Lumpy/Sunken Looking Roof
Started by theworstspy, December 16, 2013, 05:27:58 PM
theworstspy
Recently put an addition on and the roof and slowly gotten a lumpy, sunken look. Has anyone ever seen something similar? what is typically the cause? OSB was used for the decking, nails and clips.
Please help!
j
Not sure whether you posted a photo or not but it is not appearing in the message. OSB get wet prior to your underlayment?  Did you use 30# felt or synthetic underlayment?  Did you meet the sheets on a rafter or between a rafter?  Was you underlayment flat when you applied your singles?   What weight shingles did you use?  Did you use 5/8" or 1/2" OSB sheeting or plywood?   Were your rafters set on 16" or 24" OC.  Did you use factory made rafters or did you make them up yourself.  All or a combination can contribute to what you describe.
What John said. A photo would be worth a 1000 words.  :)
help with posting photos....HERE
