Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
Home
Forum
Help
Search
Login
Register
CountryPlans Design/Build Forum
General
General Forum
(Moderators:
hpinson
Adam Raabe
Building a severely simple house!!!
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Building a severely simple house!!! (Read 2022 times)
paul s
Full Member
CountryPlans member
Re: Building a severely simple house!!!
Reply #25 on:
March 11, 2020, 12:24:57 PM »
Batten, board and battegot it spelled right this time!!
Logged
Journeyman
Reply #26 on:
March 11, 2020, 03:35:56 PM »
There's almost always qualifiers it seems like. Watch the dimensions of the framing members as spans change as well.
Logged
paul s
Full Member
CountryPlans member
Reply #27 on:
March 12, 2020, 06:07:48 PM »
Batten, is a better spelling
I think 2x6 floor joists, studs cut so 8 foot plywood goes to of top of the top plate to bottom of floor joist, makes plywood siding simple, but gives 88 inch ceiling height
Nice open floor to fabricate roof trusses, 5/ 12 pitch, really 22.5 degrees, make cutting easy
Wide eaves built into trusses
Adjust eaves for easy plywood application, 8, 10, 12. 14 ft pliss gap for ridge vent!!!!
Logged
paul s
Full Member
CountryPlans member
Reply #28 on:
March 12, 2020, 06:19:42 PM »
Logged
Journeyman
Reply #29 on:
March 13, 2020, 04:15:10 AM »
There is where I was going with things to think through. a 2x6 floor joist spans around 8' so there would need to ba rows of girders and footings at those intervals, a 2x12 can span around 16' so that is one way to hop over that pier and beam cost at the expense of larger joists. And then I've been up to about 24' clear span on engineered joists, just more stuff to mull over.
Logged
akwoodchuck
Senior Member
Homer, AK
Reply #30 on:
March 13, 2020, 09:56:17 AM »
You can get T-111 siding in longer lengths than just 8' too....
Logged
1201
Junior Member
Welcome to the CP-Forum
Reply #31 on:
March 13, 2020, 06:40:29 PM »
Great discussion guys.
88 inch cooling height is way too low.
I'm looking at minimum 9 ft ceiling height.
Thanks akwoodchuck.i was wondering if t 1 11 is available at longer heights. Good to know it is. I'm revisiting it as an option just because it saves a step. Anything that saves labor should be looked at.
Logged
Dave Sparks
Senior Member
Offgrid Solar
Reply #32 on:
March 14, 2020, 09:40:31 AM »
I have done the solar power systems on over 250 offgrid homes around the planet. Many are like the folks asking here for ideas.
My top 3 for advice.
#1 Build something that is marketable. People want a minimum 3bd 2ba or the ability to do that later. Expandable needs to be thought out on a smaller than normal design.
#2 Build something that is not overly expensive if you ever want to recoup. Stay in the median price range. Offgrid homes can be hard to get loans on and to sell.
#3 Build something that is legal and meets the norm for your location. If it is not inspected take pictures of each stage.
Logged
paul s
Full Member
CountryPlans member
Reply #33 on:
April 13, 2020, 04:33:34 PM »
Re: Just how straight is kiln dried lumber?
« Reply #2 on: Today at 02:49:46 PM »
QuoteModifyRemove
Some good thinking, I am now looking at off grid properties, and am thinking of building a 12x36 shed roof 'cabin'.
I want rodent proof floor. So... double the bottom wall plate, floor is joists and 3/4 " plywood. On top of floor is laid 3/4" rigid foam insulation, on top of that another 3/4" layer of plywood.not a big r value but a continuous one. Thoughts on this please.
Ty
Paul
Btw 3 great things above
Logged
paul s
Full Member
CountryPlans member
Reply #34 on:
April 15, 2020, 09:07:47 AM »
Dave sparks, soo good those three, I will keep them in mind,
I went to school, SUNY @ Buffalo, 1976, industrial engineering, likely not you, Paul S
Logged
Print
Pages:
1
2
Go Up
« previous
next »
General
General Forum
(Moderators:
hpinson
Adam Raabe
Templates: 5:
index (default)
Ads (default)
Portal (default)
Display (default)
GenericControls (default)
Sub templates: 12:
init
html_above
adsheaders_above
body_above
adsindex_above
portal_above
main
portal_below
adsindex_below
body_below
adsheaders_below
html_below
Language files: 3:
SPortal.english (default)
index+Modifications.english (default)
Ads.english (default)
Style sheets: 1:
portal (default)
Files included: 37 - 1132KB. (
show
./index.php
./Settings.php
./Sources/QueryString.php
./Sources/Subs.php
./Sources/Errors.php
./Sources/Load.php
./Sources/AnnoyUser.php
./Sources/Subs-Portal.php
./Sources/Security.php
./Sources/LoadAds.php
./Sources/Subs-Db-mysql.php
./cache/data_9f70634b6e7b3f086ac216efb52639ee-SMF-modSettings.php
./Sources/ManageSearchEngines.php
./cache/data_9f70634b6e7b3f086ac216efb52639ee-SMF-spider_search.php
./cache/data_9f70634b6e7b3f086ac216efb52639ee-SMF-board_parents-0.php
./cache/data_9f70634b6e7b3f086ac216efb52639ee-SMF-permissions--1.php
./Sources/Subs-Auth.php
./cache/data_9f70634b6e7b3f086ac216efb52639ee-SMF-theme_settings-1.php
./Themes/default/languages/SPortal.english.php
./Themes/default/index.template.php
./Themes/default/languages/index.english.php
./Themes/default/languages/Modifications.english.php
./Themes/default/Ads.template.php
./Themes/default/languages/Ads.english.php
./cache/data_9f70634b6e7b3f086ac216efb52639ee-SMF-log_online-update.php
./Sources/PortalBlocks.php
./SSI.php
./Themes/default/Portal.template.php
./Sources/Display.php
./Themes/default/Display.template.php
./Sources/Subs-Editor.php
./Themes/default/GenericControls.template.php
./cache/data_9f70634b6e7b3f086ac216efb52639ee-SMF-verificationQuestionIds.php
./cache/data_9f70634b6e7b3f086ac216efb52639ee-SMF-parsing_smileys.php
./Sources/AutoEmbedMediaPro2.php
./cache/mediaprocache.php
./cache/data_9f70634b6e7b3f086ac216efb52639ee-SMF-response_prefix.php
Cache hits: 12: 0.00164s for 40,706 bytes (
show
get modSettings: 0.00021s - 15635 bytes
put modSettings: 0.00030s - 15635 bytes
get spider_search: 0.00012s - 1882 bytes
get board_parents-0: 0.00013s - 6 bytes
get permissions:-1: 0.00008s - 0 bytes
put permissions:-1: 0.00018s - 75 bytes
get theme_settings-1: 0.00010s - 2017 bytes
get log_online-update: 0.00013s - 0 bytes
get verificationQuestionIds: 0.00012s - 18 bytes
get parsing_smileys: 0.00015s - 5427 bytes
get response_prefix: 0.00009s - 11 bytes
get menu_buttons--1-english-1: 0.00003s - 0 bytes
Queries used: 30.
