My Pocket Cabin in the Mountains.
Started by Watch Ryder, December 28, 2014, 07:23:34 AM
Watch Ryder
Unlike my primary cabin which is a sizable 14 x 16' this one would be tiny – only 4 x 6'. Nor would it be too fancy or require sophisticated lifting methods but it would mean I'd have to put my cabin build on hold until next year alas.
Challenges.
I am at at very high elevation, the terrain is rocky and the winter weather is closing in...
Here's one wall almost done.
Back wall is up, this will be braced later hopefully, otherwise the snow drifts and pack could push it in a bit.
The video shows it start to finish here but by pictures I go into a bit more detail:
For the side walls I needed something with raw weight and toughness to give much needed mass. I found it in a tree I'd felled a few weeks earlier. It wasn't quite straight enough for long posts but for a short wall log it was perfect.
Folks, it's time to meet the first of the Balbek Logs! I call them this because they dwarf the smaller logs and also pay homage to the mighty Baalbek stones of ancient times...
I mounted, drilled and bolted this in myself which was quite a feat (foolhardy with the drop-off directly behind me but I managed it).
For the second Balbek Log my neighbor helped me as it was too high to even dare suspended from one arm alone!
Watch Ryder
Getting the roof on was not going to be easy, not only was the roof pitch in excess of 45 degrees (about 45.5 or 12.2?) but I'd never laid a roof before.
Still there's only one way to find out and that's to get stuck in and at it!
Plywood wall trimmed.
Time for the plywood roof to get installed!
As much as I like being ultra-self reliant, 4x8 plywood at 1/2 inch is too awkward and once again help was essential in lifting and holding while I lined it up for drilling...
Tarpaper is going up! I've not installed this the correct way though, as I ought to have to running along the roof and not from top to bottom. Hopefully they'll be no leakage issues...
Getting the asphalt shingles on.
A friendly neighbor let me have a bundle of these for free, but strangely would not let me have the paired second bundle, little did I know this would later bite me on the behind, but more on that later.
Starter Course
Subsequent courses.
I ran out of shingle and had a devil of a time getting more of the same type and shading.
I got the last bundle at a nearby store but even that wasn't enough! I need a third bundle!
Watch Ryder
This is what I made three of the logs into.
I suspend it from a chainblock and cut it from top to bottom with a chainsaw!
It was much easier than leaning it against a tree. I'll be using a saw-horse in future times though...
I managed to install it myself! It was as heavy as the first ones but I semi-cheated by passing it in from the interior of the structure and the rafters helped keep it from toppling down to the ground. I added the bracers shortly afterwards.
The other Balbek Log I cut into two smaller pieces and here they are on the alcove side.
This is what the rain looks like when it drains off the roof, it's a foot clear of the posts too keeping it far enough to keep subsistence down to a minimum.
I'll add some stones to this at a later stage so it doesn't erode the ground away.
Watch Ryder
My neighbor kindly let me have an old door from the materials stockpile. He told its tale and made mention that it's at least 100 years old! From a relation in homestead lands it now has new purpose at the Ryder's Redoubt.
With his help this and other materials soon arrived and it was time to get the door screwed into place...
Getting a door on is no mean feat but with shims, boxes and other things to level it up I managed to get it square and installed.
Ready and I've got a hasp lock installed too, I'd like to see a bear figure its way into that one.
This is the last day at the Mountain Hold and the weather began to close in like a mystical mountain fog...
Watch Ryder
The Tree i sourced the big logs from:
Interior Pic.
The Cabin Shed / Storehouse is complete and the great rain and snow looms in the coming days. I only just reached the construction-finished point with days to spare.
The gaps and crannies have been sealed, with the exception of the rafter-gaps which I did not have time to block off with noggins etc.
So while I've hopefully got the deer mice and voles sealed off from the interior squirrels and maybe a pika will take up (temporary) residence, plus perhaps a wasps nest over the winter.
The morning of departure was a busy one, not only was there a lot to do but the temperature was freezing.
Just look at the roof!
Icy coverings were everywhere but the sun shone bright and soon melted it all away...
Mike helped brace up the cabin, hopefully it won't end up tumbling down under the weight of the snow but as a safeguard several logs like this will help prevent it.
It's my first ever building I've built myself (with lifting assistance and some advice from MMM of course).
I can only hope it will stand the test of winter! A real test at 9,500 feet in the Rocky Mountains, only time will tell...
Gary O
OK, I'll be the first to stick my goofy lookin' neck out and say, 'Hey, whatcha doin'?'
My first take was, 'what th'?'
Then I thought, 'well, geez, I don't think I could do that with those tools, let alone pack those tools over those hills, let alone pack my own hind end over those hills.
Love yer energy.
I s'pose you got a plan......(?)
you mentioned a larger cabin?
Welcome, BTW
Watch Ryder
Quote from: Gary O on December 28, 2014, 10:13:06 AM
Love yer energy.
Welcome, BTW
Hey Mr Goof! :)
Yep this is just the start. Got an even bigger project to work on in the summer! It'll hopefully be a Redoubt on the mountain into the very bedrock of the mountain itself!
Larger cabin will be about 14x16 and 18 feet high at the ridge. A custom Pole Barn Cabin with my own quirky style.
Gary O
Well now ya gotta expound....
Vehicle?
Jenny?
Watch Ryder
Quote from: Gary O on December 28, 2014, 04:04:46 PM
Vehicle?
Jenny?
I can tell my saga in another thread, that might be much more rewarding.  Got a pickup. Got a small generator, it's a cheap 100 bucks deal from harbor freight though. It kinda sucks at high elevation.
speedfunk
very neat.  Im a sucker for a simple shack made with whats there.
Watch Ryder
hpinson
