Wall Plugin for SketchUp
Medeek
Version 3.8.6 - 01.25.2025
- Added tread covers, carpet and stair runners for T-shaped landings.
- Enabled the option for a single stringer (for modern style stairs).
- Added an option to disable the placeholder for landing/winder framing.
- Added a "GLASS" option for balusters within the built-in baluster materials.
- Added a "None" built-in option for the handrail profile parameter.
Nathaniel P. Wilkerson, P.E.
Medeek
Tutorial 64 - Modern Stairs (12:43 min.)
Medeek
Version 3.8.7 - 01.28.2025
- Enabed subtractive geometry for all stair assemblies.
- Added the following two parameters to the baluster sub-menus: Baluster Type (Square, Round, Glass, Cable), Baluster Height.
- Enabled intermediate posts for both glass and cable railing.
- Added the following cable railing options into the Stairs tab of the Global Settings: Cable Railing Spacing, Cable Railing Diameter.
- Added a bottom vertical offset parameter for bottom posts of a stair run.
Tutorial 65 - Cable and Glass Railing (13:26 min.)
Medeek
Version 3.8.7b - 01.29.2025
- Fixed a bug with the baluster options.
- Enabled a zero stringer option for floating stairs.
Medeek
Just a few more loose ends before I jump back to the Floor plugin.
I would like to enable landing treads for winders, but things get a little interesting when the min. winder length is set to zero.  Does this look okay?
Medeek
Version 3.8.8 - 02.06.2025
- Added landing treads, tread covers, carpet and stair runners for a winders.
- Added an SIP wall framing option for all wall types.
- Added five additional SIP parameters into the wall Draw and Edit menus.
Tutorial 66 - SIP Walls (8:03 min.)
Medeek
Version 3.8.8b - 02.06.2025
- Added the option for closed stringers.
Medeek
Version 3.8.9 - 02.09.2025
- Added preview thumbnails for handrail fittings to the draw and edit menus of the stair tool.
- Fixed a bug with adjacent winders/landings for landing treads and covers.
- Fixed a minor bug with materials for handrail fittings.
Medeek
Version 3.9.0 - 02.11.2025
- Enabled zero size intermediate posts (balusters) for glass railing.
- Fixed a bug with floor level winders/landings for landing treads and covers.
Medeek
Version 3.9.0d - 02.14.2025
- Fixed a floating point rounding bug for metric templates.
- Fixed a bug for balusters when a run of stairs is a single step.
Still putting out a few little fires.  Whenever you make big changes it always seems like you miss something or you add a new feature that adds a whole new level of complexity, and then the plugin gets itself into states that you did not foresee.  That is what makes this job fun, you get surprised once in a while.
Please feel free to send me any additional bug reports or feature requests.  I think we've just about wrapped up the stair module for a while.
Medeek
Version 3.9.1 - 02.23.2025
- Added the following (48 - low poly) Simpson post caps to the post module: CC1210, CC718_718, CC718_8, CC718_6, CC718_4, CC514_8, CC514_6, CC514_4, CC462_550, CC462_462, CC462_362, CC314_6, CC314_4, CC128, CC126, CC106, CC98, CC96, CC94, CC88, CC86, CC84, CC78, CC77, CC76, CC74, CC68, CC66, CC64, CC48, CC46, CC44, CC6_718, CCO4, CCO6, CCO7, CCO8, CCO9, CCO10, CCO12, CCO46, CCO314, CCO462, CCO514, CCO718, ECC64, ECC66, ECC68.
This update per customer request.
I still need to add in the rest of the ECC series, so there is always more to do.
Medeek
**Version 3.9.2** - 03.15.2025
- Enabled an edge material/texture for built-in gypsum wall materials.
Medeek
Here are a some new renderings of an Inverted Tee landing using the newly upgraded stair module. A huge shout out to @patrick.c.obrien for these amazing images and for all of his efforts in helping me debug this module during the month long process of updates and additions:
Medeek
Version 3.9.3 - 03.29.2025
- Added the following Simpson Strong-Tie holdowns to the wall, column and shearwall modules: DTT1Z, LTTP2, LTTI31.
- Added the following Simpson Strong-Tie holdowns to the wall, column and shearwall modules: HD3B, HD5B, HD7B, HD9B, HD12, HD19.
- Updated the wall and column modules so that they include all previous holdowns that were added to the shearwall module.
I think I now have added every common holdown used for walls and columns that is found in the Simpson Catalog [Wood Construction Connectors 2024-2025] (pg. 51-65).
Quote from: Medeek on March 22, 2025, 02:37:32 AMHere are a some new renderings of an Inverted Tee landing using the newly upgraded stair module
Impressive renderings!
Is that a whale?
Medeek
Quote from: MountainDon on March 31, 2025, 08:20:45 PMImpressive renderings!
Is that a whale?
Yes, that is a Killer Whale.  The fellow that did these renderings actually used my artwork in his model:
www.wilkersonart.com
Medeek
Version 3.9.4 - 04.04.2025
- Added the following Simpson Strong-Tie header hangers to the door module: HH4, HH6.
- Enabled header hangers for all door headers.
Note that Simpson only manufactures two standard header hanger sizes (HH4 and HH6).  However there are quite a few more options for CFS framing.  If there is any interest I can add those hangers as well upon request.
Quote from: Medeek on April 04, 2025, 03:36:14 AMYes, that is a Killer Whale.  The fellow that did these renderings actually used my artwork in his model:
I like that.    [cool]
Medeek
Version 3.9.5 - 04.19.2025
- Enabled a zero thickness apron for style B window casing.
- Included additional logic for vertically offset sheathing and cladding.
Both of these updates per customer request.
I have been taking care of some miscellaneous items on my **todo** lists for both the Truss and Wall plugin before I dive back down the rabbit hole that is currently the Floor plugin.  Once I jump back into that one I may not emerge again for a couple months so I thought it best that I take care of a few requests first.
Medeek
- Added a "Union Door Gypsum" and "Union Window Gypsum" option into the Sheathing tab of the Global Settings.
- Enabled "seamless" gypsum for gypsum wrapped windows and doors.
Note the difference between the two windows below:
Medeek
Version 3.9.7 - 04.30.2025
- Added a "Chord Angle" output parameter for arched doors and windows within their respective HTML menus.
- Added glulam and steel columns into the in-wall column module for all wall types.
- Enabled a wood grain and an end grain material for glulam columns within the in-wall column module.
- Added a "right" hand slider window and updated the existing slider name to be a "left" hand slider window.
Medeek
Version 3.9.8 - 05.04.2025
- Added the Connect Corner tool to the Medeek Wall Tools II toolbar.
- Updated the Opening Copy tool with the left and right hand slider window.
- Fixed a specific bug related to glulam columns with a vertical offset equal to the wall bottom plate thickness.
Tutorial 69 - Connect Corner Tool (9:12 min.)
Medeek
Version 3.9.9 - 05.09.2025
- Updated the Connect Corner tool to work with non-orthogonal walls.
- Fixed a bug with the in-wall column tool for gable walls.
- Enabled Advanced Framing Options within the window module.
- Added the Advanced Framing Options parameter within the Windows tab of the global settings.
- Fixed the callout for right handed slider (OX) windows.
- Enabled zero stool extensions and zero stool projections for all window casing options.
