install toilet in water free cabin
Started by robbscabin, April 28, 2014, 06:37:25 PM
robbscabin
just purchased a hunting cabin. cabin has a outhouse but also had a toilet in inside bathroom,with toilet flange and pipe runnig 30ft to ouside outhouse pit. how can i set this up besides just getting 5 gallon jug and pouring water to flush. can i get a large container of water and run hose from water container to toilet or can i use a pump and rig something up for a couple days of hunting season so i can flush inside toilet. i need someone who is creative,thank you
Quote from: robbscabin on April 28, 2014, 06:37:25 PM
Sounds as if you are flying completely under the radar so to speak.   ;)  Well I can tell you what I have seen done and it works well.
Used a 250 gallon fuel tank sit on legs on the exterior.  A plumbing line was used from the bottom of the tank to the tank of the toilet.  It was all gravity fed. Float activated just like a regular toilet.   A little slower filling the tank of the toilet but when filled it operated basicly the same as a regular plumbed toilet.  One advantage this individual had was that it was located near a stream so once a week or so he used a generator/pump to draw water up from the creek to fill the tank.   But he had a septic tank of sorts whereas you will only have a small pit so I would imagine that it will fill up pretty fast when to add 2 gallon of water to it each time it is used.
Another obsticle will be if it is used in low temperatures and the feed line/tank freezing up.
