Photobucket One-Click-Copy Problem
Started by MountainDon, October 28, 2008, 12:20:19 AM
Photobucket is experiencing a problem with it's One-Click-Copy feature. They are aware that many users are finding it no longer works as meant to. The problem is being associated with Flash 10. The Photobucket gurus are apparently working on a solution. Until then use the "right click - copy" method or try highlighting and Ctrl+C.
hmm I wondered what made that work.  Mine is still working though.
We have one computer where it still works.  :(  Mine, which does have flash 10 does not.   >:(
Where do you find out you flash version?
Follow this link
http://kb.adobe.com/selfservice/viewContent.do?externalId=tn_15507
There may be other ways, but this is simple enough I can do it with one hand   [crz]
Thanks, Don.  I have 9.0.115.0  - guess I should keep it a while.
Whitlock
Don, I have the flash 10 and was having problems with the photo bucket a few days ago.
When I did a system restore on my coputer eveyting was fixed ???
When you run that flash version test link, does it still say you have version 10 or did the restore take you back to a previous version?
I had a quick look at photobuckets self-help forum and found several references to the flash ten = one-click not working.
Whitlock
Took me back to a previous version. I restored the computer to Oct.1st.
I downloaded the flash uninstaller and ran it. Restarted the system. Downloaded the flash 9 archive and installed the latest version 9 (WIN 9,0,124,0) and now the One_Click_Copy in photobucket works again.  :)
Whitlock
