OKLAHOMA 20X30 SINGLE STORY
1 Member and 18 Guests are viewing this topic.
Mrdecatur217
He Todd,You done real good.  Glad you found this sight so that dad and I can watch your progress.  If we lived closer, I'm certain dad would be right along side you helping out  :) [cool]
astidham
#26
google maps updated this week, however i removed the pictures because they were not working right
— Henry Ford
astidham
Got to the building site today and had some company
I cut all my 6x6 post to a general size put them in the brackets
i used the water level to mark all of them level to each other and cut them
after installing I fastened them with 16 galv nails and 10 galv nails because i didnt have enough of the 16s for all of them
— Henry Ford
Mrdecatur217
astidham
Got 1 beam built today, it started good but the ending result looks to be 1/4th to 1/2" height different on some of the 2x12s in the beam,
i will put the best side up for the floor joist
— Henry Ford
John_M
That is a huge and HEAVY beam to transport to the jobsite!!  Why not just make it there?
Just curious... ???
astidham
You are right John_M, they are heavy.
I built them at my house because i work 2nd shift and can only do so much at a time.
my property is about 30 minutes from my house, so only an hr round trip but my house is closer to work.
im not real sure how we will get these loaded... ???
— Henry Ford
dug
On almost all lumber there is a slight, or sometimes not so slight warp along the edge (called a crook I think) which should be positioned up in most cases. Depending on the pier spacing it probably won't make a difference but I think it would be good practice for future beams, joists, rafters, etc.
astidham
Thank you dug I will keep that in mind when im building #2.
your beams look flawless
— Henry Ford
Dug is right on...even the terminology  [cool] Crook is a hockey stick, bow is the side planking of a boat.
Put crown up on everything, if one person is cutting and others working we put an arrow on the face pointing up to the crown edge. Even walls laying on the deck are crowned all in the same direction so you don't end up with back and forth crowns down the length of the wall.
If you have one, I very often power plane the top edge of built up girders to get a truer surface to work from.
dug
Quoteyour beams look flawless
Thanks! That's nice to hear, however while sometimes photos can expose things you never noticed, they can also mask flaws. Mine are not perfect, but will do.
If I had the full kit (power planer Don mentioned) that would have been real nice. Lumber may be sold as 8, 10 12 in. etc., but those numbers are just an approximation.
Sometimes I dream of a giant disc sander, 50 ft. in diameter that is mind controlled and can produce a perfectly flat plane on any surface. Should I be worried?
Native_NM
I've seen them tow huge steel beams before.  They attach an axle to one end and a tongue to the other.  Hmmm....   ;D
If you ever get that disc sander worked out, let us know. Could be a helpful tool :D :D :D
astidham
— Henry Ford
While the beams look nice I'm envious of the green lawns.
Now I want to see how the beams get moved.
astidham
Im wondering how also, i will take pics...
— Henry Ford
astidham
loaded the beams today,we first put them on a industrial 4 wheel dolly
we wheeled them to the trailer and winched them up
they only had a little overhang...lol
we moved the beams to the cabin site, how will we get them off the trailer?
we will manhandle them, with the tractor
all of this was directed by my daughter Leilani
— Henry Ford
Mrdecatur217
well now i believe you should have an easy time from this time on,., just kidding but you have a great start,.,.dad
dug
Nice use of tools moving those beams! I don't think it would have gone so smoothly had it been me doing the job. :-[
Mrdecatur217
 ??? i see who the boss is and she is so cute gota love her
astidham
dug it went smoother than we thought it would, i cant believe how heavy those beams are each.
— Henry Ford
astidham
Quote from: Mrdecatur217 on June 19, 2010, 11:14:07 PM
she rules the roost  :)
— Henry Ford
astidham
— Henry Ford
astidham
I have the beams temporary in place.
— Henry Ford
