When I read this my mind went to the beetle infestation we have here. If you are seeing a lot of bluing - bingo.
That is interesting on the lack of resin blobs, the epithelial cells under normal circumstances are the last to die, they can still be cranking out resin in the logs months after a tree is disconnected from its' roots. The moisture is higher here but we'll get blue in warm weather with or without beetles in dead sapwood that is above fiber saturation point. Beetles tunneling through the spore covered bark certainly carry it in much faster. That sapstain fungi is a sugar eater, drinking it up from the cell lumens rather than feeding on the cell walls themselves but it is saying the conditions are right for the true decay fungi to move in.I suspect the steam explosion(s) within the tree cause an embolism in the vascular water column between roots and leaf and the tree has no way of repriming that capillary pump (which is also why it is impossible for sap to "go down" in winter. a tree has no way to re-establish a broken water column)
There is always great urgency to move pine logs to the mills and get water on them in the summer time. This of course prevents the blue stain or the growth of the fungus that causes bluing.
I counted 102 rings today; 2 feet above ground @ 16" diameter. That's a NM tree for you.
WOW you are definitely not the the pine forests of Georgia and the Carolina's nor the Washington and Oregon plantations.....
It's one reason I do quite fine with a 16" bar. I have one more already thoroughly dead and dry ponderosa about this same size that I'm leaving standing for the birds or whatever. It's far enough away from any normal activity, far away from buildings, etc, but close enough to a bunch of other trees that it is pretty much guaranteed to hang up. thread drift? ..... what's that?
The idea of slowly blowing / moving cool air from inside to the battery box has merit I think. If the box was sealed better than mine that should push the circulation from bottom to an upper exit. In one end at bottom and out the other at the top.
Petawawa Fire Fighters fought several blazes yesterday after a massive lightning strike behind two homes on Blue Jay Way in Petawawa.According to Petawawa Deputy Fire Chief, Chico Traclet, at 2:30 in the afternoon yesterday the lightning strike hit a jack pine sending splintered wood in a 200 feet radius in the backyard of the two homes. The energy of the lighting strike ignited a natural gas meter at one home and hit a garage at the 2nd home. The strike also hit an underground tracer wire along a gas line and ruptured a 4 inch line in front of the two homes.One home completely burned to the ground while the second home suffered damage to the roof of their home and their garage burned to the ground.No one suffered any injuries and 16 Petawawa Fire Fighters responded to the blaze as well as Garrison Petawawa Fire Fighters. The Garrison also provided their ariel truck to combat the flames. Crews were on scene monitoring the situation until 6:30 this morning.
