Author Topic: A small deck that is fairly fireproof.  (Read 754 times)
Offline Dave Sparks
  • Offgrid Solar
    • Offgrid Solar
« on: February 26, 2019, 12:25:36 PM »
I am starting a small deck that I want to be fire safe. I do not want to use metal as this will be near sleeping rooms and I already have a metal roof that makes plenty of noise in the rain.
I was thinking of  a fireproofing coating I could roll onto wood. The other way would be to use fibrous cement on top of the underlayment.
Any good ideas would be appreciated.
Offline MountainDon
    • My 15.75 x 30 Jemez Cabin
Re: A small deck that is fairly fireproof.
« Reply #1 on: February 26, 2019, 04:11:23 PM »
A framework of https://en.wikipedia.org/wiki/Weathering_steel. No need to paint it at all. Plus concrete; blocks, bricks, poured, or precast and prestressed floor panels.  I don't know what the costs would be but a fire wouldn't do much to it.
Offline Dave Sparks
  • Offgrid Solar
    • Offgrid Solar
« Reply #2 on: February 27, 2019, 07:29:43 AM »
Thanks Don, Interesting but I do not want to hear the sound of rain on it below me as I already get the metal roof sound above me :(
I probably will just build with sticks and plywood and put a lay of fibrous cement on top. The deck will not really be walked on and is a way to get solar hot water panels in a better location that can drain back below for cold season.
Offline MountainDon
« Reply #3 on: February 27, 2019, 09:31:53 AM »
Ah!
Offline DaveOrr
  • Living In The Land Of The Midnight Sun
    • The Arctic Angler
« Reply #4 on: February 27, 2019, 06:12:43 PM »
Sigmadek
Aluminum frame with porcelain deck boards.
All you need is $$$$$.   :)
https://www.sigmadek.com/
Offline Don_P
« Reply #5 on: February 28, 2019, 02:24:22 AM »
More often than not decks ignite from below, debris and blowing embers. Heavy timber? it actually performs better in fire than unprotected metals. Spancrete and sonotube? Just throwing ideas around.
Offline Dave Sparks
  • Offgrid Solar
    • Offgrid Solar
« Reply #6 on: February 28, 2019, 06:38:40 AM »
Yes this is very true in the fires we have had go through here. One of the fireman said the plastic decks that are a composite are the thing he fears the most. A regular Redwood deck is fine as long as what you said is true about underneath.
Offline jeepj667
  • Apprentice
  • Welcome to the CP-Forum
« Reply #7 on: February 28, 2019, 09:45:49 AM »
In order to meet Wildland Fire code my deck had to be made with heavy timber structure and 2x decking.
Offline Don_P
« Reply #8 on: March 01, 2019, 03:54:23 AM »
Your firefighter friend echoes my concerns. We were taking a break on a new plastic deck we had built. I had tried burning a cutoff and it was excellent fuel. So there we are sitting in front of the designated egress on a moat of fuel between the structure and escape, not sure I understand how that gets passed.
Offline Dave Sparks
  • Offgrid Solar
    • Offgrid Solar
« Reply #9 on: March 01, 2019, 06:54:23 AM »
Where are you Don? We have been 2X or larger out here in California for a long time.
 One deck has 2X and plywood underneath (to keep area underneath dry) that I plan to remove and go to metal if I lose my fire insurance. We have lost insurance 3 out of the last 10 years due to cost. On the years we lose it, I just use the money to harden something else or buy another pump. We can have 3 pump failures and still have spare :P
Do you guys think there is a way to safely secure a 3 x 5 piece of fiber cement under a deck to keep the area dry?
Offline Dave Sparks
  • Offgrid Solar
    • Offgrid Solar
« Reply #10 on: March 01, 2019, 06:56:32 AM »
Where are ya please?
Offline NathanS
  • NY Mountains
« Reply #11 on: March 01, 2019, 08:39:06 AM »
Just curious, a raised slab is definitely out of the question?
I am pretty sure the cement board will not last very long on it's side outdoors. It is not rated for that anyway.
Offline Don_P
« Reply #12 on: March 01, 2019, 12:57:51 PM »
Dave, I'm in the Blue Ridge in VA.
I was meaning the technical definition of heavy timber, 5x and thicker framing members.
 If you put metal roofing canted under the framing that would drain moisture from above, then if you want fiber cement under that use 4x8 sheets of hardie flat panel or they make a soffit panel meant for horizontal applications up to 2'x12' long.
Offline Dave Sparks
  • Offgrid Solar
    • Offgrid Solar
« Reply #13 on: March 01, 2019, 03:00:17 PM »
Where are you getting the horizontal part Don? The existing deck is 2 x6 framing with redwood 2 x 6 deck on vertical 4 x 6 poles in cement.
I have underneath plywood to keep my cats dry and the door area dry. I can easily mount metal under there to do the same thing.
I was wondering instead how I would use hardie board and safely mount it 9 feet above where people and cats walk? A frame I guess???
Maybe the metal is best as I can use it to collect more rain ::)  Beautiful area Blue Ridge!
Offline DaveOrr
    • The Arctic Angler
« Reply #14 on: March 05, 2019, 06:42:32 PM »
Dave, just screw the cement/Hardie board on like you would drywall inside.
Screws on 12" spacing will hold up fine.
Offline JRR
  • 1000', Southeast, USA.
« Reply #15 on: March 08, 2019, 06:28:26 AM »
Wouldn't vertical metal flashing attached to sides of wooden members add some fire retardant?   If sides and tops of beams/joists were covered in flashing or foil before decking added, there would be resistance to rain and fire added... I would think.   Especially if the side metal were extended low enough to form "drip legs".  ??
« Last Edit: March 08, 2019, 12:50:46 PM by JRR »
Offline Dave Sparks
  • Offgrid Solar
    • Offgrid Solar
« Reply #16 on: March 09, 2019, 03:01:31 PM »
I am thinking on both of the replies. It sometimes is better to sleep on it :P
Offline Dave Sparks
  • Offgrid Solar
    • Offgrid Solar
« Reply #17 on: March 15, 2019, 06:15:00 AM »
I want to do this! The thought of that weight (underside of a deck falling on me) and then the inevitable cracking and water leaks down on my winter firewood storage and cat homes makes met want to go with a light metal corrugated. Probably needs to cover 20 feet x 4 feet so (2) 10 foot lengths and be sloped a 1/4" per foot to drain out the end.
Any different  ideas  are welcome as this is a summer project. Thx!
Offline glenn kangiser
  • The Troglodyte
    • Underground Cabin
« Reply #18 on: April 22, 2019, 09:22:02 AM »
Dave, I'm thinking of doing some stucco in various places. You could use your corrugated overhead to keep your wood dry and get the water to a drain on one side. Vertical stucco walls around the perimeter are pretty fireproof as well as cheap if you do your own. We have a deck on our rental that is a firetrap.
I have used the burlap and cement (like stucco- CBRI medium duty concrete floor) around the old pool and I think it would work as a deck cover with added Fibermesh.... Although it would not be the rich man's choice, it is a low cost option. 😊
Offline Dave Sparks
  • Offgrid Solar
    • Offgrid Solar
« Reply #19 on: April 23, 2019, 11:11:14 AM »
Thanks Glen! The corrugated metal under the redwood deck is what I am going to do, if I lose fire insurance, again...... :(
Cache hits: 13: 0.00215s for 40,801 bytes (show)
Queries used: 30.
