rafter to top plate joint at end wall
Started by BigMish, March 30, 2007, 09:47:46 AM
BigMish
In the 20' wide 1 1/2 story, the birds mouth joint connecting the rafter to the top plate is measured at 5 ½" on the plans. However, at the end walls, it seems to me, the joint would just be flat and not be a birds mouth, right? Also, at this joint the Simpson H10 looks like it won't work; what connector should be used here?
Thanks, Mischa
 Your graphic's  are  slipping Mish ,  ;D Is that showing two 2x6 stacked on each other??
Your right about a H10 not working on a / the gable rafter's generally the inspector doesn't demand a clip / connector on those as they are tied in with the gable end sheathing , the sheathing is the connector . If he , or you want a clip usea A35 ,
 Link :http://www.strongtie.com/products/connectors/ltp4-ltp5-a34-a35.html#gallery
that's about what it should look like.
Ridge to rafter,
BigMish
Thanks PEG,
I cleaned up the image a bit just to make sure I was understanding it right. Yes, by my reading of the plans the truss is built of 2 2x6s stacked on top of each other. Is that not right?
Depends  ;D There must be gussets to tie the two together??? Never seen it done that way in 30 plus years of building , that doesn't make it wrong , BUT I think your reading something wrong on the plan . But if that what John's calling out he must have  a detail/ reason for it .
 [size=72] HEY JOHN!![/size]  ;D
BigMish
yes, there are gussets: 11x11 tie gussets from 1/2" plywood @ 5' o.c.
 There ya go , so it's a truss , site built I assume . He may be using that system to make it easier for semi / unskilled folks to build , ease of packing stuff into a some what remote site , might be a hold over to John's young hippy years , that being opposed to his older hippy years  ;D.
Without plans I'm shooting from the hip , site built truss's a DIY , YMMV , lack Stamped Engineering , would have  a hard time getting thru a plan inspection check , IFFY set up , to many variables , not controlable as to materials quality , etc etc .
 But if John drew it , and you follow his design , use the same or better spec.ed lumber grade , etc , it will be a good truss.
 If he spec.ed standard and better Doug Fir , do not use the cheaper SPF , utility grade , common fir , type materials . The strength of the truss , MTL , was based on a specific garde of lumber , any lesser grade lumber will result in a weaker , strenght wise , truss.
If the gussets are 5' OC out of 1/2 "  CDX don't use 3/8" OSB 6' OC , follow the plan , most folks wanta make it cheaper , stretch the materail , use cheaper material , a 2x6 is a 2x6 , is not true in some case's , the GRADE is important in this truss type issue .
BigMish
Unless I'm missing it (I've read and re-read a few times) I'm not seeing a grade specified for the 2x6s that compose the truss. John, what should they be?
No 2 or better standard DF or SP framing lumber.
On the end walls the notch shown in the bottom 2x6 will not work as you noticed. You will cut it off on those two trusses and can then tie the two sides together with a 2x4 or 2x6 collar tie or nailer on top of the end wall plates. That will lock the truss together even tighter on the end walls and this can be spiked into the double top plate.
Yeah, PEG. This is a non-engineered site-built truss for DIY framing on the loft floor. It is made with 2x6's so as to not be hugely weighty. A 2nd 2x6 is scabbed onto the bottom after the roof is up to provide full insulation at the sloped portion of the ceiling.
Of course, an owner or builder can have the local truss company engineer and fabricate these to local loads and to the satisfaction of the inspector. I have over-designed this truss for many locations so the manufactured units may be lighter and perhaps even less expensive for some areas than building it yourself.
PS - I may not be able to be quite on top of the forum questions here for a few days. I just heard that my 90 year old father broke his hip so I may need to be taking off some time.
youngins
"A spoonfull of sugar helps the medicine go down.."
I'll be going over to Wenatchee early in the AM and should be back here on Monday. I'll take a laptop and may be able to log on from there.
John R.
I hope things go well or at least better, John.  We'll do what we can.
Have a safe trip John , we're hoping for the best. Glenn will keep us in line  ;D
QuoteNow you have me scared, PEG. :o
Ya right  ;D Scared you'll go crazy with abslolute power :-/ :o
I never wield my whip unnecessarily.   :-/
OK -- well --- I try not to leave any marks where they will show. :o
