change of plans
Started by tesa, April 28, 2010, 01:21:22 PM
tesa
is it possible to build the 1 1/2 story WITHOUT the 1/2 story??
can't i just frame the walls to be shorter, basically only building a one story?
way back in the beginning of things, i had considered building the 1 1/2 story as a 20'X40' but thought it too big
now i'm reconsidering it, building it as a 20'X40' but not building the loft, we decided it will be enough room at 20'X40',
and i'd like to have exposed beams so i wouldn't want the loft
thoughts?
tesa
"building a house requires thousands of decisions based on a million bits of information"-charlie wing
OkieJohn2
Have you already purchased the 1 1/2 story plans?  John also has the 1 story 20 x 30 plan.
http://www.jshow.com/y2k/listings/46.html
tesa
yes, i've already purchased them.
and the funny part?
we THOUGHT we were sure of what we wanted, i agonized over the decission, and now we want the other one
i'm hoping i can make these plans work for us
tesa
Yes, you can just build the one story walls to the height you want for the ceiling and then have the local truss company build trusses (24: o/c) for the roof structure. They will factor in the local loads.
If you want, they likely can make different shapes for you interior ceiling other than just flat. Ask about an "energy" truss if you want a highly insulated ceiling.
tesa
phew! thanks, one less thing to stress over
man, this home building is FULL of decissions!!
we wanted to do site build trusses, and contract out the metal roof install
do i have to go with off site built?
tesa
tesa
sorry, i'm confussed, or tired, or both, but we're not doing trusses, we're doing rafters
tesa
Use 2x8 rafters and 2x8 ceiling joists both @ 24" o/c. See "Basic Gable Roof"  Chptr 9 in Wagner book.
