post bracket unlevel
Started by astidham, June 10, 2010, 06:13:31 PM
astidham
some of my post brackets i put in concrete are a little un-level, what would be a good way to fill the gap or shim them so there will be no gap from my 6x6 to the base?
— Henry Ford
I'd use some galvanized flat washers or cedar shims.
astidham
Thank you ScottA, so just level the post verticaly and fill the gaps?
— Henry Ford
Cedar is not up to the task, hardwood or steel, hardwood will rot. I'd cut the post to the shape needed. A short chunk of scrap post and a torpedo level should make it easy to map what you need on the real post.
diyfrank
Just in case you're using that string line for grade you will be a little off. A dry line sags a 1/8" in 20'  And a wet string around  a 1/4"
Home is where you make it
markert2523
I just used cedar shims to fill the gaps--------time will tell, but I think there is enough settling here and there that it won't make that much of a difference in grand scheme of things.
Eric
astidham
— Henry Ford
Rover
I've used plastic shims.  I love them.  They are the ones my curtainwall subcontractors use to install large aluminum framed windows.  They gave me a whole bag of various thickness flat ones and wedge shaped ones.  They are even colour coded.  Sorry, I don't know where to buy them.
astidham
is there any type of liquid shim for this application?
— Henry Ford
