Don,Did you see the simplyphi batteries in the Wind Sun Store. Still pricey but 24V option is there.
What are your thoughts about putting the inverter, and possibly the charge controllers inside the cabin vs in the porch with the batteries?
What do you think of using a bus like this to provide 12vdc power to multiple devices?
https://www.delcity.net/store/100A-MiniBus-Common/p_807936.h_807937What do you think of using a bus like this to provide 12vdc power to multiple devices? I have a 24v to 12v converter that I use to power a 12v ceiling fan, some 12v fans in the composter room and my car stereo. Today I just wire nut everything to the output (12v) on the converter but I'm looking for a clean way to provide power and thought that I could two of these to provide + and - connections to each device.With two buses I could land the fans etc on each buss and then provide the power connections to the buss frm the converter. Should be a cleaner way to do this and allow me some more connections.Thoughts? Any suggestions? Truth is I was looking for a toggle gang switch I could provide power to on one side and then multiple toggles for each item (so I could then just turn them on or off).
