Propane Cabin Heater
Started by stagalv, December 06, 2004, 05:32:00 PM
stagalv
In my 12x16' cabin I have a Dearborn propane heater.  The propane tank is outside and a gas line runs through the wall to the heater.  It is a really nice, 20,000BTU heater and works great.
I am wondering about sleeping with a heater like this on.  I know that carbon monoxide poisoning is a big concern.
As long as all lines are safely connected with no leaks is it ok to sleep with this on all night?  I do have a carbon monoxide detector and there is a 16' wide ridge vent on the roof.
Thoughts?  Is it way too unsafe?
Ray N
 I just put a propane heater in the basement of my vacation home.   I went the Direct Vent route where combusion air and exhaust are expelled to the outside.  I did however look into the "ventless" ones which I guess you have.
Things I remember:
--- some states it is not allowed in a sleeping area. Even though it may be approved for Bedroom use by somebody.
--- "blue flame" units are sold lots of places for ventless indoor heat.
--- people have died by doing stupid propane stuff like bbqing indoors,  wher they weren't even asleep or using it for a long period of time.
--- A carbon monixide detector isn't a bad idea no matter where or what system you have.
So I think you have reason for concern especially in a small space.  Check with the manufacturer, insulate to reduce its use, add a small wood stove for "over night heat" all come to mind.
BPellow
I used to manage some rental property with them in them and have come not to trust the detectors whatsoever.  I strongly discourage sleeping while using this type of heat- the problem while sleeping is you might not realize your being poisoned until it is to late.
I've used portable propane and kerosine heaters in houses in Nashville and a propane heater here.   All very leaky situations--not just conduction.  No problems.  Although with cats and dogs inside, I don't leave them on when I'm not in and awake.
But my neighbors up the hill tried to heat their house with a big 5-plaque heater (radiant, not blue flame) and ended up taking it out.
Why?
Their floors stayed wet.  When the products of combustion are CO(2 we hope) and water, and you are elderly and want the place REALLY VERY WARM, then there's just too much water being produced and staying in the house.  Of course they may not have had much insulation under the house.
I've no idea if they could have heated to 68 degrees instead of 78 degrees without problems.
DavidLeBlanc
Takes air from outside and returns exhaust air back outside using coaxial flue. Optional 12 V fan (included - the option is using or not using it). CO safety shutoff. Available in "small" and "large" (BTU's) sizes.
Current price, about $775 for the small one; about $100 more for teh bigger one. Includes stove, flue, backing plate.
http://www.dickinsonmarine.com/shop5/shopdisplayproducts.asp?catalogid=30
DavidLeBlanc
#5
Maybe these links will work better!
Modified to add: nope! ??? It's www.dickinsonmarine.com - somehow it shows up on the forum as www.thingyisonmarine.com ???
Gaaaaaaa! Dic kinson - turn off the stupid naughty words thingy!
(From John - I can edit this post and see the image and link work in the preview. It doesn't work when saved, however.)
Didn't have not thingys on the original URL.  Heck with it. ???   >:(    :-[
It was, however, a Newport Propane Fireplace P-9000  And it's a direct vent.
There is a problem with the links above and it is not your fault. I think the issue lies with the word censor.
Here is a link to the stove using TinyURL (which gets around the censored words in the url).
http://tinyurl.com/4lt58
See if this Tinypic hosting of the image posts:
I will see if I can turn off the word censor and test that. Let me know if you have further problems.
[glb]Success![/glb]
I have turned off the word censor and the images and links now post. I'm not too worried about profanity on this board. If it gets out of hand we can always add censorship back in (it is turned on by default).
[glb]Added bonus - [/glb]Now Glenn and I can talk about "male enhancement products" all we want!
Thanks for your patience and let me know if there are further problems.
DavidLeBlanc
Two questions, John
1.  Do we need to start our male enhancement discussion under a different subject heading? ??? Although I think it may be too late for any improvement for me,  my wife already thinks I am perfect ;D
2.  If I actually mean to use the word "thingys" in a real posting, will it be translated back to a naughty word now that the censor is off ???
