Wall Plugin for SketchUp
Medeek Engineering
First look at quoins applied to Custom walls.
Nathaniel P. Wilkerson
Medeek Engineering
#1051
Version 4.6.9 - 07.16.2026
- Enabled advanced options for Custom walls.
Currently the custom wall draw tool requires that a face be draw and then selected to draw a custom wall. I think I also need to allow for a point-by-point polyline method. I will give this some further consideration tomorrow.
I also think it might be convenient to be able to switch a rectangular wall to a custom wall, however the ability to switch back will be disabled or disallowed since a custom wall will potentially have too many points that define it so it can't be cleanly converted back into a rectangular profile, I will need to give this some additional thought.
Medeek Engineering
Tutorial 92: Custom Walls - (14:47 min)
Medeek Engineering
Version 4.7.0b - 07.20.2026
- Added a floating grid to the Custom wall draw and profile edit tool when the "Grid Snap" option is toggled on.
Medeek Engineering
The API connector/bridge seems to be working, just need to do some more testing and also add the roof:
Medeek Engineering
Version 4.7.2 - 08.31.2026
- Updated the opening move tool with additional construction dimensions.
- Updated the column move tool with additional construction dimensions.
- Fixed a minor bug in the stair module (riser materials).
