pier flooring insulation
Started by dan614, March 30, 2007, 05:03:57 PM
dan614
How do you insulate a pier or skid floor????? I want to make my cabin usable in the winter.
Building on piers and beams you would leave enough space under the beams and joists to allow you to crawl under and install your insulation from underneath after the cabin is dried in. Then you should cover the underside of the joists/insulation with something to keep the critters out and still allow for ventilation. Pegboard is one way.
Pre build your floor down side up , insulate as required , Typar under side of floor joist , add wood lathe , or strapping , ( to insure the Typar stays up ) roll the floor over , You'll need helpers , on to your skids , simple .  You'd be good to go for years with that setup , unless you poked holes in the Typar when skidding the place around.
dan614
Would you use faced or not. We get alot of snow so moisture could be a problem
QuoteWould you use faced or not. We get alot of snow so moisture could be a problem
I'd use unfaced insulation, what the Typar would be , [highlight]in theroy [/highlight], is breath the faced insulation is in part a vapor barrier , so it MIGHT trap moisture between the subfloor and the paper.
skiwest
I was with - top to bottom
subfloor
6mil poly vapor barrier
joists 2x10 with bat insulation
1" blue board
sheathing 3/8"
1/4" page wire  - think thats the name - the wire mesh 1/4" squares glav.
Had mice and rats in a house that really had to work on so anal about the critters
Quote1/4" page wire  - think thats the name - the wire mesh 1/4" squares glav.
It's called Hardware Cloth.
The sheathing above the wire mesh will not allow the floor to breath down and the plastic on top will lock any moisture in at the top. It might be better to use pegboard; it'll breath.  Of course the blueboard will also slow down the breathing if it's fitted tight/nailed. Let's see what PEG thinks.   :-/
Quote
I already did say what I thought, see post  3 & 5 , the wire / hardware cloth over the Typar would be nice as rodents here are a  big issue, sort of a belt and suspenders  thing .
We have Norwiegn rat around here and I've seen a place where they chewed thru standrad bird blocks plastic mesh , we had to remove all the insulation in a couple of attic spaces , and put wire mesh soffit vents over the bird block / vented blocks between the truss's , the rats ,we think , orginally got in thru the vented ridge vent  ( which had light weight plastic mesh orginally ), we also screwed hardware cloth from inside the attic space to keep them from getting in that way as well. They are persistance little buggers , those norweign's , ah the rats that is  :-[
The vent is essently 1/4 " hardware cloth with a metal frame , so hardware cloth in combination with Typar would be a good thing in the long run , but it would be spendy.
Why is it good and cheap rarely go hand in hand  :o ;D
QuoteWhy is it good and cheap rarely go hand in hand   :o ;D
PEG,  Sassy is half Norwegian.... and are you saying that is why we don't hold hands much?
Very good twist Glenn  ;D Took me a second to figger er out ;)
Thought you were picking on me for a minute there. :-/
Your just naturally paranoid , remember,  you can pick your nose but ya can't pick yer friends nose ;D And your MTL only paranoid cuz everyones out ta get ya, just like me  :-[ ::)
