Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
Home
Forum
Help
Search
Login
Register
CountryPlans Design/Build Forum
General
General Forum
(Moderators:
hpinson
Adam Raabe
1/2 bath upstairs in victoria's cottage
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: 1/2 bath upstairs in victoria's cottage (Read 4653 times)
rdzone
Senior Member
on:
September 27, 2005, 07:51:12 AM »
I have several plans from this site and I am working with my supervisor (read wife) to decide which plan to build. She is leaning torward Victoria's cottage, but with no upstairs bathroom she is unsure. Has anyone put a small 1/2 bath in upstairs or thought about it. I think it would work out OK. Any thoughts or suggestions would be appreciated. Thanks.
Chuck
Logged
Chuck
Daddymem
Journeyman
Ahmpit of the Cape, MA
Re: 1/2 bath upstairs in victoria's cottage
Reply #1 on:
September 27, 2005, 08:45:35 AM »
My grandmother has a log cabin in New hampshire with a narrow upstairs with one bedroom and no sanitary facilities upstairs, similar to the Victoria's Cottage. She solved the problem by installing a tiny sink and a small toilet right in the bedroom and put up a screen in front of them. I thought it was funny at first, but then realized she only needed to use it when she woke up in the middle of the night, so it made perfect sense. I have no idea if codes would prevent you from building this, but she did it anyways.
Logged
Aide-moi à les retrouver.
rdzone
Senior Member
Reply #2 on:
September 27, 2005, 09:11:46 AM »
Daddymem,
I am not really worried about the codes as this would be a recreational cabin here in Alaska and not in an area that has any codes. I do like the idea of a small sink and toilet upstairs mainly for the reasons you mentioned. It would keep who ever is sleeping upstairs from having to trek downstairs in the middle of the night.
Last Edit: September 27, 2005, 09:12:43 AM by rdzone
Logged
Chuck
Daddymem
Journeyman
Reply #3 on:
September 27, 2005, 11:59:06 AM »
In her words "I would die without those." Might require some boxing in if you go with exposed beams downstairs....or clever placement of the pipes. Good luck! Hey! Eagle River, I've been there! Out near Fort Rich, no? Stopped on a hellacious road trip from Fairbanks to Anchorage. It chose to drop to almost -60F on that trip and I had to keep stopping along the way because the heater in my car couldn't keep up with it. I almost died that trip...one stall out and I would been a goner. There was ice
inside
my windshield. I think I knew a few kids from there as well, I'll have to check my old address book.
Logged
rdzone
Senior Member
Reply #4 on:
September 28, 2005, 05:34:26 AM »
Yep thats the place near Fort Rich. I have had several of those trips up here, scraping Ice off the inside window.
not much fun.
Logged
Chuck
Administrator
Journeyman
Whidbey Island, WA
Reply #5 on:
September 28, 2005, 05:35:06 AM »
Space wise you should have no problem working out this bathroom. You might want to consider a wall hung toilet as you can probably install it without having the P-trap stick down through the decking.
Logged
Micky
Junior Member
Reply #6 on:
September 28, 2005, 07:04:03 AM »
I am about ready to rough in the plumbing in my 20x32 1-1/2 story. I used the 4x12 beams on 4' centers w/ t&g decking as John detailed in the plans.
I am following the same approach as John mentioned to hide the plumbing. However, I am using a floor mount back outlet toilet. This accomplishes the same thing as the wall hung, but I am finding the prices are more reasonable and they don't look as industrial.
I am also installing a shower. I think this may be a little more tricky. My original thought is find a pan that is tall enough to put the plumbing under it without having to go through the floor. Then I could put the p trap into the same wall as the toilet.
I think this would also work for your setup.
I would appreciate anyone’s input on the shower idea....
Last Edit: September 28, 2005, 07:08:40 AM by Micky
Logged
The Troglodyte
Administrator
Journeyman
Central California Sierras- Home of Yosemite NP
Reply #7 on:
September 28, 2005, 12:23:57 PM »
You could frame a box under a normal pan to give clearance or build your own pan using a vinyl or PVC liner and cement/sand with tile or natural rock-- like in the old days before fiberglass.
Logged
Glenn's Underground Cabin
http://countryplans.com/smf/index.php?topic=151.0
rdzone
Senior Member
Reply #8 on:
September 29, 2005, 05:24:34 AM »
Micky,
I like your design. One quick question what brand/manufacturers floor mount back outlet toilet are you planning on using. I looked on the web yesterday and found many of the industrail looking ones, but no real residental looking toilets.
I hadn't thought about a shower, but if I was to do one upstairs and maintain the wood plank floor. I would have to agree with Glenn and build a box to give enough clearance for the p-trap without punching a hole in the floor.
The only other option I can think of is to try and stack the bathrooms (upstairs over downstairs) and frame the ceiling in the downstairs bathroom to allow for the upstairs fixtures.
Logged
Chuck
The Troglodyte
Administrator
Journeyman
Reply #9 on:
September 29, 2005, 06:28:56 AM »
One other option to save a little room would be to put the p-trap in the wall with only a 90 el coming out under the pan shower strainer with the pipe sloped to the p-trap in the wall then vent off a tee in the wall also. I think that would still be legal and save 3 or 4 inches.
Logged
Micky
Junior Member
Reply #10 on:
September 29, 2005, 07:39:29 AM »
There was a few I was looking at:
American Standard makes a model called the Youkville.
http://www.americanstandard-us.com/pdfs/as/install/Install_145.pdf
Gerber:
http://www.gerberonline.com/catalog.aspx?categoryID=2220&itemID=2765
My local distrubitor can get a briggs toilet for about $250. However, I have not heard good things about Briggs.
http://www.briggsplumbing.com/products/pdp.asp?cid=1&pid=86
Glen, I think the picture was trying to show what you are talking about. If I can put the trap in the wall, I would only have to raise the shower a few inches versus 6".
Logged
Administrator
Journeyman
Whidbey Island, WA
Reply #11 on:
September 29, 2005, 07:44:42 AM »
Micky:
Thanks for the info on the plumbing options. I don't think a single step up onto the shower pan will be any problem at all.
Logged
The Troglodyte
Administrator
Journeyman
Reply #12 on:
September 29, 2005, 07:52:46 AM »
Silly me, Micky. Here I was trying to be brilliant and you already were. I hadn't noticed the picture solution. Half the time I'm not awake. The rest of the time I'm sleepy. :-/
Logged
Senior Member
1000', Southeast, USA.
Reply #13 on:
September 29, 2005, 11:05:12 AM »
An insulated outside piping chase is another option if door or window openings are not in the way. Can be boxed in chimney-like.
Works especially well with wall-mounts. All traps can be enclosed in the chase if you make the outside chase wall "fake" and removable.
Last Edit: September 29, 2005, 11:07:49 AM by JRR
Logged
Print
Pages: [
1
Go Up
« previous
next »
General
General Forum
(Moderators:
hpinson
Adam Raabe
Templates: 5:
index (default)
Ads (default)
Portal (default)
Display (default)
GenericControls (default)
Sub templates: 12:
init
html_above
adsheaders_above
body_above
adsindex_above
portal_above
main
portal_below
adsindex_below
body_below
adsheaders_below
html_below
Language files: 3:
SPortal.english (default)
index+Modifications.english (default)
Ads.english (default)
Style sheets: 1:
portal (default)
Files included: 38 - 1124KB. (
show
./index.php
./Settings.php
./Sources/QueryString.php
./Sources/Subs.php
./Sources/Errors.php
./Sources/Load.php
./Sources/AnnoyUser.php
./Sources/Subs-Portal.php
./Sources/Security.php
./Sources/LoadAds.php
./Sources/Subs-Db-mysql.php
./cache/data_368b6252d53cc949945f95b43ba1cc58-SMF-modSettings.php
./Sources/ManageSearchEngines.php
./cache/data_368b6252d53cc949945f95b43ba1cc58-SMF-spider_search.php
./cache/data_368b6252d53cc949945f95b43ba1cc58-SMF-board_parents-0.php
./cache/data_368b6252d53cc949945f95b43ba1cc58-SMF-permissions--1.php
./Sources/Subs-Auth.php
./cache/data_368b6252d53cc949945f95b43ba1cc58-SMF-theme_settings-1.php
./Themes/default/languages/SPortal.english.php
./Themes/default/index.template.php
./Themes/default/languages/index.english.php
./Themes/default/languages/Modifications.english.php
./Themes/default/Ads.template.php
./Themes/default/languages/Ads.english.php
./cache/data_368b6252d53cc949945f95b43ba1cc58-SMF-log_online-update.php
./Sources/PortalBlocks.php
./SSI.php
./Themes/default/Portal.template.php
./Sources/Display.php
./Themes/default/Display.template.php
./Sources/Subs-Editor.php
./Themes/default/GenericControls.template.php
./cache/data_368b6252d53cc949945f95b43ba1cc58-SMF-verificationQuestionIds.php
./cache/data_368b6252d53cc949945f95b43ba1cc58-SMF-parsing_smileys.php
./Sources/AutoEmbedMediaPro2.php
./cache/mediaprocache.php
./cache/data_368b6252d53cc949945f95b43ba1cc58-SMF-response_prefix.php
./cache/data_368b6252d53cc949945f95b43ba1cc58-SMF-moderator_group_info.php
Cache hits: 12: 0.00234s for 40,795 bytes (
show
get modSettings: 0.00041s - 15558 bytes
put modSettings: 0.00039s - 15558 bytes
get spider_search: 0.00014s - 1882 bytes
get board_parents-0: 0.00020s - 6 bytes
get permissions:-1: 0.00019s - 75 bytes
get theme_settings-1: 0.00024s - 2017 bytes
get log_online-update: 0.00014s - 0 bytes
get verificationQuestionIds: 0.00013s - 143 bytes
get parsing_smileys: 0.00020s - 5427 bytes
get response_prefix: 0.00014s - 11 bytes
get moderator_group_info: 0.00015s - 118 bytes
get menu_buttons--1-english-1: 0.00002s - 0 bytes
Queries used: 29.
