16x25 Studio 100 Mile House B.C.
Started by GW, June 24, 2008, 12:09:29 PM
GW
We finally got started on our studio. We had 10 days of delays because of weather and problems with getting the foundation poured. The work you see here took place over 3 days. By the last day we were short on manpower and only got 2 of the 14 trusses placed.
ED: introduced spaces between pictures for easier viewing - MD
For three days that had to be a well planned coordinated effort.  Good job.
Way to go, you guys aren't messing around - great job!  Pretty area, too  8)
dmlsr
This cabin is being built in memory of my father Robert and my granfather Henry.
Thank you for looking
Dave
GW
I have to say I cheated a bit. While we were waiting for the foundation to be poured I made the headers and precut most of the wood for the walls. We are going up next week to try to get the rest of the trusses placed and the roof sheathing on. I have to say I'm scared of heights and dreading doing the roofing work. I wish I hired that out but its pretty hard to get someone this time of the year.
Don't worry about the height.  A fall from 20 feet is not a lot worse than a fall from 30 feet...either could kill you.  Just be careful.  Work 100% tied off if you feel better about it- a bit slower but safer.  Safety harnesses are available for around $100.
Complete kit - 129   http://www.amazon.com/gp/product/B00005Q7A6/ref=pd_cp_hi_0?pf_rd_p=277661601&pf_rd_s=center-41&pf_rd_t=201&pf_rd_i=B0007KQXVI&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=02N83KGBPJP3X0TWZHF5
Just a harness is really cheap -
http://www.amazon.com/MSA-SAFETY-WORKS-10072487-HARNESS/dp/B000S8647W/ref=pd_bbs_sr_3?ie=UTF8&s=electronics&qid=1214351611&sr=8-3
or kit with fall cushion lanyard which is best
http://www.amazon.com/gp/product/B0007KQXVI/ref=pd_cp_e_0?pf_rd_p=277661601&pf_rd_s=center-41&pf_rd_t=201&pf_rd_i=B000S8647W&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=005C1T8JQ63F38F7QFEE
Note -- I am a professional --- I have tipped a manlift over at 68' in the air.  No problem.
GW
I'll definitely use fall protection for the sheathing and the metal roof. d*
Nice work guys and thanks to Glenn for the links to the "Right Stuff"!
Safety FIRST!
I hate to be a sissy but if I'm going down, it's nice to know I'm hooked up. My problem is I have no fear whether I'm hooked up or not.  82 feet up seemed about the same as 20.
Situational awareness helps but is not a substitute for safety.
Very nice work GW. I love to see that fine Canadian lumber! Stout built for sure. [cool]
PA-Builder
Quote from: glenn kangiser on June 24, 2008, 11:57:24 PM
You may have been called a lot of names during your time; but I doubt "sissy" was one of them !
Thanks, PA.  I have my moments. :)
Now if I could just get rid of this attitude, and let you see my humble side. ::)
Yeah --right. [crz]
GW
We got the trusses up yesterday. I'm afraid of heights so it wasn't easy, next time I build something its not going to have a 12/12 roof pitch. The trusses didn't line up perfectly, I'm hoping the roof doesn't look all wonky. I'm not going to bother sheathing it , I'm going to use purlins since I have a metal roof.
I still think the 12/12 is worth it even if you have to get help.  Looks good.
GW
Some updates, septic is going in today,[ no pictures].
Nice work. :D
These are called parallel chord trusses and give you lots of room for insulation while providing a full slope cathedral on the interior (unlike a scissors truss that has a flatter interior pitch).
Yep, I agree with Glenn... I'll bet long term you will be glad for both the look and the usable space of the 12:12 pitch roof. A 4:12 is easier to roof, but then you would have... a single story rambler. ;D
With luck and the metal roofing you probably only do it once.
GW
Looking good. I like the big double doors on the front.
If you needed extra racking resistance (I'm not saying you do - but it might helpful if you have heavy wind or earthquake loads) then you could sheath the inside of that wall with 3/8" OSB prior to the drywall or interior finish. That will add extra stiffness.
GW
Earthquakes aren't a big problem here but it does get windy, I might just do that, thanks for the advise. We got the loft up and the last of the windows in. I attached the loft as directed by the designer, Ledger boards lag bolted on to the wall studs, then joist hangers. I know this is not how you guys do it here.
KDOG
GW
We found a few toads hanging around, funny I've never seen a toad before. I also saw a bear and a bobcat.
