Diary of a 20x24 cabin going up in NH
Started by cockergod18, May 18, 2006, 05:11:25 PM
Hardware cloth is the wire screen that is welded and galvanized - comes in 1/4" squares and 1/2" squares - other sizes.
peteh2833
Dave, what did you do to fire proof behind the woodstove???
Pittsburgh Pa for home
Tionesta Pa for Camp
nickolekidd
Wow this all looks great keep up the great post.
Nickole  :)
It's better to have tried and failed then to have never tried at all!!!!!!!!
Nickole
dmlsr
we put cement board screwed to the studs ,then a 1 inch air gap .We cut strips of the cement board to make up the gap. then more cement board. I hope that is clear for u
This cabin is being built in memory of my father Robert and my granfather Henry.
Thank you for looking
Dave
dmlsr
Dave
peteh2833
Ya, everything looks good. You screwed a piece of cement board to the studs then ripped down pieces to use as spacers then screwed another piece of cement board to the spacers. Sound right.....
dmlsr
Dave
peteh2833
Thanks Dave. I'm starting the framing on my place on Monday. If I have any ?'s do you mind if I ask??? Pete
dmlsr
Dave
deedonke2
dave,you got to be proud of the work and great turn out on your cabin/camp.looks awesome,congradulations.may have miss it but what did you use exterior board/batten,and interior walls.loved the idea on angle/iron for beam ties what size?Ito am planning to build a cabin in north louisanato live in.I plan on using some of your ideas hope you don'T MIND also me asking question THANKS!!!!
darrell
Great idea with the cement board, Dave.  Gap at the bottom for air flow to enhance cooling too, I assume.
dmlsr
#336
deedonkes
The angle iron is 2x2x6. It was alot of work and cost a lot of $$$$ but i would do it again. The outside is 12 inch roughcut with 2 inch batten. Inside is also 12 inch but is planed smooth. Use as many ideas as you like. cant wait so see your place
Glenn
It was open at first but  the stones dont really get the warm so when i completed the cement it got filled in
Dave
peteh2833
Dave, How far apart did you space your loft floor joists and what size flooring in the loft did you use? It looks like 3/4 flooring. Thanks Pete
dmlsr
16 on center and rough cut planed both sides down to 3/4 inch
Dave
peteh2833
Would you recommend planing both sides. I was going to plane only the floor side.
I believe that falls into the category of personal choice. Unplaned would be more rustic and would soak up more finish.    ???
peteh2833
dmlsr
we did both sides so that the floor would be even to walk on . We did not want to be banging our toes and or triping .
Dave
peteh2833
Thanks. I haven't decided yet on rough cut 2x6 material or T&G 2x6. I was told by John R that I need to use the 2x6 T&G to make the floor one structual unit.
peteh2833  2 by T&G is nice but I have found one draw back.  Normally during milling they will hold the V groove tighter to the planer and the surface is uniform. There is usually a little difference in elevation on the flooring side.  Not that much but still noticable.  Same goes for the flooring side of the T&G.  The V-groove fits pretty good but the flooring or flat side not as tight with gaps.  You can't draw them any tighter because the T&G have already bottomed out.
Remember that any unplained surface will hold dust and dirt.  Not a big issue now but later it might be important when you try to keep it clean.  In addition the wear factor of rough lumber is not as good as protected finish not to mention splinters if they are in an area where you would be in contact with it.
peteh2833
I was going to use rough cut 2x8 with it planed on the floor side and leave the underside rough. Would it be ok to use 2x8 that isn't T&G?
The problem with anything that will be movement of the planks as they "work" with walking across and other movement. They also will not form as strong a floor.
The inevitable shrinking will also cause gaps between planks here and there. That will cause dirt to filter down below.
They will do as Don said - I have full 2x material on the bridge between the kitchen and bedroom - some wider than 12" and it does move without the TG.  The gap is also a problem as we will have a root cellar below one section.
peteh2833
Ok thanks for the info. The 2x8 without the T&G is alot cheaper though. I don't think the amish mill can put a tongue and groove on it.
