For Those of Us Who Have a "Thing" About Large Diameter Bullets
Started by MountainDon, March 22, 2010, 11:46:00 PM
 :D :D    The 454 Casull chambering is what's new  :o   6 shots, too.   :P
Quote from: Windpower on March 23, 2010, 07:14:32 AM
the 3" snubby would be 'interesting' to fire
More flamethrower than Handgun ;D
The problem with the 45/310 combos is that unless you do some real creative handloading or a rechamber, they are just not very accurate.
I had to burn up a lot of powder before I got my BFR shooting well.
The long cylinder makes for a lot of freebore unless you make a case that spans it.
I went to the range 20 years ago with my boss and a gun-nut co-worker.  He brought along his Casull for us to shoot.  My boss was not a handgun shooter, and fired the Casull with bent elbows.  The revolver kicked back and smacked him in the forehead.  It was all I could do not to laugh.
A)  He was my boss
B)  He was holding a loaded revolver  ;D
Quote from: peternap on March 23, 2010, 08:02:33 AM
That is the criticism I have read about.  But it is an interesting revolver.
Do you use 410 all brass cases or size 444 marlin?
444 Don.
All of the 410 brass that I know of except RMC, is baloon head and won't stand the pressures I put in it.
Some people are making cases out of 9. something (Sorry, my CRS is acting up) and that has a little more length.
You do have to use a rebated heel bullet unless you rechamber.
If you're willing to rechamber, there are a number of other options.
I do use brass 410's for my Buckshot, Bear loads. These are .50 balls I size and flatten the ends so they will syack in the case,
You can see the bear loads here:
SardonicSmile
I'm a little wary of the "new" calibers. There have been many, and all but a few are practically out of production.
Quote from: SardonicSmile on March 23, 2010, 05:38:08 PM
If you are referring to the 454 it's been around for over 50 years, although there have not been many handguns made for it. Based on the 45LC it uses a heavier wall gauge and longer case and produces much higher pressures. 45LC can be used in a 454, but not the other way around.
335 gr      1,600 ft/s    1,904 ft·lb
eddiescabin
I like Peter's pic,  FIRST he smacks the bear with the crecents wrench!  Don't make him grab his shotgun!  Thanks for the info on guns a casual observer would not know about...I think they rate guns in Cali by how many Caddy dorrs it will shoot thru!
