Wall Plugin for SketchUp
0 Members and 16 Guests are viewing this topic.
Medeek
Version 2.9.0 - 07.07.2022
- Added the following window types to the window module: Double Hung, Twin Double Hung, Triple Double Hung.
Technically these windows are no different (geometrically) than the single hung variants however the callout indicates that they are "double" hung instead of "single" hung.  This addition was per customer request.
Nathaniel P. Wilkerson, P.E.
Medeek
Version 2.9.1 - 07.08.2022
- Added additional grille options for windows and doors.
The additional grille options are all GRID options.  The "FH" appending the window grille options stands for "Farm House".  When this option is chosen the grille is only installed in the top window of a single or double hung type window.
Medeek
Version 2.9.2 - 07.24.2022
- Added one additional raised header configuration for windows and doors.
The "RAISED2" configuration removes the plate directly below the header.  This update per customer request.
Medeek
Version 2.9.3 - 07.29.2022
- Enabled independent control of exterior and interior stud depths for staggered stud walls (rectangular only).
Previously staggered studs were auto-calculated and one could not independently control the stud depth for the exterior and interior studs.  This latest update allows for granular control of the stud depths and makes the staggered stud feature more flexible and useful.
Medeek
First look at custom casings:
Notice that when CUSTOM casing is specified for the Casing Style, the edit or draw menu will provide a preview of the profile as shown.
Now I need to work on enabling this for arched doors and also updating the global settings with this new option.
Medeek
Version 2.9.4 - 08.05.2022
- Enabled CUSTOM door casings for rectangular doors.
- Added a thumbnail preview into the edit and draw door menus showing the custom casing profiles.
- Added a thumbnail preview into the Door tab of the Global Settings and added the custom profile parameter.
Additional profiles can be added into the "casings" sub-folder of the "library" folder within the plugin folder.  Placement of the profile is important, so best practice is to open one of the two examples within this sub-folder and duplicate its positioning and grouping.
I will still need to enable this feature for arched doors and all window types, so much more work is yet to be done in this regard.  It seems there is never a lack of work when it comes to this plugin.
Medeek
Version 2.9.5 - 08.06.2022
- Enabled CUSTOM door casings for arched doors.
- Added CUSTOM D and CUSTOM F door casing options for rectangular doors.
Medeek
Version 2.9.6 - 08.07.2022
- Added STYLE G and CUSTOM G casing options for rectangular doors.
I had to add in these two styles since they are used in our own home.  I think I have finally beaten this horse to death but if there are any other styles you feel should be added please feel free to contact me or post them here.
The profile for the upper molding is found in the "system" sub-folder of the "library" folder.  It can be edited and customized by the user.  The file name is: CM_HEADER.skp
Medeek
Version 2.9.7 - 08.09.2022
- Enabled the following CUSTOM casings for rectangular windows: CUSTOM, CUSTOM D, CUSTOM F, CUSTOM G.
- Added a thumbnail preview into the edit and draw window menus showing the custom casing profiles.
- Added a thumbnail preview into the Window tab of the Global Settings and added the custom profile parameter.
- Added a STYLE G casing option for rectangular windows.
- Fixed a compatibility bug with CUSTOM door casings.
Medeek
Version 2.9.8 - 08.13.2022
- Added a "Label Rotation" parameter for all wall types (0 or 180 degrees).
- Added a default "Label Rotation" parameter into the General tab of the Global Settings.
Medeek
Tutorial 31 - Custom Window and Door Casings (15:42 min.)
https://youtu.be/msWClVo3VEo
Medeek
Version 2.9.9 - 08.21.2022
- Enabled an option to specify the location of beam pocket king studs for in-wall columns: LEFT, RIGHT, BOTH.
- Fixed a number of minor bugs related to in-wall columns.
Medeek
Version 3.0.0 - 08.22.2022
- Fixed a bug created by the upgrades in Version 2.9.9.
- Updated some of the Global Settings tabs to display the status message at the top of the HTML page.
Medeek
Version 3.1.7 - 08.26.2022
- Enabled the following 3D roof cladding material for shed rafter roofs: Metal.
Medeek
Version 3.0.1 - 09.03.2022
- Added a "Label Location" parameter for windows: AUTO, INT, EXT.
- Added a "Label Location" parameter for doors: AUTO, INT, EXT.
You can now manually configure the window and door labels to be on the interior or exterior of the wall on a per opening basis.  The feature added per customer request.
Medeek
Version 3.0.2 - 09.05.2022
- Enabled custom materials for wall framing within the global settngs.
- Enabled custom materials within the "Wall Framing Material" parameter for all wall types.
With this update you are no longer constrained to set number of material/texture options for the wall framing.  You can now use your own custom material for wall framing.  The update was also per customer request.
Medeek
Version 3.0.2b - 09.06.2022
- Fixed a bug with wall presets introduced with the addition of the Label Rotation parameter from Version 2.9.8.
!!!! CRITICAL BUG FIX !!!!
This bug affects wall presets within the "Draw" menu only.  The issue was already correct in the "Edit" menu.  I strongly encourage everyone to upgrade to this version of the plugin if you have Version 1.9.8 or later currently installed.
Medeek
Version 3.0.3 - 09.12.2022
- Reorganized the door draw and edit menus to include an annotations section.
- Added a "door swing angle" parameter for single and double doors.
- Added the door swing angle parameter to the Door tab of the global settings.
The preset angles are: 30, 45, 60, 90, 120, 135.  The door swing angle for the door symbol can be set on a per door basis and can also be set to a default value within the global settings.  This update per customer request.
Medeek
Version 3.0.4 - 09.15.2022
- Added XPS foam insulation as a built-in cavity insulation option.
- Added XPS foam insulation as a built-in sheathing option.
In the material folder I've also included a zero-border version that can be utilized as a custom material.
Medeek
Version 3.0.5 - 12.15.2022
- Enabled auto-dimensioning for plan views of all wall panels.
- Added the "Dimension Offset 2" and "Plan Dimensions" parameters to the General tab of the global settings.
- Updated the Add Material and Edit Material HTML menus so that commas cannot be used in Custom Material names.
Note that framing dimensions (elevations) and plan dimensions (plan view) can be turned on and off independent of each other in the global settings.  Also the additional offset parameters allows one to adjust both offsets independently as well.  However both dimensions are placed on the same layer (at least for now).
Currently the plan view dimension option will assign an overall dimension for the wall length and then separate dimensions for windows, doors and garage doors.  I do not have it inserting dimensions for more custom features like Simpson Strong Walls or in-wall columns.
This new feature is per customer request.
Medeek
Version 3.0.6 - 12.28.2022
- Added a "Jamb Interior" parameter into the Draw and Edit menus for doors.
- Enabled this parameter for both rectangular and arched doors.
- Added this parameter to the Doors tab of the Global Settings.
This update was per my previous notes and per customer request.
Medeek
Just cleaning up some loose ends before the start of the New Year.
One issue that is sometimes encountered is when a custom material is defined in the Material Library and then after using it in a Wall Preset it is subsequently deleted.
When this happens and that particular Wall Preset is loaded the plugin tries to assign that custom material in the Draw or Edit wall menu.  If you try this you will quickly notice the drop down box for the material is blank and no valid material is selected.  This inevitably leads to an error either being thrown within the plugin code itself or within the javascript of the HTML menu pages (not sure which at this point).
I need to devise some error checking in the HTML/Javascript to detect this problem if it pops up and gracefully resolve it rather than locking up the plugin.  If I can fix this it will not only save the end user from annoying headaches but also eliminate unnecessary support calls and emails for myself.
Medeek
Version 3.0.7 - 12.30.2022
- Added error checking code into various HTML menus to detect non-existent custom materials used within wall, door and window presets.
- Updated the Wall Stretch tool with an improved wireframe preview.
- Changed the default value for the header extension parameter to zero for doors, windows and garage doors.
The third item in this list was per customer request.
Medeek
Version 3.0.8 - 01.03.2023
- Added ICF options in to the Insulation tab of the Global Settings.
- Added an ICF wall framing option for all wall types.
- Added four additional ICF parameters into the wall Draw and Edit menus.
- Fixed a bug with the plan view auto-dimensioning module.
- Enabled trim, ext. wainscoting and quoins for CMU Core and ICF wall types.
ALERT! - CRITICAL BUG FIX
The bug associated with the upgrade that brought you plan view dimensions will cause the plugin to abort during regeneration when installing garage doors into a wall.  It is highly recommended that you install this latest update which addresses this bug and a couple more minor bugs with the plan view dimension feature.
Medeek
Version 3.0.8b - 01.03.2023
- Added a "Concrete" layer to the Layers tab of the Global Settings.
