Wooden sub frame directly over concrete
Started by waltsuz, April 11, 2016, 08:54:07 AM
waltsuz
I was referred to this forum about a cabin design I am ready to start building. The technique I am using I have used before on posts with greats results but I have had to change this method because of the terrain. I have a 20x28' concrete slab I want to build a 2x8 PT frame/subfloor structure directly over the concrete slab to erect our cabin on. I use T1 siding and this allows the bottom of the siding to remain off the ground and allows drains, electric, and insulation in the sub floor. I have not found a method of anchoring nor recommendations for vapor barriers to do this. I have used styro foam insulation in previous buildings as insulation and vapor barrier all in one in the floor structure and built off of that. We are basically homesteading a wooded property, we have no codes and I can pretty much do as we want. Any suggestions would be appreciated. Thanks for taking the time to read this, Regards Walt
waltsuz
#1
https://s1100.photobucket.com/user/waltsuz/media/sub%20floor.jpg.html
Hope this works
Picture shows a building base I did anchored with 4x6 posts. I want to do another similar to the picture and anchor it directly on a concrete slab without posts and build a 20x28' cabin on the base. I can't find anything like this online and was looking for opinions, Regards Walt https://s1100.photobucket.com/user/waltsuz/media/building1.jpg.html
Not sure I am understanding but I will give it a shot from what I think you are describing.
Generally when building on concrete slab the base plate is anchored with wedge bolts or J-bolts.  You could bolt a base plate to the slab and build off of that.  The plate would be anchored and then you attach the rim joist and interior floor joist to them. Grace makes a barrier which I describe below which could be placed between the concrete and PT wood.
But if you are just wanting to attach what you have pictured (complete w/insulation) then you could use Grace Ice/snow guard to the slab (or directly to the joist bottoms in strips) which would give you a moisture barrier.  As far as anchoring without looking I would say that "Simpson" has available a fastener for this application.  But if you use Simpson galvanized fasteners I would use small pieces of either # 15 felt or ice guard between the metal and the wood as the chemical properties of the wood treatment will corrode the fastener.
waltsuz
Quote from: Redoverfarm on April 11, 2016, 01:02:43 PM
Thank you Redoverfarm, Your explanation is what I'm asking. I was thinking of laying a layer of #15 felt paper over the entire slab then building/ setting the sub frame over it. I've never used ice guard which sounds interesting and I'll look into it. Hopefully I can find angle clips to attach this to the concrete with wedge bolts or redheads. I'm surprised I haven't found a technique like this online anywhere. Regards Walt
