Wall Plugin for SketchUp
0 Members and 21 Guests are viewing this topic.
Medeek
Version 3.5.4b - 03.09.2024
- Enabled a pressure treated end grain material for bottom plates of all walls.
- Enabled end grain materials for in-wall columns.
- Enabled end grain materials for beams.
- Enabled end grain materials for blocks.
- Enabled end grain materials for posts.
Nathaniel P. Wilkerson, P.E.
Medeek
Version 3.5.5 - 03.11.2024
- Added a "Custom Glass" garage door type/option with fully customizable glass panels.
- Further refined the end grain material positioning for top plates (rectangular walls) and in-wall columns.
I will need to create a tutorial video explaining the proper syntax for the "Glass List".
Medeek
Medeek Wall Plugin **Tutorial 47** - Custom Glass Garage Doors (w/ Webcam)
https://youtu.be/EOZ_GB0hfWc
Medeek
#903
Version 3.5.6 - 03.21.2024
- Added built-in "Taped" and "Green Taped" gypsum materials for all wall types.
- Updated and added additional tool tips within the Global Settings.
Medeek
Version 3.5.7 - 04.17.2024
- Fixed a compatibility bug with SketchUp 2024 while maintaining compatibility with previous versions of SketchUp.
Medeek
Version 3.5.8 - 04.25.2024
- Fixed a bug with cripple studs over windows and doors.
- Fixed a bug with the copy wall tool.
Medeek
Version 3.5.9 - 05.01.2024
- Added a rainscreen option for gable walls (vertical, horizontal, 45 and 135 degree).
- Added a rainscreen option for shed walls (vertical, horizontal, 45 and 135 degree).
- Added a rainscreen option for hip walls (vertical, horizontal, 45 and 135 degree).
- Updated the license verification system with a more secure and improved algorithm.
Medeek
Version 3.6.0 - 05.04.2024
- Added the ability to create custom "Vertical Shiplap" wall cladding materials within the Material Library.
- Enabled "3D" Vertical Shiplap wall cladding for all wall types: Rectangular, Gable, Shed and Hip.
This update per customer request.
Medeek
Version 3.6.1 - 05.13.2024
- Added Symbol 2 Layer specfically for 2D door swing symbols (Layer tab of the global settings).
Medeek
Version 3.6.2 - 05.14.2024
- Enabled wall sheathing 2 statistics for the Medeek Estimating Module.
- Fixed a bug with wall presets and the wall sheathing 2 option.
Medeek
Double sliders are kind of interesting windows.
Sometimes I forget how cool it is to be able to create something like this in SketchUp and have it animate like it does. Can I say I love my job?
Medeek
All of the rectangular window types with their elevation swing/open lines:
Medeek
Version 3.6.3 - 06.06.2024
- Enabled elevation swing/opening lines for doors and windows.
- Added elevation swing line annotation settings to the Door tab of the Global Settings.
- Added elevation swing line annotation settings to the Window tab of the Global Settings.
- Enabled opening and closing for all double hung type windows.
Medeek
Tutorial 48 - Elevation Swing Lines (8:31 min.)
Medeek
Version 3.6.4 - 06.08.2024
- Added the following additional Wide Flange (W) beams to the beam module: W10X49, W10X54, W10X60, W10X68, W10X77, W10X88, W10X100, W10X112, W12X45, W12X50, W12X53, W12X58, W12X65, W12X72, W12X79, W12X87, W12X96, W12X106, W12X120, W12X136, W12X152, W12X170, W12X190, W30X90, W30X99, W30X108.
- Added the following Simpson Strong-Tie heavy girder hangers to the beam hanger library: HGUS2.75/10, HGUS2.75/12, HGUS2.75/14, HGUS3.25/10, HGUS3.25/12, HGUS412, HGUS5.25/10, HGUS5.25/12, HGUS5.5/8, HGUS5.5/10, HGUS5.5/12, HGUS5.5/14, HGUS7.25/8, HGUS7.25/10, HGUS7.25/12, HGUS7.25/14.
- Allowed the use of a period "." in custom beam hanger library names.
Medeek
Version 3.6.5 - 06.12.2024
Added the following Simpson Strong-Tie heavy girder hangers to the beam hanger library: HGUS5.62/10, HGUS5.62/12, HGUS5.62/14, HGUS6.88/10, HGUS6.88/12, HGUS6.88/14, HGUS7.37/10, HGUS7.37/12, HGUS7.37/14, HGUS26, HGUS26-2, HGUS26-3, HGUS26-4, HGUS28, HGUS28-2, HGUS28-3, HGUS28-4, HGUS210, HGUS210-2, HGUS210-3, HGUS210-4, HGUS212-3, HGUS212-4, HGUS214-3, HGUS214-4, HGUS5.25/10, HGUS46, HGUS48, HGUS410, HGUS412.
Medeek
Tutorial 49 - Component Libraries (13:05 min.)
Medeek
Version 3.6.6 - 06.24.2024
- Added hardware (caps and bases) options to the post module.
- Updated the material/color parameter for (exterior) wall trim to include custom materials.
Medeek
Version 3.6.6b - 06.24.2024 thru 06.25.2024
- Fixed a minor bug with the post cap positioning algorithm.
- Added the following Simpson post cap: APL6
Medeek
Version 3.6.7 - 06.27.2024
- Updated the post module to include multi-part installations for Simpson heavy angles (post cap).
- Added the following Simpson heavy angles to the post module: HL33, HL35, HL35G, HL37, HL37G, HL43, HL46, HL46G, HL49, HL49G, HL53,HL55, HL55G, HL57, HL57G, HL73, HL76, HL76G, HL79, HL79G
Medeek
Version 3.6.8 - 06.28.2024
- Added the following built-in ICF (block) materials: Nudura, Fox Blocks.
- Added the following Simpson column bases to the post module: CPT44Z, CPT66Z, CPT88Z
Medeek
Version 3.6.8b - 06.30.24
- Updated the built-in ICF materials to include the manufacturer's logo.
- Added the follwing Simpson post base: ABW44.
Medeek
Version 3.6.9 - 07.23.2024
- Enabled "Remove Cladding Lines" for 3D cladding materials.
Medeek
Version 3.7.0 - 07.25.2024
- Added a duplicate wall check to the regen module for all wall types.
Tutorial 51 - Duplicating Walls (6:15 min.)
Medeek
Version 3.7.1 - 09.17.2024
- Added a vertical offset parameter for in-wall column king studs.
In the case where you have a beam pocket and king studs over top of a door or window this update is critical.  Previously the king studs would simply project to the bottom plate in the wall passing through the opening.  Now you can utilize this extra parameter to vertically offset these king studs the same way the column itself is offset.  Note that the offset can be both positive or negative or zero (default)
