply #9 on: December 27, 2012, 07:24:46 AM »
http://www.amazonsupply.com/andantex-anglgear-universal-mounting-diameter/dp/B00852JJKM?ref_=goo_pf_B00852JJKM
Pretty sure your local Thai boat shop has some plumbing parts to use- or get similar to the above
the drive shafts on those thai boats are usually just thiick wall plumbing pipe !
Offline Don_P
« Reply #10 on: December 28, 2012, 08:01:26 PM »
I've got an old tiller motor in my Red Green pile I keep meaning to put on a little skid with a hydraulic pump, reservoir and quick connects. Use it for a universal power unit for a log splitter, engine hoist, winch, etc.
Offline MountainDon
« Reply #11 on: December 28, 2012, 09:01:25 PM »
Quote
Red Green
     ;D ;D
      "If the women don't find you handsome, they should at least find you handy."
Offline MushCreek
« Reply #12 on: December 29, 2012, 02:35:57 AM »
'Red Green pile'.... I like that! I usually just call it my 'yard art'.
Jay
Offline waggin
  • Foothills above Pugetropolis, WA
« Reply #13 on: December 29, 2012, 11:00:52 AM »
I (or should I say my property?) resemble that remark!
Offline muldoon
  • Muldoon, TX
« Reply #14 on: January 01, 2013, 04:49:55 PM »
Am I the only one who immediately thought go cart?
Offline NM_Shooter
« Reply #15 on: January 03, 2013, 08:06:18 AM »
I made a portable generator for my gun club.  They had a wobble trap that was served off of batteries only, and needed a way to quickly charge or run the thing off of a generator for shoots:
http://countryplans.com/smf/index.php?topic=5481.msg70555#msg70555
Offline NM_Shooter
« Reply #16 on: January 03, 2013, 08:13:24 AM »
BTW, auto alternators also don't shut off when you turn off power to the rotor.  Back emf keeps the thing producing power.  Alternators need a source of current to start working, but remove that initial current and they still keep working, so beware.  Also, put a switch on the rotor power, as this will allow you to start the motor with the charge wires hooked up to the battery.
Cache hits: 12: 0.00186s for 40,831 bytes (show)
Queries used: 28.
