Author Topic: Just how straight is kiln dried lumber?  (Read 554 times)
Offline lacazet2k
  • Newbie
  • Welcome to the CP-Forum
« on: March 09, 2020, 11:06:09 PM »
So, we finally got some land. And got it paid off. Now it's time to buckle down and settle on a house plan on details. Is kiln dried whitewood straighter than SYP? Is it worth the extra money? The reason I'm asking is because I want 12-14 foot sidewalls for a little extra headroom upstairs rather than building a short pony wall on a platform upstairs (I'm told that would create a "hinge-point"). I'm trying to get an estimate of how much lumber and how much money it'll take to frame up a 20x24 or 24x24 building.
Offline Don_P
Re: Just how straight is kiln dried lumber?
« Reply #1 on: March 10, 2020, 02:59:50 AM »
Hmmm... where to begin. They will both more than likely be kiln dried to 19% moisture content. The wood will finally be at equilibrium moisture content with the local environment somewhere between 8-12%. Wood moves mainly due to changes in moisture content. Denser stronger woods generally move more than less dense weaker woods. SYP is denser and stronger than SPF.
As to the rest of that, at the top of those extended sidewalls is a roof that needs to be properly tied or supported, hinge or not, those studs will not stop the spreading thrust of an improperly conceived roof system. Post a section pic of your thoughts.
Offline paul s
  • Full Member
  • CountryPlans member
« Reply #2 on: April 13, 2020, 02:49:46 PM »
Some good thinking, I am now looking at off grid properties, and am thinking of building a 12x36 shed roof 'cabin'.
I want rodent proof floor.  So... double the bottom wall plate, floor is joists and 3/4 " plywood.  On top of floor is laid 3/4" rigid foam insulation,  on top of that another 3/4" layer of plywood.not a big r  value but a continuous  one.  Thoughts on this please.
Ty
Paul
Offline Don_P
« Reply #3 on: April 14, 2020, 03:55:50 AM »
Certainly better than an uninsulated floor. I've done that with a plank and beam second floor in a timberframe house to help control sound. In my climate to meet energy codes with continuous insulation I believe it would take R-10 which would be 1-1/2" thick xps but any insulation is better than no insulation and if this is a seasonal small building that certainly factors in.
Offline paul s
  • Full Member
« Reply #4 on: April 15, 2020, 09:01:54 AM »
Ty for the response, well stated.
Paul
Offline paul s
  • Full Member
« Reply #5 on: May 18, 2020, 01:09:04 PM »
With this stay at home thing. Been really thinking,  and rethinking.
And I am thinking 16x16, gable roof,5/12 roof truss.
Not sure weather precut studs for 8' or 9' ceilings..
Less cutting = faster  building,
My dad built 5 cabins in his day. Biggest was  24x36
Always divisible  by 4!!
I know I still have to cut, crown and inspect each piece of wood, .
 I would like bigger but going to keep it very simple.
I can add on later.
Paul
Offline Don_P
« Reply #6 on: May 18, 2020, 04:09:05 PM »
Quote
I can add on later.
With those wall heights and a shallow roof pitch you are certainly limited in addition options/methods, plan for that carefully.
Offline paul s
  • Full Member
« Reply #7 on: May 19, 2020, 01:39:14 PM »
Good point, what ever I have, will be smallish.
Ty
Cache hits: 11: 0.00136s for 40,772 bytes (show)
Queries used: 29.
