Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
Home
Forum
Help
Search
Login
Register
CountryPlans Design/Build Forum
Plans Support
Plans Support
(Moderators:
Adam Raabe
Build Up Beam Question
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Build Up Beam Question (Read 8213 times)
Micah
Junior Member
on:
August 30, 2009, 07:25:05 AM »
I cannot get 4"x6"x14' beams so Im going to take Johns advice an make my own. Heres my problem. I have 2"x6"x14' boards but I have no way to transport a beam of that size. Could I do this instead? Cut the 14' do to 9' and 5' and assembly them like this
9' 5'
5' 9'
With 1/2" ply between. Then assemble when i get to my site. The directions (Here
http://www.countryplans.com/builtupbeam.html
) say "each joint in the joists no closer than 4' from another joint". With this spacing I have 4' between ends so I should be ok right?
Also do I need to seal the cut side of the osb so it doesn't expand if it gets wet?
Logged
diyfrank
Senior Member
Re: Build Up Beam Question
Reply #1 on:
August 30, 2009, 07:58:15 AM »
Your cuts or joints need to be placed where they land over the center of your posts or piers. If they are placed at a point that is not supported, you have lost the strength of the beam.
Logged
Home is where you make it
Micah
Junior Member
Reply #2 on:
August 30, 2009, 08:06:41 AM »
See thats what I thought to. Good thing I asked. Looking at the plans I could get them in half since there is a pier right in the middle. Do I need any special brackets to join them together?
Logged
diyfrank
Senior Member
Reply #3 on:
August 30, 2009, 08:42:56 AM »
I don't think you need any special bracket but you need some way to connect them to your piers.
I'm not sure what your building. If your using one of johns plans He or someone that is familiar with your plan can be more specific.
Logged
Micah
Junior Member
Reply #4 on:
August 30, 2009, 10:03:10 AM »
Im building the 10x14 from the Little House Plan. My foundation is going to be Sona tube with a PT 4x4 post.
Logged
Bob S.
Full Member
CountryPlans member
Reply #5 on:
August 30, 2009, 10:22:44 AM »
Micah,
Have you thought about possibly renting a trailer so as to be abel to transport the 14' boards? This would be a onetime expense and might solve the problem.
Logged
Micah
Junior Member
Reply #6 on:
August 30, 2009, 10:33:33 AM »
I actually have a trailer but no way to tow it. I had to get rid of my truck a few months ago to get a mini van. Its hard to cart 4 kids around in the front seat of a truck
If I had the money I would rent a Uhal but that would cost $230.
Logged
Micah
Junior Member
Reply #7 on:
August 31, 2009, 06:46:47 AM »
Anymore input about cutting the beams to 7' ? Here is a picture of how I plan to do the foundation
Only im using a 4x4 post in an 8" sona tube 30"+ in the ground.
Logged
Administrator
Journeyman
Whidbey Island, WA
Reply #8 on:
August 31, 2009, 11:55:26 AM »
I would build these on-site and get at least one of the joints to land on the posts. Since this is only two laminations, if you have to have two cut lines at the same place then you have to be over a post. Make sure the splice is well nailed into both 2xs.
Personally I would do what you show in your diagram and with good nailing and some glue you don't need to worry if all the joints are over the posts. They work as a composite beam.
Logged
Administrator
Journeyman
Jemez Mountains, NM; that's pronounced HEY-mess
Reply #9 on:
August 31, 2009, 01:57:31 PM »
The method I used to get every single beam joint to all over a pier involved some small amount of waste. I cut the component pieces to such lengths that allowed the joints to fall directly over a pier. Worked or me. Sme of the cut offs were used other places like for blocking.
I built the 30 foot long beams on site, right on top of the piers where they were going to stay. I actually built them slightly long and then trimmed them off after each beam was complete. That was easier than trying to lift the completed beam into place and trimming to length made it easier to get to precisely the required length and squareness.
Logged
Micah
Junior Member
Reply #10 on:
August 31, 2009, 03:23:52 PM »
Awsome 9 and 5 foot it is. What about sealing the piece of OSB in between? Should I worry about that expanding?
Logged
Administrator
Journeyman
Whidbey Island, WA
Reply #11 on:
September 01, 2009, 05:33:20 AM »
Probably not a bad idea to paint or seal the beam ends and tops where they might be exposured to wind and rain.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Plans Support
Plans Support
(Moderators:
Adam Raabe
Templates: 5:
index (default)
Ads (default)
Portal (default)
Display (default)
GenericControls (default)
Sub templates: 12:
init
html_above
adsheaders_above
body_above
adsindex_above
portal_above
main
portal_below
adsindex_below
body_below
adsheaders_below
html_below
Language files: 3:
SPortal.english (default)
index+Modifications.english (default)
Ads.english (default)
Style sheets: 1:
portal (default)
Files included: 38 - 1132KB. (
show
./index.php
./Settings.php
./Sources/QueryString.php
./Sources/Subs.php
./Sources/Errors.php
./Sources/Load.php
./Sources/AnnoyUser.php
./Sources/Subs-Portal.php
./Sources/Security.php
./Sources/LoadAds.php
./Sources/Subs-Db-mysql.php
./cache/data_d24618a1818abee563d06e77cfd8fbe6-SMF-modSettings.php
./Sources/ManageSearchEngines.php
./cache/data_d24618a1818abee563d06e77cfd8fbe6-SMF-spider_search.php
./cache/data_d24618a1818abee563d06e77cfd8fbe6-SMF-board_parents-0.php
./cache/data_d24618a1818abee563d06e77cfd8fbe6-SMF-permissions--1.php
./Sources/Subs-Auth.php
./cache/data_d24618a1818abee563d06e77cfd8fbe6-SMF-theme_settings-1.php
./Themes/default/languages/SPortal.english.php
./Themes/default/index.template.php
./Themes/default/languages/index.english.php
./Themes/default/languages/Modifications.english.php
./Themes/default/Ads.template.php
./Themes/default/languages/Ads.english.php
./cache/data_d24618a1818abee563d06e77cfd8fbe6-SMF-log_online-update.php
./Sources/PortalBlocks.php
./SSI.php
./Themes/default/Portal.template.php
./Sources/Display.php
./Themes/default/Display.template.php
./Sources/Subs-Editor.php
./Themes/default/GenericControls.template.php
./cache/data_d24618a1818abee563d06e77cfd8fbe6-SMF-verificationQuestionIds.php
./cache/data_d24618a1818abee563d06e77cfd8fbe6-SMF-parsing_smileys.php
./Sources/AutoEmbedMediaPro2.php
./cache/mediaprocache.php
./cache/data_d24618a1818abee563d06e77cfd8fbe6-SMF-response_prefix.php
./cache/data_d24618a1818abee563d06e77cfd8fbe6-SMF-moderator_group_info.php
Cache hits: 12: 0.00167s for 40,836 bytes (
show
get modSettings: 0.00026s - 15641 bytes
put modSettings: 0.00023s - 15641 bytes
get spider_search: 0.00010s - 1882 bytes
get board_parents-0: 0.00009s - 6 bytes
get permissions:-1: 0.00009s - 75 bytes
get theme_settings-1: 0.00015s - 2017 bytes
get log_online-update: 0.00022s - 0 bytes
get verificationQuestionIds: 0.00008s - 18 bytes
get parsing_smileys: 0.00017s - 5427 bytes
get response_prefix: 0.00012s - 11 bytes
get moderator_group_info: 0.00013s - 118 bytes
get menu_buttons--1-english-1: 0.00003s - 0 bytes
Queries used: 29.
