Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
Home
Forum
Help
Search
Login
Register
CountryPlans Design/Build Forum
General
Owner-Builder Projects
(Moderators:
hpinson
Adam Raabe
Mtn Cabin in Nicaragua
« previous
next »
Print
Pages:
1
2
3
4
5
6
7
Go Down
Author
Topic: Mtn Cabin in Nicaragua (Read 69925 times)
alex trent
Junior Member
Re: Mtn Cabin in Nicaragua
Reply #150 on:
May 29, 2012, 06:08:43 PM »
Been raining pretty good. Had about 5 inches since May 15. Things still holding up and as the ground get saturated , the outside is draining pretty well too...we disrupted a lot of natural flow areas when we did the drive and the walk, so I worried about that. Put is a lot of drains under the walk and drive and in some places to intercept flows..as we are about 2/3 way down a pretty steep hill. The really heavy stuff is still to come but to now we look good and in a couple of places I have made some adjustments.
Mud is all around. The deck looks pretty humble. Did three coats of oil and then a transparent sealer. Still tough to clean...really have to scrub the mud/footprints with some soap to get them off. Any suggestions? A bit of wax?
The floor inside is just two coats of oil and nothing else...has a nice patina and is bait easier to deal with as we do a lot of feet wiping...I may try a bit of wax on it. Good idea?
Logged
rdzone
Senior Member
Reply #151 on:
May 30, 2012, 01:48:21 PM »
I wouldn't use wax on the floor if you plan to ever refinish it. It really messes things up as any new finish will not adhere.
Logged
Chuck
alex trent
Junior Member
Reply #152 on:
June 20, 2012, 11:48:44 AM »
Well, six months ago I could not find decent deep cell batteries. Two months ago I found some Trojan 105s, but they were old...almost two years, so waited.
Today went back and they had a bunch and different types. Decided on a AGM-31 as i know my predilection for letting maintenance things slip and theses will be indoors. will start with two..will be 200 AH, which is less than the two 105s at more money. But this gives me some flexibility as I can add a third easier than I can add to the six volt string.
So tomorrow I will be in business....the Marine battery has about given up the ghost...dies inn 20 minutes from full charge. but it served a good life...about 100 recharges from a 60-70 discharge. Went downhill all of a sudden.
I bought a good hygrometer, which I now do not need. Is there some other reasonably price way to test the batteries, or do i just rely on the charger to do its job automatically...
Logged
Administrator
Journeyman
Jemez Mountains, NM; that's pronounced HEY-mess
Reply #153 on:
June 21, 2012, 10:32:51 AM »
Voltage readings are the only way to gauge the charge of an AGM battery, but only after it has been sitting idle for a few hours, not under load or while being charged. That's the big thing I dislike about AGM's. A charging system with the bulk, absorb and float charge rates should keep the batteries at their best. The system should "float" every day. It should be adjustable to best suit the rates recommended by the battery mnaufacturer; frequently different when compared to a flooded lead acid battery.
Logged
Jens
Senior Member
Knoxville, TN
Reply #154 on:
July 09, 2012, 05:53:09 PM »
what a beautiful build! I'm sure it is said somewhere, though I couldn't find it, what kind of wood is it framed with?
Logged
alex trent
Junior Member
Reply #155 on:
July 10, 2012, 03:14:40 AM »
Thanks, this site had a lot to do with making it possible and you will see on here that i did a lot of work trying to get to the right wood and ascertain the properties.
Local name is Cedro macho. Scientific name is Carapa guianensis...called most commonly crab wood. Works great, good strength and other properties....in my book pretty much the wood of choice for building, but not much wood building here in the land of blocks and concrete. Pine can be used but most is pretty poor stuff and not used in quality construction, although I am going to attempt a small building with it.
The reddish wood...rafter ties and deck for example...... is Hymenaea courbaril...locally called guapinol. Hard and durable. Turns dark red when dry.
Logged
alex trent
Junior Member
Reply #156 on:
July 28, 2012, 05:06:47 AM »
I separate my grey water from my sewerage. We are pretty frugal water users, having to collect it ourselves. But this is the rainy season, so we dont watch it too much.
I was concerned that when we got in the heavy rains which we have and the ground got saturated i would have problems with the grey water, Over built to prevent that...have about a 600 gallon catchment, 4x4 feet lined with blocks with some spacing to drain out side and gravel on the bottom. It is on a bit of a slope , so I was prepared to put a French drain above it to divert ground water.
Turns out that there is no water in the pit..none at all. The 300 or so gallons we have used is gone into the ground. And nothing is coming in off the slope.
So, overbuilt it a bit, but no big deal. Am going to build another small cabin a bt away but in the same general area and this is good to know as will save work and materials.
Logged
alex trent
Junior Member
Reply #157 on:
July 29, 2012, 10:59:20 AM »
Stared today on a new smaller cabin not far away from the first one.
On pretty level ground...about 1 foot drop left to right. Much more sheltered location. View is up the mountain in back of the original place, not across the valley.
This will be on individual cut stone footings (18 x24 x6) that are sitting on top of gravel...15 in all...3 rows of 5. 6x6 on top of them and cut to level the place. Double 2x10 beams and then 2x8 joists at 16" spacing and on top of that 1" lumber. All this lumber is rough cut so 1" is 1". This is a prototype for a small ecolodge complex....maybe 6 or 8 of these scattered about with a central lodge.
Cabin is 22 x 16 including deck. Built in the lightweight style with no interior walls and rafters at 4 feet and studs the same. Actually this will remain a deck for 4-5 months using a tent for shelter.
Sewerage is still to be determined. Water will be off the roof of the main lodge...20x30 feet or so. In the meantime I am pumping water from my place up here...400 feet and a 40' rise to a 1500 gallon tank.
Should be a chinch compared to the first one...smaller and simpler. But experience is the main thing.
Last Edit: August 04, 2012, 12:52:22 PM by alextrent
Logged
alex trent
Junior Member
Reply #158 on:
August 04, 2012, 12:57:43 PM »
Had a 4.2 tremblor yesterday, shallow and about 20 miles away. Shook buildings in town. Not sure about up here, but people felt it as workers talked about it today. No apparent damage.
Had several very heavy rains....real worst is yet to come. Have one leaking screw in the roof. EZ place to get to and the leak is over the kitchen counter.
There is work to be done, but I am very poorly motivated . I come up, lay in the hammock and look out over th valley to the ridge on the other side. Not stunning, but peaceful and nice...good breeze.
Logged
Huge29
Full Member
Welcome to the CP-Forum
Reply #159 on:
August 22, 2012, 08:18:13 PM »
Very fun to watch the progress, thanks for sharing!
Having lived in Mexico, Yucatan Peninsula, for a couple of years it is cool to see somewhat similar climate. I can see how it would be difficult to find materials that are not what they normally use, mainly concrete...where are the hamacas?
Logged
duncanshannon
Senior Member
Reply #160 on:
September 17, 2012, 05:37:42 AM »
Just checking in... everything progressing down there?
Logged
Home: Minneapolis, MN area. Land: (no cabin yet) Spooner, WI area. Plan: 20x34 1 1/2 Story. Experience Level: n00b.
Build Thread:
http://countryplans.com/smf/index.php?topic=10784.0
lodestar
Junior Member
homesteader
Reply #161 on:
October 20, 2012, 08:01:53 AM »
I worked with UNICEF in 88/89 based out of Matiguas and into the mountains along the border with Honduras...also spent a good deal of time in Pearl Lagoon north of Bluefields...interesting.
Know anything more recent about those areas?
Logged
Be the change you wish to see in the world...
~Gandhi
BAdams
Apprentice
Reply #162 on:
March 20, 2016, 09:33:11 AM »
This post appears to be abandoned. I remember looking at it some time ago and found it quite interesting. I am considering building off grid in the usvi and was thinking of doing something similar to this. The pictures appear to be deleted. Does anyone know if it's possible to view them somewhere else?
Logged
Administrator
Journeyman
Reply #163 on:
March 20, 2016, 09:57:56 AM »
The personal photo archive where the OP kept the images is no longer active, so no.
Logged
BAdams
Apprentice
Reply #164 on:
March 20, 2016, 10:36:57 AM »
Thank you MountainDon. I'm sure I'll find something similar. Thanks for the quick reply.
Logged
Print
Pages:
1
2
3
4
5
6
7
Go Up
« previous
next »
General
(Moderators:
hpinson
Adam Raabe
Templates: 5:
index (default)
Ads (default)
Portal (default)
Display (default)
GenericControls (default)
Sub templates: 12:
init
html_above
adsheaders_above
body_above
adsindex_above
portal_above
main
portal_below
adsindex_below
body_below
adsheaders_below
html_below
Language files: 3:
SPortal.english (default)
index+Modifications.english (default)
Ads.english (default)
Style sheets: 1:
portal (default)
Files included: 38 - 1132KB. (
show
./index.php
./Settings.php
./Sources/QueryString.php
./Sources/Subs.php
./Sources/Errors.php
./Sources/Load.php
./Sources/AnnoyUser.php
./Sources/Subs-Portal.php
./Sources/Security.php
./Sources/LoadAds.php
./Sources/Subs-Db-mysql.php
./cache/data_d24618a1818abee563d06e77cfd8fbe6-SMF-modSettings.php
./Sources/ManageSearchEngines.php
./cache/data_d24618a1818abee563d06e77cfd8fbe6-SMF-spider_search.php
./cache/data_d24618a1818abee563d06e77cfd8fbe6-SMF-board_parents-0.php
./cache/data_d24618a1818abee563d06e77cfd8fbe6-SMF-permissions--1.php
./Sources/Subs-Auth.php
./cache/data_d24618a1818abee563d06e77cfd8fbe6-SMF-theme_settings-1.php
./Themes/default/languages/SPortal.english.php
./Themes/default/index.template.php
./Themes/default/languages/index.english.php
./Themes/default/languages/Modifications.english.php
./Themes/default/Ads.template.php
./Themes/default/languages/Ads.english.php
./cache/data_d24618a1818abee563d06e77cfd8fbe6-SMF-log_online-update.php
./Sources/PortalBlocks.php
./SSI.php
./Themes/default/Portal.template.php
./Sources/Display.php
./Themes/default/Display.template.php
./Sources/Subs-Editor.php
./Themes/default/GenericControls.template.php
./cache/data_d24618a1818abee563d06e77cfd8fbe6-SMF-verificationQuestionIds.php
./cache/data_d24618a1818abee563d06e77cfd8fbe6-SMF-parsing_smileys.php
./Sources/AutoEmbedMediaPro2.php
./cache/mediaprocache.php
./cache/data_d24618a1818abee563d06e77cfd8fbe6-SMF-response_prefix.php
./cache/data_d24618a1818abee563d06e77cfd8fbe6-SMF-moderator_group_info.php
Cache hits: 12: 0.00196s for 40,845 bytes (
show
get modSettings: 0.00050s - 15639 bytes
put modSettings: 0.00025s - 15639 bytes
get spider_search: 0.00009s - 1882 bytes
get board_parents-0: 0.00010s - 6 bytes
get permissions:-1: 0.00007s - 75 bytes
get theme_settings-1: 0.00012s - 2017 bytes
get log_online-update: 0.00011s - 13 bytes
get verificationQuestionIds: 0.00017s - 18 bytes
get parsing_smileys: 0.00019s - 5427 bytes
get response_prefix: 0.00012s - 11 bytes
get moderator_group_info: 0.00015s - 118 bytes
get menu_buttons--1-english-1: 0.00006s - 0 bytes
Queries used: 28.
